Question about Coby Televison & Video
Wont play disks
I have a new coby dvd player #dvd-233 when i insert disc it keeps telling me there isnt a disc what can the problem be
  • Coby Master
  • 19,396 Answers
If this happens with all disks, then the lens are dirty or faulty.
Try first using a cleaner disk. If that does not work, then the player must be taken apart removing screws at the back and at the bottom of the unit, to clean lens manually using isopropyl alcohol and Qtips.
If that does not work, then the lens pickup must be replaced.
Before attempting any repair call manufacturer ringing the number listed on the owners manual.
Posted on Sep 05, 2009
SOURCE: Bad Disc - CH-DVD 300 DVD Player Problem
Goto the following site: http://www.drx9000repair.netfirms.com/#Cyberhome%20CH%20300 You more than likely have a bad power supply. The caps in the output circuit are pretty crappy and are well known for failure. Good luck! Art
Posted on Aug 22, 2007
VOTIT
  • 2071 Answers
SOURCE: APEX AD-1115 DVD PLAYER
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 25, 2008
stonephoenix
  • 563 Answers
SOURCE: No disc message on my coby 224 dvd player
Thanks for using FixYa.
If the unit is showing "no disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. It can not be repaired. Our warranty is 90 days from the date of purchase. If you received the unit as a Xmas present, please call 1-800-727-3592 for instructions on getting the unit exchanged.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 07, 2009
renx
  • 71 Answers
SOURCE: dvd player will not spin disk
Unfortunately, your DVD player is broken. Portable units like these often get bumped and jostled and the motor that spins the DVD quits (very small and fragile). Sorry, I wish there were a magic button.
Posted on May 02, 2009
  • 5 Answers
SOURCE: Philips PET710 DVD player shows 'no disc' when disc inserted
The safest way , this may sound really stupid but has always worked for me is give it a slightly rough slam on its bottom and it will work , dont judge this badly for it actually wotrks
Posted on Feb 16, 2010
When I insert a disc it says no disc
try cleaning the lens, either with a cleaning disc or taking it apart and using white spirit on a cotton wool bud, but not too much spirit
Apr 17, 2010 | Coby DVD-233 DVD Player
DVD power button won't turn green. why? initially
my best advise after alot of time straining thought process... i decided that you should go to walmart and get a new dvd player
Dec 21, 2009 | Coby DVD-233 DVD Player
Won't read Dvd/Cd as loaded
It is a problem of the optical head being covered up by foreign particles obscuring the optical lens. Try using a CD/DVD cleaner disc which has double brushes and one add some solvent which comes along with the pack.Simply play it & keep ejecting and inserting the disc makes the disc to spin, till your player starts reading it..............................sodeep
Oct 06, 2009 | Coby DVD-224 Player
Coby TR-DVD8500
Sounds like it's a problem with the optical sensor in the disk drive. Try and clean the little sensor with a cloth. If that doesn't work then you may have to send it back to Coby for either a warranty replacement or a repair.
Apr 13, 2009 | Coby TFDVD5000 Portable DVD Player
Dratted Coby TF-DVD7100 Portable DVD player not working!
Its defective. Coby doesn't repair the units. The lense is off balance which is causing the laser to not read the dvd/cd.
Apr 17, 2008 | Coby TF-DVD7100 Portable DVD Player
Invalid disk message sometimes and machine lock up
coby dvd-233 cd wouldn't spin invalid disc is displayed on the tv please help me solve this problem
Jan 21, 2008 | Coby DVD-233 DVD Player
Nov 27, 2007 | Coby DVD-224 DVD Player
Not playing DVD
i have coby dvd 283 player , its new but i don't know why it is nt playing ..........when i start the power button and insert disk , then on my tv on right hand upper side of the tv only a picture of the disk rotating round is seen .................pls help me out what shall i do
Aug 23, 2007 | Coby DVD-283 DVD Player
WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Aug 02, 2006 | Coby DVD-224 DVD Player
Televison & Video Logo
63 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
