Question about Lowrance Lms 525c Df 5" Df Sonar Chartplotter With External Antenna
Transducer for lowrence lms 525 df..
The lowrence trancduser th 50/200 dx will work on the lowrence lms 525 df gps sonar...??
5 Suggested Answers
  • 30 Answers
SOURCE: Lowrance Lms 522c 5" Screen Color Internal Gps And 200 Khz Sonar
If it is normal in deeper water, it is most likely just returning stuff in the water (debris, algae, anything floating around...choppy water can cause this). Try installing the latest updates from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If it doesn't help, adjusting the sensitivity or setting the SURFACE CLARITY option from the SONAR FEATURES menu to LOW, MEDIUM, or HIGH...whichever gives the best results.
Posted on Jul 14, 2009
  • 15 Answers
SOURCE: sonar inop at most times . onec in a while it works fine
(1) bad transducer. (2) bad ground from unit to battery. The cable next to the battery will have no effect.
Posted on Sep 05, 2009
SOURCE: I HAVE A LOWRANCE LMS-334C IGPS THTEE SONAR AND
I have this exact same problem with my unit. I just started doing this and I have no solution yet.
Posted on Sep 19, 2010
SOURCE: Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
Posted on Oct 31, 2010
Flashing screen
two things can be taking place 1 you have a bad key pad 2 you have a bad transducer(short in wire )
Oct 22, 2013 | Lowrance Lms 520c 5" Screen Color External...
My Transducer had broke and the sonar went out, then the transducer fell completely off and the unit itself will not power up. I checked the power ot the unit and i have 12 volts going to the unit. It...
All Lowrance systems have an in-line 3 Amp fuze. My guess is that when it broke and fell off the fuze shorted out. Look back the power sypply to the unit and you will find the in-line fuze. Replsacit with a new 3 Amp fuze and you should be up and running.
Aug 30, 2010 | Lowrance LMS-332C GPS Receiver
Best regards
Dan
May 07, 2010 | Lowrance Lms 520c 5" Screen Color External...
My LMS-522C keeps losing it's position on the GPS.
I'd suggest calling Lowrance.. Those guys are very helpful with step by step support... I just purchased a used boat with a 525c df on it and been troubleshooting some problems with it. Central time zone and best to call right when they open or turn on the phones at 8:15.
Mar 07, 2010 | Lowrance Lms 522c 5" Screen Color Internal...
Can i replace my 330c head unit with the 525c using the same wires antennae etc lowrance
Hope its not to late, before you replace (buy a new one) call Lowrance. I have a 525 and working through some problems and they advised me that they would replace my unit for $200 no questions asked. To answer your question not 100% positive but I did see a recent question where Lowrance lost his unit and sent him the 525 as a replacement and the connections were different. I believe my 525 has a 5 pin system with one notch. Does yours have a external gps module? The 525 does!
Mar 01, 2010 | Lowrance Lms 525c Df 5" Df Sonar...
Sonar inop at most times . onec in a while it works fine
Sep 05, 2009 | Lowrance Lms 522c Sonar Gps Chartplotter...
Unit not working properly
G'day
I had a similar problem of the unit turning off when the engine was started.
I simply replaced the battery as the one one boat was only registering about 11 amps. This unit requires amps to be over 12 to maintain the readings. This fixed my problem at least.
If you are not getting a reading on the transducer you may need to make some slight adjustment on the transducer itself. Is it installed correctly? There is a manaul with pictures detailing the exact method of installing the transducer. It is very important you get this right.
Good luck mate
Noel
Dec 02, 2008 | Lowrance LMS-527C DF iGPS GPS Receiver
Lowrance Lms 525c Df 5" Df Sonar Chartplotter With External Antenna Logo
274 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
