Question about Corel Paint Shop Pro Photo X2 Full Version for PC (PSPPX2ENPC)
Paint shop pro x2 ultimate upgrade wont rum on Vista Home
I bought this version of paint shop pro and when i set it up using the CD it worked ok. The next time i started PC the program would not start. I tried the patch from Corel website and got the error message "CAN NOT FIND PAINT SHOP PRO" What really annoys me is that it actually mentioned Vista as being a program which had been tested as suitable for PSP. I have deleted, reinstalled, repaired, Googled the problem, Any genius out there.
I havent actually solved the problem but I did get PaingShopProUltimate to run by starting up in "SAFE MODE" I tried it out and everything seemed to work ok. but of course this is not very convenient.
Posted on Sep 07, 2009
Downloading Corel Paintshop photo x2 ultimate
if you know how to work torrents, heres the link for the download
http://kat.ph/usearch/Corel%20Paintshop%20photo%20x2%20ultimate/
Oct 19, 2012 | Corel Paint Shop Pro Photo X2 Ultimate
When I load paint shoppro x2 it closes worked fine
try to clean your registry or try to reinstall the software it may have some corrupted files
May 06, 2010 | Corel Paint Shop Pro Photo X2 Full Version...
Trying to install on new computer
On CD or back of packaging. If you registered it, e-mail or call the company. They will accomodate you.
Apr 20, 2010 | Corel Paint Shop Pro Photo X2
Failure to Start
System Requirements
  • Windows Vista® or Windows® XP, with latest service packs installed
  • 512 MB RAM (768 MB recommended)
  • 768 MB RAM required if using Windows Vista
  • 1 GHz processor (2 GHz recommended)
  • 1.5 GB hard disk space
  • 24-bit color display, 1024x768 resolution
  • Microsoft DirectX® 9.0c or higher (included in Windows Vista and XP)
please check every thing is there in your system and check........
Dec 17, 2009 | Corel Paint Shop Pro Photo X2 Ultimate...
My Paint Shop Pro Photo X2 suddenly started to fail to start completely today. I tried updating my drivers, scanned for viruses, and even bought an upgrade to the latest version. When I start the...
I have had the same issue on my Vista machine.
I've clicked on it until it too has said Program Not Responding. Depending on the amount of resources being used (how many other programs you have open), it has usually come to life after waiting a minute or two. If you have a lot of other stuff running, close everything you don't need to run while you're working in PSP.
If you don't have 3GB of RAM installed, consider doing so.
I have had to reinstall PSP once as well. Nothing I did helped. Once I uninstalled it and reinstalled it, it worked again.
Sep 22, 2009 | Corel Paint Shop Pro Photo X2 Full Version...
Paint Shop Pro will not respond AT ALL!
not a hardware or major software prob, but see that if any other software have the same prob...?
you will have to scan your pc through a best virus cleaner or remover. then will have to install a fresh O.S, and then install Paint Shop Pro X2, it will run faster then before..
take care
shafky
Jun 20, 2009 | Corel Paint Shop Pro® X Full Version for...
PSP X2 Ultimate Not Responding
Hi, I got a fabulous response from Corel and it fixed my same problem! Here is what they sent me. The first step did not work alone, but may have been necessary for the second step to work properly. Good luck!
We are working on a permanent fix for this issue. Use the following workaround to allow launching of Paint Shop Pro Photo versions X1 or X2:
Delete or rename the Paint Shop Pro Photo XI database file: ImageDB.db.
Database file locations
On Windows XP: C:\Documents and Settings\<username>\Application Data\Corel On Windows Vista: C:\Users\<username>/AppData/Roaming/Corel Here are instructions to easily delete the ImageDB.db file.
  1. On XP systems, Go to Start | Run. On Vista systems, Click on Start button and then highlight the "Start Search" field.
  2. Type %appdata% and click Ok (or push Enter on keyboard on Vista systems).
  3. Double-click on the Corel folder.
  4. Delete* the ImageDB.db file and then close this window.
You should now be able to successfully run Paint Shop Pro Photo. *NOTE: if you receive a message that the file cannot be deleted or is in use, Restart the computer, then immediately try deleting the file. It should delete fine after a restart.
If Paint Shop Pro Photo X2 still hangs or is slow responding, try the following: Do the following to delete the Paint Shop Pro Photo X2 Database files. The program will recreate the files upon next launch. First Close Paint Shop Pro Photo X2 if is it running.
  1. Go to Start | Run, Type %temp% and click Ok. (on Vista, click Start button, then highlight Start Search. Type %temp% and then push enter on keyboard)
  2. On the Windows® Explorer Tool bar, Click the Up Folder button. The Up Folder button looks like a folder with a green arrow pointing up. If you don’t see it, Click View | Go to | Up one level. (On Vista, click Organize | Layout | Menu bar. Once displayed, go to View | Go to | Up one level).
  3. Double click on the Application data folder. NOTE: The Application Data folder is a hidden folder. Make sure you have enabled viewing of Hidden files and folders to see this folder. We have included instructions* below for enabling this view.
  4. Double-click on the Corel folder.
  5. Delete all content in the Corel Folder and then close this window
  6. Try running Paint Shop Pro Photo X2 again and note how it functions.
* To enable viewing hidden files and folders do the following:
  1. Go to Tools | Folder Options.
  2. Click on View tab.
  3. In the large white area marked Advanced settings, check the "Show Hidden Files and folders" radio button.
  4. Click OK to accept this setting. You should now see the Application data folder as described above.
Dec 02, 2008 | Corel Paint Shop Pro Photo X2 Full Version...
Every time I run paint shop pro X2 it freezes right on start up. It freezes in the same spot every single time, which is when it says "loading Cache files" or something rather. I have no i dea...
Did you install the software update for the program. Also remove the software and delete the Paint Shop Pro folder off your HDD and download www.ccleaner.com and clean the registry with that software. Now reboot and re-install Paint Shop Pro.
Jul 23, 2008 | Microsoft Windows Vista Ultimate Edition
Corel Paint Shop Pro Photo X2 Full Version for PC (PSPPX2ENPC) Logo
194 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
