Question about Panasonic CT-36SX12 36" TV
Checking the 6.3a slo-blow fuse
If I open the TV where would the 6.3a slo-blow fuse be? I would like to check if it before calling the repairman. Is it easy to change? Panasonic CT-36SX12
  • 55 Answers
If you open your tv , you have to put back the board, there are 2  clips
one on left other in the right that keep the board to the case of tv( you have to disconnect  the cable AC before open the tv)
you can see the fuse easely ( if  i remember good there is only one
fuse about near the switch on /off
Posted on Dec 08, 2007
How to change fuse
See Service Manual, fuses F7001 (6,3A), F7002 (1,6A), bimetal switch (page 17 - power unit, page 33 - Checking the power unit, page 126 - gray areas of the wiring diagram, fuses F7001, F7002):
Apr 13, 2015 | SharpVision XV-Z10000U Multimedia...
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
Can power on
Check the fuses.Blown fuse conditions
FU1 - 6,3A Doors/covers open is displayed.
FU2 - 6,3A Doors/covers open for the finisher is displayed.
FU3 - 4A paper end condition.
FU4 - 6,3A SC 121 is displayed.
FU5 - 6,3A one of SC302 or SC403 or SC405 is displayed.
FU101 - 15A no response.
Fu 102 - 8A no response.
FU103 - 1A normal operation,optional heaters do not work.
If FU or 102 is the problem,verify the main motor and the fusing unit heater lamps and thermofuses.After change the problematic fuse removal the fusing unit and turn ON the copier.
Apr 18, 2013 | Ricoh Aficio 450 Copier
Fuse keeps blowing on my Philips 32pw8608/12
Please, never try to replace a fuse, without checking for any short circuit inside. You will only increase the damage inside. It is advisable to call in a qualified service technician as opening back cover by unqualified personnel is hazardous.
Aug 15, 2012 | Philips Televison & Video
How do I know If the fuse that needs replaced is a "slow blow" or "fast acting" fuse?
Look at the stampin on the fuse, if it has TXXA 250V, then it is a slow blow fuse type (T = Time dealy), some may be stamped with SLO-BLO XXA 250V on it.
Post pictures if you are not sure.
Failed TV and Monitors:
Sep 24, 2010 | Philips Televison & Video
Just bought a used Toshiba TAC 9530. Owner said it worked. I plugged it in and have no power, no indicator light, nothing. Can anyone help or have I paid for a very large paper weight?
A blown fuse is a very common type of fault due to poor design very often triggered by power surges due to outages or lightning storms. However, the most likely parts to short are easily tested, usually in-circuit, with an ohmmeter and then easily removed to confirm.
Note that it *may be* useful to replace a fuse the *first* time it blows (though it would be better to do some basic checks for shorted components first as there is a small chance that having a fuse blow the second time could result in additional damage which would further complicate the troubleshooting process). However, if the new one blows, there is a real problem and the only use in feeding the TV fuses will be to keep the fuse manufacturer in business!
Sometimes, a fuse will just die of old age or be zapped by a power surge that caused no damage to the rest of the TV. However, it must be an EXACT replacement (including slo-blow if that is what was there originally). Else, there could be safety issues (e.g., fire hazard or equipment damage from too large a current rating) or you could be chasing a non-existent problem (e.g., if the new fuse is not slo-blow and is blown by the degauss circuit inrush current but nothing is actually wrong).
If the fuse really blows absolutely instantly with no indication that the circuits are function whenever the TV is turned on.
May 30, 2010 | Televison & Video
What makes a fuse blow after being on for about 15 seconds
Hi Bill,
Either a short or too small a fuse.
Many fuses are what they call, 'Slo-Blo'. they are designed to take high current for a few seconds before blowing. This prevents normal power surges from blowing the fuses.
If this is happing every time you replace the fuse, something is wrong internally that requires attention.
Remember, the fuse blows to protect the equipment. The next step is to find out what is making the fuse blow.
If it's under warranty, don't open it up. just exchange it.
As for the reason it's blowing, you would need to post all the symptoms.
Best regards
Dec 26, 2009 | JVC KD-LX30 CD Player
Fuse blown
Hi mate most uk set have a 3,15amp 250v fuse ti dosent matter if its quick or slow all the best Bob
Aug 13, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Rca 27f630t
It takes a star driver if I am not mistaken to take the back off probably two different sizes one for the top bottom and sides and one size for where the rca jacks are.. I only recommend checking the fuse...if blown never put foil around it. Takes a 4 amp. 5 amp would be ok. Dont go over this. If the fuse is good you should take to a good tv repairman. If blown and blows the fuse you put in take to tv repairman. Anything past this is highly technical. Hope you have a blown fuse only.
Dec 30, 2007 | Televison & Video
Panasonic CT-36SX12 36" TV Logo
141 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
