Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ice maker not dumping out ice
Whirlpool Model GD5RHAXNQ00 Side by Side, There is ice in the ice maker but it will not dump it into storage bin. On/Off Switch is on, infrared switch appears to be working (red light blinks next to On/Off Switch, when infrared control is pushed closed the red light stays lit). Water dispenser is working. Wanted to remove ice making unit but Use & Care Guide booklet is useless and doesn't give instructions on how-to. Don't want to break anything. Will continue to search internet for directions on this while waiting for reply here. Thanks
  • 612 Answers
Your ice maker has a heater on the bottom of the tray that heats up the tray enough to allow the ice to release from the tray. It's energized when the ice maker advances to a point that the fingers touch the ice. There is a micro switch inside the head that turns the heater on. You will need to remove the ice maker to repair it. You should have two 1/4" bolt on the top and one or two on the bottom ( Don't know which model you have). If I knew the model number you have I could tell you what you would be looking at after you pull the front off the head of the ice maker. There are two major types. One you can test while still mounted and the other you can advance only. Once you have taken the unit out, you can ohm the heater. If it's good, your problem will be the micro switch. It cost around $8.00. If the heater is bad, you can replace it, but It's hard to do and I think you will find it will be better to replace the ice maker. I have replace a few and around half didn't work afterwords due to them breaking while installing them. You have to bend the metal over the element ot install and it's tricky to do this without breaking the element. I Hope this helps. Please rate my solution. Thanks
Posted on Sep 05, 2009
Testimonial: "Thanks for heading me in what appears to be the right direction. Will"
    President:
  • 1,126 Answers
Http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=GD5RHAXNQ00&siteCd=WHRCOM
Ice maker exploded view is on page 19, and parts are listed on page 2 of the parts manual. I agree, the care and use guide to be useless.
http://www.appliance411.com/
Have you tried thi site? Hope this helps and good luck.
Why does Whirlpool G16FARXXF05 refrigerator not dump the ice?
as I remember them there is a small heater that warms the bottom of the ice maker so the ice is loosened a little perhaps your timer or heater has gone kaput
Jul 20, 2015 | Whirlpool Refrigerators
Ice maker will not dump the ice.
if the auger is not turning the ice will not dump
Apr 08, 2014 | Whirlpool 2198597 Ice Maker
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Not making ice
What is the model number of your unit?
Nov 30, 2012 | Whirlpool Gold White-on-White 21.9 cu. ft....
Maytag freezer wont produce ice
You have two sides to the water control valve. One side is for the water coming from fountain and the second side is to refill your ice maker after each cycle of dumping ice into the ice bin. The freezer should be a 5 degrees or below for the ice maker to function properly. If the ice maker is empty then fill with tap water up to top edge of the ice maker and allow to freeze. If after the water freezes and dumps the ice into the ice bin the ice maker does not refill I would recommend replacing part=> 67006009 Dual Water Control Valve
or here=> 67006009 Dual Water Control Valve
If the ice maker has old ice inside and does not want to dump itself it will be considered defective and the ice maker core moduel will need be replaced=> W10190972 Ice Maker Assembly
Whirlpool Ice Maker Troubleshooting
I will be here should you have any questions, Thank You, Sea Breeze
Please Rate this Solution
Feb 08, 2012 | Refrigerators
The ice cube tray in the automatic ice maker overfills with water. After the ice dumps, the water for the refill overflows the tray and some goes in the dump bin.
Good day,
Sounds like a bad water valve located in the rear bottom of the machine. (not shutting down properly).
Solution is to replace the valve.
In extremely rare cases it can be a faulty ice maker.
The ice maker sends power to the water valve for 7 seconds on each cycle. If the circuit board in the ice maker malfunctions, it could cause this problem.
But again, very rare.
Dec 04, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Won't dump ice
ice maker defost heater o/circuit,shuts off the ice maker will require a new ice maker
Jul 25, 2009 | Whirlpool ED2FHEXN Side by Side...
Cubes won't dump into the storage bin
In photo below you can see the heating element that comes on moments before the ice maker drops the ice. If not working then the icemaker will struggle to unload. You need to unplug the refrigerator and then unpluge the ice maker and remove it to test these parts. Test with a multi meter or ohm meter. Test the 2 connections next to the number #26. Hope this helps, Sea Breeze
May 21, 2009 | Whirlpool GS5SHAXN Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
546 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
