Question about Home
My Triton T90 si shower is now broken. i want to replace it with the T90XR, the model that has taken over from the T90si. the T90XR is available in 8.5 and 9.5 kw versions. i would like the 9.5kw, but the electrician has said i can only have that one if the T90si was also 9.5kw because otherwise he will have to change the cable. i dont know how to tell whether my T90si was 8.5 or 9.5kw. have looked all over it but cant find that info.. any ideas?
  • 171 Answers
SOURCE: shower pressure.
Hi chicken69
I'm Harvey the Master Plumber.
You want to know why the presssure on your triton t80i shower has dropped by half?
It is very possible that some debrie has come up in the water and is partially clogging the shower. For this you would have to turn the water off and dissassemble the parts clearing all the small passages, a bit of wire or paper clip works. Perhaps for a pro? If you like you may choose to utilize our Repair Directory.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
  • 659 Answers
SOURCE: Triton T90si electric shower temperature stuck on hot.
It sounds as though the valve is not closing and opening properly. I would have a proffesional come out to have a look. I could also be the control board not working correctly or a combination of both.
Posted on Mar 22, 2009
Monster80
  • 463 Answers
SOURCE: I have a triton T90si that wont heat yhe water
Check your heating elements..Turn up all the way and listen to each element..You'll hear the one not working..Or you can put your hand by each one and feel for the ones that the coolest.Thats the one thats bad...
Posted on Apr 03, 2009
mrhotandcold
  • 248 Answers
SOURCE: I have a triton T90xr the water is only luke warm
your incoming cold water pressure may have to be reduced if not by the main control valve a pressure reducing valve may have to be fitted
Posted on Sep 18, 2009
bloues
  • 56 Answers
SOURCE: triton shower t90si will not cool the water. water
hello :>
have a look at ur geyser and what tempreture the thermostat is set on. dont set it lower then 55 degrees or swams will grow in geyser and not higher then 65 degrees or the water will be scolding to qwite hot. plz rate, and let me know if u need more help. thermostat is located on geyser at power point. take off outside shell. put off power when worinking it hehe .U will see a devise with a pin conected with wiers that says most comenly 0-80 degrees. hope that solves it . let me know
Posted on Jul 08, 2010
Hi I got a plumber to replace a triton T90 si with a new z model it only has half the power of originalIDo you know why the problem could be?
You might want to compare the FLOW RATE of the old model with the flow rate of the z model. It seems that in order to "save water" the manufacturers are decreasing flow rates to save the planet...or to meet new regulations.
Good Luck.
Feb 12, 2015 | Home
My triton T90xr doesnt heat the water as well as it used to. At max the water is warm. No problem with pressure
The heater coil is tired. A replacement should be around £50 plus labour. So not cheap
Dec 09, 2014 | Home
I have a triton t90 shower it was workin grand until 2day when i was fillin my daughter paddling pool wit the tap in the garden that is connected to the hot water and it must of empty the tank as there was...
As per my view, you should immediately contact to a professional who can fix this shower problem very easily and quickly. You can also explore latest shower enclosures that are available at reasonable price.
May 26, 2012 | Home
Drip from shower head triton t90 when turned off
The shut off is not closing completely remove the handle and faucet assembly and take it to the hardware store to purchase the right washer, o-ring, or gasket. If there are two take them both so you don't have to do this again for the other side.
May 08, 2012 | Home
No water, hot or cold from Triton T90si. Any ideas please?
The Triton t90si is fed from the tank in your attic.This also feeds the cold water in your bathroom.If you still have cold water in the bathroom tap,it means that there is water in the attic tank so the problem is somewhere else.I believe there is a bleed valve on these showers so maybe that is the problem. It may also be that the pipes are clogged up with dirt or limescale.The water filter may need cleaning. Hope this will help with your thinking on the problem.
Dec 19, 2010 | Home
I have a triton T90xr the water is only luke warm i have changed the element and its still the same
Sep 16, 2009 | Shower Spa Home
Mar 22, 2009 | Home
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
MY Triton T90si electric shower continues to run when it is turned off. It is not fully on , but water keeps coming from the shower head evev when the electric isolation swithc has been turned off. Also it...
Most conventional showers have brass seats or rubber seats that can deteriorate over time. these will leak or dribble and not maintain your temp.. Rubber and brass seats are a fairly common and easy replacement. It sure beats trying to rip out a shower valve.
Jul 11, 2008 | Heating & Cooling
Home Logo
632 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
