Question about Intel Motherboard
Usb driver not installed
Helo! I have a problem now with my mother installer, i reformat my computer and the usb driver not installed my usb lash drive did read also and my printer. how can I find a solution .......tnxs!!!!
Cannot read from disk, ask for installation drive
Just to clarify it is asking for the install driver? If so it should be in the portable unless you have reformatted or upgraded your laptop/computer. I went to the WD site and found this page for you. I would recommend that you check the knowledge data base and dicussion board before using any of the downloads. I hope this helps
Sep 02, 2013 | Western Digital Wd Elements Se 1tb...
I got wd5000bmvv 2.0 portable hard drive I puted that in usb 3.0 jack in my laptop now its show detect but dose not come any option on screen
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Western Digital produces a line of external hard drives known as "My Book," designed primarily for use as part of a data backup regimen or general data storage.
These drives are compatible with both Macintosh and Windows computers, but you may need to perform some work on the device in order to get it working as desired with your specific system.
Reformatting
Western Digital's My Book drives come formatted with use for a particular type of computer. Therefore a drive sold for use with a Macintosh may not work out of the box with a PC, and vice versa.
In such cases, you will need to reformat the drive for use with your system.
On a Macintosh, you can reformat a PC drive using the Disk Utilities application, found in the Utilities subfolder of the Applications folder.
Set the number of partitions you wish to divide the drive into, and choose "Apple Partition Map" and "Mac OS Extended (Journaled)" from the list of options.
To reformat a Macintosh drive on a Windows computer, use the Disk Management window.
Start by right-clicking on the desktop icon labeled "My Computer," then select the option labeled "Manage."
Review the listings, and select the drive entry that corresponds to your My Book.
Right-click on a volume's blue bar to delete that volume from the drive (make sure you have the right drive selected).
When the blue bar turns black, right-click on it and select "New Simple Volume" to launch a wizard that will guide you through the rest of the reformatting process.
Drivers and USB 3.0
The My Book does not require the installation of any special driver software in order to work with your computer.
However, if the data transfer rates seem slower than expected, you may wish to check that your computer's USB drivers are up to date.
Some models of the My Book are capable of operating at USB 3.0 speeds, but if your system is using USB 2.0 drivers, this can affect performance.
You can generally find the latest drivers for your computer by visiting the manufacturer's website; look for a link to a "Downloads" or "Support" page.
Searching for your computer's specific model number may help as well.
If you've built your own computer from scratch, check the motherboard manufacturer's website. If your computer does not come with USB 3.0 installed, you can install an adapter card into one of the motherboard's available PCI-e slots.
These cards come packaged with special drivers of their own, and installers are also often available at the manufacturer's website.
if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
these can be purchased on Ebay cheap and easy to install
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
for roughly $9 or $10free postage
Hope this helps.
Nov 24, 2012 | Computers & Internet
I have a western digital Mybook. the blue light will not come on. I hear the hard drive coming on.
w7
for xp or earlier
Reformatting
Drivers and USB 3.0
Hope this helps.
Nov 23, 2012 | Western Digital My Book Essential Edition...
My lg external hdd hxd2 works with other computers but not on mine i have reformatted my windows 7 and it does not work ?
I usually face scenarios like yours and this is what i normaly do. Firstly Change the USB ports(in other words try all the usb ports you have on the computer. If it doesnt work try to use a diffrent USB cable. If it doesnt, then open up the hard drive and remove the usb connector and connect it directly to your computer's motherboard as a slave. Here, no doubt you will access it. Even though you have re-installed Windows 7, maybe your computer needs High speed USB Drivers
Dec 19, 2011 | Computers & Internet
The hard drive crash I can get the recover up but it will not reformat the hard drive it has a lot of bad sector. have new hard drive have windows disk, try loading windows install driver for SATA drive,...
Try copying the driver files (install and otherwise) to a USB flash stick. Put it into a usb port, turn computer on. You should then be able to access the files throughout the installation.
Jun 29, 2010 | Gateway MX6912 Notebook
Sir, Good day! How to reformat my hardrive toshiba dynabook without dvd drive
You'll need to remove your hard drive, hook it up to another computer via a USB to Hard Drive adapter and use the operating system of the other computer to reformat the hard drive. This will only reformat the hard drive, not install a new OS. To install a new OS you'll need a DVD-ROM and OS installation disc, or a flash drive with an OS installer on it to install from the flash drive.
Mar 25, 2010 | Computers & Internet
Laptop dsn't rd USB flash wants driver+DVDrom/CDWR missin driver
what is your OS? XP or higher Os dont require driver for your USB, but if you are using XP then a problem on your driver, reinstall your board driver
Oct 08, 2009 | Computers & Internet
The computer doesn't read the flash drive when i plug it into the USB port
go to my computer property then hardware then device manager then uninstall usb drivers and install again
if u find unknown device u must have to install proper flash drive driver
May 22, 2009 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
