Question about Home
I have a 1928 home with a speakman mixometer, the water constantly leaks from the shower handle, also the cold water faucet leaks when it is turned on only. Thanks for your support
  • 123 Answers
Http://www.plumbingspecialties.com/downloads/PPfistertoSpeak.pdf......this website offers several blow up diagrams of the mixometer. More than likely it is the packing and all you have to do is tighten the packing nut. You can do this by removing the handle and tightening the nut below it. You may have to remove the escuteon to gain access but the blow up should help you. If you have any questions just ask.
Thx
Ken
Posted on Sep 08, 2009
How do I determine the model number of Speakman Shower faucet?
Before replacing parts, check the diverter for corrosion that prevents free operation.
Jun 19, 2014 | Speakman Home
When water is turned on, water leaks from faucet and hot/cold water handles but when diverter is engaged the shower works fine with no leaking from the handles or faucet. I have a three handle system. Any...
Write down the type and model of faucet you have. Most hardware stores have rebuild kits for faucets.( washers, rubber o-rings and or gaskets) You will have to turn your water off and do some minor repairs.
The kits come with step by step directions.
Dec 13, 2012 | Home
Speakman mixometer shower leak
If your shower get leaked then you should consult with a professional as he can fix this problem very easily.
Feb 21, 2012 | Home
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
Leaking water from head when turned off
It is normal for the water to trickle for a little time while the water drains from the shower head. If this continues you will need to repair the shower faucet
Jun 25, 2010 | Speakman S-2252-2 Anystream 6 Jet Dual...
Moen kitchen faucet. I changed the cartridge but
Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
Water comes out the shower head without the faucet lever being engaged
the whole faucet is bad it has an internal leak replace the whole thing
Jul 03, 2009 | Home
Speakman shower faucet washer replacement
there may be two nuts,one for the stem and one for the stem barrel.if not then the stem does just screw out,may just have a build up of something on it,try and working it back and forth to try and break it loose,careful not to damage anything.
May 23, 2009 | Plumbing
Home Logo
995 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
