Question about New World E70DOa Electric Double Oven
How to set the clock
Set the clock and timer
0 characters
1 Points
How do I set the clock/timer to make the oven work?
does it have a clock button , if so press it then use the +or- buttons to set the time then press clock again
Dec 06, 2015 | Ovens
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Can not re set time
Are you trying to reset the timer or the Clock? It's a bit different on each stove, but usually if it's the clock, you press the Clock button TWICE, the time will then begin to flash on and off. then press the + or - sign to increase or decrease the time. When you have gotten to the time you desire, PRESS the Clock button ONCE more. The time will be set, & then you should be all set :).
If it's the KITCHEN TIMER, Press the Kitchen Timer button ONCE, the timer will start flashing. It will usually flash all 0000's. Press the + sign to add minutes, then Press the Timer Button ONCE again, it will be set to the amount of time you added and will beep once the time runs out.
Disclaimer: This instruction is primarily for the General Electric Stove. If you state your specific model, I could be more specific.
Nov 12, 2010 | Ovens
Power went off now oven wont work. The timer keeps flashing
If you look at the timer control you will see a button that is used to set the clock. most likely the oven will not operate until the time is set. Press the clock button, set the time and either press start or the clock button again.
Aug 29, 2010 | Ovens
How to set oven timer on a GE electric stove
that is not a problem. I copied the instructions straight from the manual which you can also review by clicking here.
Using the clock and timer.
To Set the Clock The clock must be set to the correct time of day for the automatic oven timing functions to work properly. The time of day cannot be changed during a timed baking or self-cleaning cycle. Press the CLOCK pad. Press the HOUR and MIN + or – pads to set the time of day. Press the START pad. Make sure the clock is set to the correct time of day. To Set the Timer Press the KITCHEN TIMER ON/OFF pad. Press the HOUR and MIN + or – pads until the amount of time you want shows in the display. The maximum time you can enter in minutes is 59. Cooking times more than 59 minutes should be changed to hours and minutes. For example, enter 90 minutes as 1 hour, 30 minutes. If you make a mistake, press KITCHEN TIMER ON/OFF and begin again. Press the START pad. After pressing the START pad, SET disappears; this tells you the time is counting down, although the display does not change until one minute has passed. Seconds will not be shown in the display until the last minute is counting down. When the timer reaches :00, the control will beep 3 times followed by one beep every 6 seconds until the KITCHEN TIMER ON/OFF pad is pressed. The 6-second tone can be canceled by following the steps in the Special features of your oven control section under Tones at the End of a Timed Cycle. The timer is a minute timer only. The timer does not control oven operations. The maximum setting on the timer is 9 hours and 59 minutes. To Reset the Timer If the display is still showing the time remaining, you may change it by pressing the KITCHEN TIMER ON/OFF pad, then press the HOUR and MIN + or – pads until the time you want appears in the display. If the remaining time is not in the display (clock, delay start or cooking time are in the display), recall the remaining time by pressing the KITCHEN TIMER ON/OFF pad and then pressing the HOUR and MIN + or – pads to enter the new time you want. To Cancel the Timer Press KITCHEN TIMER ON/OFF pad twice.
If you need further assistance follow up with a comment and please let me know and i will be glad to assist you further. Thanks, Midwest-tek
Aug 28, 2010 | GE JTP20 Electric Single Oven
I have a 40 year old Tappan electric wall oven. It has an analog clock with 3 timers on it (2 small timer...stop and start and a large timer with 3 hands on it). Which position do the timers need to be for...
I have one of these too. the TOP small clock should be set to the time you want the oven to start and the BOTTOM small clock should be set to the time you want it to turn off. Be sure to set the oven settings to what you want and the correct temperature.
Try testing it first just to see if it works correctly. It's also important to make sure the other large clock on the oven is set correctly.
May 01, 2010 | Ovens
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
The timer clock has gone off.
to stop the clock area from flashing and for it to display time, the time must be set.
Apr 09, 2009 | Ovens
How to set clock and timer
reset clock, set clock on the right time by clicking + & -
Dec 30, 2007 | Miele Novotronic H350-2B Electric Single...
Hi this is propably too late now but we moved in to our new house six months ago and have a Zanussi ZBF 360 oven, and had no idea how to set the timer / clock. After fiddling around with the oven clock for the last 6 months i managed to set the clock. It shouldn't be much different to the one you have. Hope this helps you and others in the future.
Click the middle button until the little red things on the screen moved round to the clock symbol, then press + or - to get to the correct time, once you have done this it will flash for a few seconds then it will stop flashing and the clock is set. The same goes for the timer to set it when you want to cook something for a period of time eg: ten mins.
As for getting the oven timer to turn it's self on and off I am still messing with it and when i have mastered it I will let people know.
May 07, 2007 | Zanussi ZBF660 Electric Single Oven
New World E70DOa Electric Double Oven Logo
Top New World Ovens Experts
Dan Webster
Dan Webster
Are you a New World Oven Expert? Answer questions, earn points and help others
