Question about HP DeskJet 5550 InkJet Printer
I get the msg below when I open my IBM T42 lap top connected to ho 5550 printer. The file'hpzrp306.dll'on hp cd is needed
    Scholar:
  • 191 Answers
To resolve this issue please disable the automatic start of HP Programs at start up. Please follow the instructions given below and verify the results.
  1. Click on ‘Windows Logo’ on your desktop.
  2. In SearchEdit Box type ‘msconfig’ without quotes.
  3. Go to Start up tab.
  4. Uncheck all the HP related items, except the entry which has the file as "HP Digital Imaging".
  5. Click on Apply to apply the changes.
  6. Restart the computer.
Posted on Sep 05, 2009
Hp 1402 fatal error and MSI.scan
Hi Ihan,
You are facing terrible problem with that error message.. However we can try to fix it. There are few methods you can do..
Solution 1.
  1. Insert the product software CD into the CD-ROM drive on the computer.
  2. Right-click Start and then click Explore . Windows Explorer opens.
  3. Locate and select the CD-ROM drive that contains the product software CD.
  4. Locate and double-click the Setup and then the Scan folders to open them.
  5. Double-click Data1.cab or Scan.cab to open the contents of that file.
Extract, rename, and save the filesLocate the following files, right-click them, select Extract , and save them to the Windows Desktop. Leave Windows Explorer open after extracting the files.
  • F1922_TWUNK_16.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the Desktop, right-click it and rename it to TWUNK_16.EXE .
  • F1923_TWUNK_32.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWUNK_32.EXE .
  • F1928_TWAIN.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN.DLL .
  • F1939_TWAIN_32.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN_32.DLL .
Then you have to copy these files to C:\windows\system32 folder ( this means overwrite the files ) and try to install the software. it should work.
for better understanding check the link below.
MSI.SCAN Solution
Solution 2.
you need to remove all the HP Printer entry from Add/remove or Programs and features under Control panel.
Then download the latest software from HP website by clicking on the link below.
HP PSC 1402 Printer Drivers
Regards,
Suhail
Oct 19, 2011 | Office Equipment & Supplies
ArcSoft Connect Notifier has stopped working
ArcSoft Connect Notifier has stopped... Solve Every time I switch on my lap-top,I get the same msg, "ArcCon.ac - Unable To Locate... (More) Every time I switch on my lap-top,I get the same msg, "ArcCon.ac - Unable To Locate Component" in the title bar with "This application has failed to start because ArcCon.dll was not found. Re-installing the application may fix this problem." Can any1 help?
Aug 08, 2009 | Arcsoft Print Creations - Cards &...
The file hpzrp306.dll on (unknown) is needed
You need to clean your registry. Download a program called Glary Utilties (it's free) from Download.com. Run it to clean your registry.
Apr 03, 2009 | HP DeskJet 5550 InkJet Printer
IBM Lapyop T42-message"Fan errors" does not turn on
your cooling fan is reporting as damaged you need to replace the fan unit (cooling pad as well) likely service is required and unless you want to disassemble your laptop a service center would be better suited for this job.
Dec 13, 2008 | IBM ThinkPad T42 Notebook
Ibm think pad
File iertutil.dll is located in the folder C:\Windows\System32. Downloading the file and copying into the specified folder will solve this problem.
http://www.dll-files.com/dllindex/dll-files.shtml?iertutil
Sep 28, 2008 | IBM ThinkPad T42 Notebook
Owner is late, we can't find the cd software
To download the drivers you can go here. When the page opens you will need to choose your operating system. Then from the Drivers section I would choose the full feature driver. Once you click that, you will see a Install Now button that will allow you to immediately install the software and also a Download Only button that will allow you to download the file for later installation. Both of the options will have a link below them that says View Directions which can be used to get step by step instructions for installation of the drivers.
Hope this helps. Please remember to rate this information.
Thanks
Aug 02, 2008 | HP DeskJet 5550 InkJet Printer
New installation on Toshiba lap top. Unable to transfer data from Quicken 99 on IBM lap top. IBM did not recognize flash drive. Copied to email and sent from IBM. 3 messages below with attempts to add...
Try reinstalling Quicken 2008 after uninstalling it first via 'Add/Remove Programs" in Control Panel. this should help.
Also check out THIS article on converting Quicken files to new versions and other info..It may prove to be quite useful..
As for the IBM Laptop not recognizing the flash drive, generally they come with a driver CD. Try installing that on the IBM and see. If you do not have the CD, you should be able to find the driver from the manufacturer's website, or do a google.
Should you have any further questions, please feel to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 19, 2008 | Computers & Internet
HP deskjet 5550 sometimes prints and icon reads Toolbox not available because printdriver is not installed
thats easy! HP has a bad habit of screwing drivers up! List here what operating system you have, and the exact,with any letters behind the 5550, model number here and I'll get the drivers. I have almost every drivers for windows for that particular printer
Jun 13, 2007 | HP DeskJet 5550 InkJet Printer
5150 installation problems
Does the message specify any particular dll? If you could copy the dll?s exact name and repost this question it might help the community in finding you a better fix. The best I can do considering the situation is refer you to the HP site, to a page there where you can download the relevant drivers: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=304431&lc=en&cc=us&dlc=en&submit.y=9&submit.x=11&lang=en&cc=us download the driver that fits your operating system and follow the instructions. Usually installation doesn?t require much computer savvy, just repeatedly pressing the ok button. Offcourse if you still have the original installation CD that you got with the printer then check to see if the driver is already there. Good luck
Feb 21, 2006 | HP DeskJet 5150 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
Seeker5211
Seeker5211
