Question about Neovo E-17DA (Black) 17" LCD Monitor
Monitor switches off!
Hi! My english is not very good, but i can try to explain my problem. My monitor E-17DA turns off.I switch off adapter, after 2 minutes put it in back, then monitor turns on again. I think it's adapter fault, i buy new adapter, but it's doesn't help. Monitor switched off always when, I do something active - watch films, play games or press nvidia button. It's 100% monitors fault, because I try videocard on else computer and it's works!
    Top Expert:
  • Neovo Master
  • 43,904 Answers
An internal circuit may be failing.
Posted on Jul 03, 2017
4 Suggested Answers
SOURCE: The monitor won't go on after holding the power button
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Posted on Apr 17, 2010
  • 293 Answers
SOURCE: Neovo F-417 monitor keeps switching
The power supply of your monitor have problem.Leak capacitor at ur power supply need for replacement
Posted on Oct 05, 2010
budmrtn
  • 11361 Answers
SOURCE: Hi there i have some
Look for bad caps (6) on the power supply/inverter board first.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 09, 2011
I have a perfect second hand Neovo 17DA monitor, but I don't have the installation disk so that I can take advantage of the build in speakers inside the monitor. What can I do about this? I've tried to...
Well, a driver is not required to use the internal speakers! You just have to plug the OUTPUT from your computer sound card into the input jack on the rear of the monitor. For this, of course, you will require a suitable lead (or cable) with stereo jack plugs on each end. The sound output from the speakers is only 1 watt so don't expect wonders..but it does have a headphone socket so it would make a convenient point for you to plug your headphones to, but of course, you've got to feed the output from your sound card to the monitor first. Regards, nicam49
p.s. please don't forget to vote :-)
Feb 01, 2011 | Neovo E-17Da Monitor
Notebook will not turn on
There are few steps you have to try since this could happen due to any reason.
Check which one is possible for you to try out of these steps below.
1. Can you do a chip level repairing OR
2) Try a known good adapter. OR
3) Remove the battery and adapter. Press and hold on the power button for one minute and then release it. Now connect the adapter and switch on the system.
Hope this fix the issue. Do let us know if the issue is resolve or if not resolved.
Nov 10, 2010 | Acer Aspire One PC Notebook
I have acer 3050 is switch on but no display
Hi! Try to check if there is a hotkey to turn on/off lcd display. If none, try to power drain the machine by unplugging ac adapter and removing the battery.Press and hold the power button for 10 secs and then after that put the battery back and plug in ac adapter.Press power button and then check if you will see anything on the screen,if still the same then try to connect the laptop to a external monitor and then press FN+F5 to switch display to external monitor, if you see something on the ext monitor it means you are dealing with a faulty lcd on your laptop...Hope this helps...
May 20, 2010 | Acer Aspire 3050-1733 Notebook
Power button goes on and off, and no response
Power drain the computer by removing the battery and power adapter and press the power button for 1 minute. then insert back in the battery also the adapter to your computer and start the computer.
If the solution won't work
, try using flash light on the monitor,if you can see anything on your screen, possible backlight is the problem, however to isolate also the issue you may use an external monitor to check if you can have a video using other monitor and if not? you may contact the tech support of your system for possible mechanical failure.
hope it helps.
please post positive comments and rate.
May 13, 2010 | Acer Aspire 5520-5908 Notebook
Acer Monitor Not Staying On
It sounds like there's a problem with the monitor itself. It may be that the lamp in the computer is dying, which would explain why it keeps going out. Other possibility is that the monitor isn't receiving power properly either through the cable or inside the monitor itself.
If your're not the kind of person who wouldn't mind opening the monitor up and hopping in there, then I recommend you take it somewhere it can be diagnosed like Best Buy.
Hope I helped :)
Nov 28, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
I can't turn on my la[ptop
Laptop is dead. How to troubleshoot the problem.
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Nov 08, 2009 | Acer Aspire One PC Notebook
Push power button and it wont turn on on my
These tips may or may not help depending on the type, if any damage done to your system....
Nov 07, 2009 | HP Compaq Presario V2000 Notebook
My hp compaq nc6400 doesn't turn on. the green
Oct 12, 2009 | HP Compaq nc6400 Notebook
My acer travel mate 5710 just blipped and closed down. NOw will not even switch on. any advice how to fix? The green power light does show for one half second when I press the button but does not function...
Oct 11, 2009 | Computers & Internet
Monitor goes blank after about 30 minutes. Then you can shut it off and turn it back on and it will work for another 30 minutes or so. What could cause this?
check your power settings (run>control>power options>change plan settings>advanced options>display)
you will see the setting for your monitor to power off
it should be set to 2 hrs or more if you plan on watching a movie or keeping the monitor on without having to frequently touch the keyboard or mouse.
turning adaptive display on may affect your situation as well. try switching it on.
This should do the trick for you. If not you may have an issue with either your video card or your monitors power supply.
(if the light stays on on the monitor when it goes blank but it doesnt repsond to the mouse or the keyboard, its a setting on your system or the hardware itself)
Good Luck!!
Mar 11, 2009 | Computers & Internet
Neovo E-17DA (Black) 17" LCD Monitor Logo
42 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
