Question about Roper REX4634KQ Electric Dryer
My dryer will spin but will not heat up.
My dryer spins but does not heat up and now it does not shut off with the timer.
  • 612 Answers
You have a bad element. This is the only thing that is in the heating system that when it goes out, the dryer will continue to run.
Please rate solution
Posted on Sep 05, 2009
How do I stop my dryer from spinning?
Could be bad timer but check the timer knob first have seen them crack so they are not pointing in the right direction
Dec 09, 2015 | Dryers
Dryer wont stop buzzing
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
Will not heat
Most common issue with gas dryer is either the ignitor, valve solonoid or high limit thermostat. The timer will not advance with no heat,
Oct 27, 2009 | Dryers
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
Jul 07, 2009 | GE DVL223GB Gas Dryer
Dryer spins, no heat, timer does not seem to function
Your timer mechanism is damaged. this will happen if the timer motor is faulty. it will not advance the cycle correctly. replace the timer/control asap. Please rate and have a great weekend:)
Jun 05, 2009 | Hotpoint Dryers
Dryer will spin but won't heat up
Hi
Things that could stop a electric dryer from heating:
  • house fuse or breaker ( needs two of them )
  • heating element, burnt wire
  • thermostat(s), thermal fuse ( not all models ),
  • motor heat switch, timer, selector switch,
  • burnt power cord/plug.
You can check these things using an ohmmeter/multimeter from here.
Things that could stop a gas dryer from heating:
  • glow bar igniter,
  • thermal fuse ( not all models ),
  • coils on the gas valve, gas valve, thermostats,
  • motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 20, 2009 | Whirlpool Dryers
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
With timer on dryer stops spinning when door is open but heat won't shut off
The element might be shorted and grounding itself to the element housing.
Could also be the centrifugal switch in the motor or the contacts in the timer.
Feb 18, 2009 | Kenmore 62802 Electric Dryer
Roper REX4634KQ Electric Dryer Logo
155 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Roper Dryer Expert? Answer questions, earn points and help others
