Question about Hoover AAA160 Front Load Washer
The drum of my washing machine is not turning with the programme
  • steven_wolff May 11, 2010
    Sounds like the drive belt has come off from the motor to the drum drive ,its not a difficult job unplug from electricity take off the back panel of machine you will instantly see if belt is off or broken if broken find model number and change belt hope this helps
    Sergeant:
  • 197 Answers
Check belt is not broken, by taking off the back plate at the back of the washer
Posted on Sep 18, 2009
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Zanussi zwf1621s washing machine not working.
IT SOUNDS AS THOUGH THE MOTHER BOARD HAS SHORTED OUT OR YOUR DRUM HAS COME AWAY FROM ITS MOUNT
Dec 27, 2013 | Washing Machines
Indesit wd1030 washing machine drum not working
Your drive belt may be damaged and needs replacing
Nov 06, 2009 | Washing Machines
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
Bosh washing machine won't do any programmes
If it fills then the next phase is to agitate.
To do that the motor must drive
Can you hear a whirring sound from the machine if you get close to it if so then the belt driving driving drum may have snapped.
If not then the motor brushes may have stuck or have worn out.
Does the machine programmer advance by itself or are you turning the dial
May 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
AEG OKO_LAVAMAT 6200 DIGITRONIC fRONT LOADER wASHING MACHINE Problem: The drum doesn't spin or turn at all during any programm. We have releveled the machine and run a washing programm several times.
I have the same problem and Dell Appliances serviceman this morning stated it was a faulty interlock mechanism and that was preventing the spin function working. cheers.
Jul 17, 2008 | AEG Washing Machines
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Hoover AAA160 Front Load Washer Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
