Question about Roland Sp-606 Sampling Workstation System
How can i convert from any sample formats to SPD format
    Guru:
  • 519 Answers
I would like to share you a best converter i have used:
Video Download Studio
Click here to see the full reviews and have a free trial:
http://www.downloadvideos-convert.com/download-videos-music
It can convert almost any the video format to another with high output quality.
This full-featured video converter software also can help you:
1.convert between all mainstream video and audio formats,such as(mp4, mov, m4v, vob, XviD, avi, flv, 3gp, 3g2, mpg,wmv,etc;m4v, mp3, wav, ac3,etc)
2.extract audio tracks from video files to other audio formats
3.support all popular portable multimedia players
4.edit video-Merge, Trim, Crop and Snapshot
It is very easy to use,just follow the instructions on it you can convert your videos and make your movies and music taken easily on PSP, PS3, iPod, iPhone, Apple TV, Xbox or other digital devices.
Hope this can help you.
Posted on Jun 05, 2010
Hannspree hsg1075 says it plays video from USB but has no video in input menu.
Notes:
• It does not support "NTFS" and the maximum file size of a single file is 4GB.
• Progressive format jpeg files are not supported.
• Due to the compatibility limitation, not all of USB devices are able to be
displayed properly.
• Operation using USB hubs is not guaranteed.
• Due to the compatibility limitation, not all of external hard disks are able to be
detected correctly.
• Cables used to prolong the USB device must be certified as USB 2.0.
• In USB devices, video files may not be played properly if speed is not enough.
Apr 08, 2014 | Televison & Video
How to recover files from a crashed Compact Flash on my Roland SPD-S?
It's possible your CF card is full.
1. Connect the card to your computer as you have done. 2. Copy the files off it and save same them to a folder on your desktop.3. Right click only the Flash drive and navigate to "Properties" or "Get Info" if your a mac user.4. Take not of the file system it is currently using.5. Re-format the card with the same file system using your computer.6. Replace the card into your Roland SPD-S and Re-format using these steps: a. Select patch mode or wave mode. b. Press {SHIFT} and {SETUP} (CARD UTIL) c. Press the PAGE buttons to select "CARD FORMAT" then press {ENTER} d. A"[>] to format." indication appears. Press [>] e. A "format, sure?" indication is displayed. Press {ENTER} to start formatting.
7. Once formatted you can replace the card in your computers card reader and copy the files you backed up earlier onto it.8. Re-place the CF card in your Roland and it should work. If not then you may have a irreparable CF Card.
Oct 26, 2012 | Roland Spd-S Sampling Percussion Pad...
Converting Files from CDs?
The bit rate and sampling rate that you set for the mp3 format was possibly wrong. Since the 4GB player obviously isn't an HDD6330, I can't tell you what those rates are, but they are on the spec sheet that came with the player in tiny writing (or in the back of the manual sometimes - 50/50 with Philips). Go back into the Rip options in Windows Media Player and set the bit rate to 128. Once ripped, select the Properties for one of the song and find out the sampling rate. If the sampling rate is wrong, you can use a free program called Media Monkey to convert them to the right rate.
Another possibility: the songs that you initially converted were in CDA format. When you went to resync the songs that had been changed to mp3 format, the Philips read them as "already on the player" and ignored the format changes. Delete all the songs off the Philips and resync the songs that are in mp3 format. Good luck!
-Tha Mp3 Doctor
Jan 03, 2009 | Philips GoGear HDD6330 MP3 Player
SPD-S.....Internal Memory Full
if you have the samples in .WAV then you will have to IMPORT them, because SPD-S can only play .SPD files (import will convert from WAV to SPD).If you have produced your samples with your SPD-S (via mic or line-in or PhraseMaker) then they are already in .SPD-format and can be assigned without importing.
In this case you just have to assign a sample to a pad, by pressing CARD ("card"=lit) you can assign samples from your CF-card to a pad.
Dec 31, 2008 | Roland Spd-S Sampling Percussion Pad...
Trying to convert purchased music into format playable on philips player
If the songs were purchased from iTunes, forget about it. Philips has yet to make a player that is iTunes compatible. Unfortunately, if you have purchased music from another service, you would have to buy a DRM-stripper to make it compatible with Philips' non-DRM compatible models (of which they have several). You best bet is to buy Rhapsody's Mp3-Only service - the songs are DRM-free and will work with your Philips. You could also get songs from Limewire that are in mp3 format. If you are sure the songs are in mp3 format, and it is still giving you the error message:
-Tha Mp3 Doctor
Dec 25, 2008 | Philips GoGear SA178 MP3 Player
File import
Try IMPORT instead of just trying to load them on your SPD-S.
The SPD-S uses some kind of its own file-format.
Regards
May 18, 2008 | Roland Spd-S Sampling Percussion Pad...
Roland SPD-S Flash card error
The card I have always been using is now also suddenly giving this message. I found an old SanDisk 16MB and a 1GB SanDisk that works perfectly in my Boss 864 and they also give the same message. Trying to go into formatting brings the message "no card!"
May 13, 2008 | Roland Spd-S Sampling Percussion Pad...
Kaisen P83 - Invalid Viedo File
You need "Total Video Converter" and "Xilisoft 3gp".
1st make a video with your phone. Open the file with Xilisoft 3gp.
Take note of this:
Summary:
Duration: ????
Bit rate: ????kbps
Video:
Format: mjpeg
Frame rate: ???fps
Audio:
Format: ????
Bit rate: ???kbps
Sample rate: ---
Channels: ????
Now convert a video with "Total Video Converter" using the parameters you got on Xilisoft.
I tryed and works well.
Hope this help you ^^
Jan 17, 2008 | Siemens M56 Earbud Hands Free Headset
Converting video files
go to www.kasercorp.com and down load the manual. it will tell you were to get the mtv converter
Oct 05, 2007 | Kaser Corporation Mambo Mano Digital Media...
Roland Sp-606 Sampling Workstation System Logo
313 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Vito Vacirca Jr.
Greg Cann
Greg Cann
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
