Question about Whirlpool Washing Machines
I have an Estate Heavy-Duty Washing Machine by Whirlpool. It's about 2½ years old and I wash 2 medium to large loads per week. I've taken good care of it and it's been an excellent machine until recently. Except for the spin cycle, everything works normally. When it gets to the spin cycle, it starts jumping and bouncing, like it would with a large unbalanced load, and will take off across the basement floor as far as the cord will allow. I've tried redistributing the load, removing half of the clothes, even holding it still with my body weight, which actually works best, other than leaving too much water in the clothes at the end of the cycle. I get the feeling that maybe it's a belt or something similar. Does anyone have any ideas or suggestions? Thanks! (PS - the warranty has expired.)
  • 612 Answers
There are three springs under the transmission that help balance the machine. The top ring on the outer tub is filled with water, also to help keep machine in balance. There are three pads the carriage rides on that also has the same function. I would check these plus make sure the machine is level with all four corner feet touching the floor. If all these are correct, the machine will stay balanced. You can go to www.partselect.com enter your model number. The site will give you a parts blowup that will give you an ideal where these parts are located. You can see and replace the springs by tilting machine back.
Please rate this solution
Posted on Sep 05, 2009
Whirlpool ultimate care extra large, about 10 years old. when the machine is in spin cycle, it throws the circuit breaker. It started with a heavy load, but now it seems to do it all the time. It started...
Water leaking from tub seal into motor possibly? Try doing spin with dry newspaper under the machine and check for leaks. Could also possibly be water heater element loose or breaking down - leaks from drain hose or water pump body into windings? Dry news paper test should highlight where leaks are coming from.
!0 years old is ancient for a machine and you might consider replacement rather than a repair which will only be throwing good money after bad. Do you drive a 10 year old car? if you do, you expect repair bills to mount up! same with washer. I bet it doesn't owe you much!
Jan 03, 2018 | Whirlpool LSW9700P Top Load Washer
Ttt
Is this machine a front loader,I bet you have a clogged drain pump.
Try this with no cloths in unit put Draino-Max Gel. Add about 1/3 of bottle and let it stay in washer about 2-3 hrs. now shut door and start machine put on heavy-duty hot-water.this may take a few times,but this well take care of dog hair ,strings and also sanitize machine after. After machine starts to run better,bleach machine every other week.
Jul 26, 2010 | Whirlpool Washing Machines
Machine clogged and rust and stink
to help clean the unit, do a large load of whites, extra bleach, extra-super-heavy-duty wash, hot wash and hot rinse. many small loads sometimes cause the unit to "smell up"
Sep 04, 2009 | LG WM2077CW XL Front Load Stackable Washer...
Washing machine makes clothes get black stains Kenmore front loading Heavy Duty 2 way tumble machine.
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 02, 2009 | Kenmore Elite 45986 Front Load Washer
Turn off ALARM - Whirlpool washer
This sounds like the imbalanced load alarm. This can occur with large heavy loads like blankets, bedding, lots of diapers (cloth), jeans etc. The best solution is to wash lighter loads and not overload the machine. If overloading continues, the machine could be damaged.
Apr 11, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Mar 27, 2009 | GE WBSR3140DW Top Load Washer
Shows "LE" in display.
Machine has a bad motor or "stator" on this machine. It is a direct drive winding on the back of the machine. Remove the back panel, the one bolt removes the rotor then you will see the stator winding, replace it and your good to go.
May 11, 2008 | Washing Machines
Open Questions:
Washing Machines Logo
110 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
