Question about Acer (91.37H37.001) Internal DVD Drive
Hi my computer has stopped recognising dvd it is still working fine with cd's iv'e tried a lens cleaner and that has made no difference
  • marco_7 Sep 05, 2009
    hi, if i replace the dvd drive do you recomend one that i should use it is a desktop acer t-180 is it simple to change the drive i've never changed anything on a pc before
  • Acer Master
  • 13,433 Answers
is this a desktop computer? if it is, you can replace the DVD drive to a new one, they cost around 20-30 usd at www.newegg.com
If the current drive or computer is a laptop or is in warranty, contact your dealer for repair.
If you are outside of warranty you can clean the laser lens yourself with a q-tip and alcohol.
Here is a video on the cleaning, the cleaning is done the same way on all optical drives.
This method is better compared to the DVD lens cleaner.
If the problem remains after being cleaned properly, the drive is most likely failing, due to the cheap price its best to replace it with a new one.
Posted on Sep 05, 2009
  • Ekse Sep 05, 2009
    Hi
    Here is a video on how to replace a DVD drive in a DELL computer, I didn't find a acer video.
    But basically.
    1. unplug the computer from all cables
    2. open the side panel of the computer to get inside
    3. unscrew the dvd drive and disconnect the connectors from its back.
    4. you may have to open the other side of the case aswell to unscrew 2 or more screws from the other side of the drive
    5. pull out the drive after it is free
    6. purchase a drive with similiar connectors, if you see 40 pins on the drive back, its a IDE drive, if it has 2 smaller flat connectors, its a SATA drive.
    7. after having purchased the new drive, push it in the case, connect the connectors as they where on the old one.
    8. screw in the drive from both sides
    8.b. - at this point you can also plug in the computer and test that the drive is working.
    9. close the case
    10. connect the cables and test your computer.
    Now here is the DELL video on how its done.
My computer has stopped recognising audio cds - I get the following message Windows Media Player cannot find the file. If you are trying to play, burn, or sync an item that is in your library, the item...
If your computer has a DVD rom or writer then this problem usually occurs. DVD roms or writers are very unreliable when it comes to reading CD's after some time of use the DVD roms do not read CD's but will read DVDs and then if it is a writer it will stop writing all will write and stop before finalizing. This problem is caused by the lens assembly which misaligns after a long time of use or the lens assembly itself no longer focusing correctly. However if you have a CD rom or CD writer then you must start by cleaning it. The cleaning of CD roms can be easy or slightly complicated if the lens is covered with residue that is moisture related. That is the lens could have accumulated dirt mixed with moisture then dried up. This would need manual cleaning using a cotton bud with some of the liquid that comes with the Disc cleaners you clean the lens until it is squeaky clean. Do this being careful not to scratch. But first try cleaning with the disc cleaner. If it doesn't work then do the manual way. If all this does not work then change the lens assembly or buy a new DVD rom or writer.
Oct 22, 2011 | Computers & Internet
My computer does not recognise the disc it keeps on saying i must put in a disc
Please check both of your CD type and CD writer. You may have CD rom with DVD disc cause your computer is unable read the this. If everything is OK, you may have optical lens problem on computer. Please clean the lens with lens cleaner. If problem persist, replace your lens with new one.
Regards, Jay
Mar 19, 2011 | Canon DC210 DVD Camcorder
SecurDisc HL-DT-ST DVD -RAM GSA-H55N ATA DeviceDevice not recogni
Your dvd lens needs to be clean from dust. Clean the lens of the drive by using a cd/dvd lens cleaner. You can buy it at any computer stores. Reconnect the drive from your computer.
Dec 19, 2009 | Computers & Internet
My dvd player on my laptop used 2 work but now it suddenly stopped working and i cant get it to work it doesn't seem to recognise that there is a dvd in my computer. i have tried playing it in every single...
You may use any CD/DVD drive lens cleaner to clean the lens as it may be that the lens in the CD/DVD drive is not able to recognize the disc due to accumulation of dust. Next, you may perform System Restore to the time when the CD/DVD drive operated normally. If the issue persists then you may try reinstalling the Operating System.
If the issue persists even after performing all the above mentioned steps then the issue may be Hardware related and the CD/DVD drive may require service.
Jun 06, 2009 | Computers & Internet
Cd drive not working
i have personally faced this issue before, sometimes it does happen that CD/DVD ROM's go bonkers in reading discs, mostly bcoz either the CD/DVD is damaged (scratched etc.) or the lens has gotten dirty.if it is a lens issue use a lens cleaner (lots r avail. in the mrkt) and try again if not im afraid ur CD/DVD is concked
Mar 23, 2009 | Compaq Presario sr1403wm AMD Sempron 3000+...
DEll 2400 - cd-dvd drive stopped working
try to clean the lens using lens cleaner...
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
My Lite-On Internal Dual DVD does not recognise any CD. It keeps asking to insert a disc in my destination drive. It does however, recognise a DVD. My checks conclude that it's the best available...
Try a 'quickiee', While the power is OFF! disconnect the cables or cable to the duel dvd,[IDE (long 26 pin) & power] turn on computer, goto to control panel >system icon>system properties>Hardware>device manager>DVD\CD-rom Drives. NOTE:: you should see ONE instance of your CD\DVD drive, REMOVE it.Turn computer off., RECONNECT the power & ide cables to the dvd. Turn power on, the computer SHOULD see your hardware, if it don't, It could be semi-damaged,or internattance [sometimes is, sometimes not working]
Apr 20, 2008 | Computers & Internet
Dvd rewriter
may be some dust in ur dvd drive man ...just try to clean u r lens  by a lens cleaner disk..which is ablable in market with a liquid...
best regards & best of luck..
even u can mail me at my mailing add- sigma_shiva1@yahoo.co.in
Oct 12, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Screen displays "Error data" when trying to play a DVD
My understanding is that the DVD player uses a different lens to the CD player. So the DVD lens might need cleaning. A CD lens cleaner would not correct the DVD side.
Oct 04, 2017 | GoVideo DP8240 Portable DVD Player with...
Acer (91.37H37.001) Internal DVD Drive Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
