Question about Microwave Ovens
Panasonic dimension 4. Turntable no longer turns
  • 11,896 Answers
If table doesn't turn, then the table motor is most likely faulty. You can get motor and repair manual at www.repairclinic.com
Posted on Sep 05, 2009
Testimonial: "Thanks, most helpful"
I have a 18mth old Panasonic dimensions 4 invertor microwave oven that turns on for 3 or 4 seconds and stops altogether,any ideas?
What does the clock say after it stops? Is the time still correct, or is it wrong? Or maybe you mean only the turntable stops spinning, in which case the problem may just be that it needs a new belt! Try RepairClinic.com if that is the case!
May 16, 2017 | Panasonic Microwave Ovens
Panasonic Dimension 4 Microwave- Model NN D801. Whilst microwaving for 2 mins on high - heard a zapping noise. Didnt heat food. Front operating panel works. turntable still works. Any suggestions?
A "zapping noise" usually indicates a problem in the high voltage circuit. If it's an inverter oven, it should have provided you with a fault code. If a non-inverter, the most likely causes are a shorted high voltage rectifier or bad magnetron. But there are many other possible causes.
Oct 02, 2016 | Panasonic Microwave Ovens
I have a Panasonic Dimension 4 Genius microwave and the turntable no longer works. Is this fan belt operated and where can I get one if broken?
1) Microwave ovens are usually not user servicable, so even if you're a true Mr. Fix-It, it might be mission impossible to get spare parts.
2) Microwave ovens aren't that expensive, so a replacement might not be that much more expensive than trying to get your current model repaired.
3) Do you REALLY NEED the disc to turn??? It's all for show, it doesn't do anything to whatever you're trying to microwave.
Nov 07, 2014 | Microwave Ovens
Dimension 4
I have this NN-C780P Microwave/Convection Oven. The microwave mode is not working and baking was ok until recently, the turntable cannot rotate when the temperature, timing and baking are ok.
When I bake, there are knocking sound.
Please advise.
Sep 10, 2013 | Panasonic NN-T888S Convection/Microwave...
Panasonic Dimension 4 Genius problem
An internal fuse may have blown or the magnetron may have failed
Apr 09, 2013 | Panasonic Genius Prestige Nnsd997s -...
Panasonic Dimension 4 Microwave. Turntabel does not revolve
The motor for the turntable is probably faulty and requires replacing.
May 20, 2011 | Microwave Ovens
Panasonic dimension4 microwave
check the damper motor is opening and closeing
Jan 17, 2010 | Panasonic NN-T888S Convection/Microwave...
Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave Ovens Logo
143 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
