Question about LG KM900 Arena Cell Phone
A similar problem - LG Arena Battery Drains Too Fast
I purchased an LG Arena just about a month ago. I had to charge it every day. I thought maybe I used it frequently for the initial some days coz of eagerness and xcitement, this was normal. But this happens even after a month. When I dont use the fone (dont even attend a call) at all for 2 days, charge stays. Otherwise, witout playing songs or videos and only by moving thru various options, how does it run out so fast? As per specs, it has 40 hours of playback. But when i complete playing about 10 tracks, the first grid is empty. Wil it be a problem with the battery or LG arena on the whole has this prob?
Also, I'd like to know if touch fones, bcos of their display area and interface, uses lot of power. I am not able to figure out since I havn't used any other touch mobs. Also, what way would u suggest to chek real battery life per charge (ie, after fully charging, the no. of hours it plays audio/video, or the no. of hours on call, or hours it lasts when browsing thru the fone and etc.) Which way do i chek my battery is okay.
Note: I've turned 'Auto Brightness' OFF and Brightness level to 60%.
Thanks in advance.
2004 Yukon XL 1500, with the car off the radio circuit draws alot of current and drains my new battery in 2-3 days. Also maybe seprate issue my oil presure gage does not reset to zero.
With the problem with the battery draining, Get the chargeing system check out, End tell them all so to check for a short, As for the problem with the oil gauge change the oil pressure sending unit,
Nov 26, 2012 | GMC Yukon Cars & Trucks
LG Arena screen freezes on LG loading screen and won't turn on
charge ur mobile fully and switch it on. it will take a long time to load. take patience and wait for and hour or two. then when u gain access to the memory, remember what was the last application or file u used. if that it was big or untrustworthy delete it.
Feb 16, 2010 | LG KM900 Arena Cell Phone
Battery drains very fast
First, before we proffer any solution, we need to know the problem.
Before the battery drains, does the phone gets hot in any way?
If your phone gets hot, then maybe the problem is from the phone board.
But if your phone does not gets hot before battery drains, then it is obvious that the fault is from your phone battery.
The solution therefore is for you to change your battery to an original one. The same problem might persist if you don't purchase a good battery, please take note.
I wish you the best.
Dec 08, 2009 | Nokia 5310 Cellular Phone
LG Model UX8360 cell phones batteries drain to quickly
the batterys are defective maybe or the devices , go into verizon they are usually very helpfull and will replace them
Oct 02, 2009 | LG Lotus Cell Phone
The battery seems to drain off very fast. have to charge everyday even though seldom used
because its touch scrreen it uses aalot of battery.....if you had the phone for a while and this problem recently started happening, buy a new battery...just charge it before you go to sleppp....hope it helps
Sep 05, 2009 | LG KM900 Arena Cell Phone
A968 battery problem
This is a very commen with Chinese stuff. The looks are perfect, but the quality is exactly otherwise. Sorry to hear of your prob. See if you can find a standard battery of a good brand with the same specifications. Its better to buy a good and expensive battery than go in for three low quality ones. Give it a thought.
Aug 05, 2009 | Cell Phones
LG VX8550 will not power up
you should take the phone to a mobile service center and have them try to fix the phone for you....your mainboard may have to much corrosion on the mainboard.
Nov 30, 2008 | LG CHOCOLATE VX8500 Cellular Phone
DS Battery Problem
it's your charging port, it's not charging the battery
Jul 16, 2008 | Nintendo DS Console
LG KM900 Arena  Cell Phone Logo
1,032 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
