Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Smeg df612sdx dish washer - 'P' programme button not working
I have a smeg df612sdx dish washer, The 'P' programme button has stopped working. When you press it nothing happens.
Is it possible to replace the button ti fix the problem
Smeg dish washer wont stop even when the door is opened,
I never heard of a smeg DW but you can bet the door interlock is hung up in some way. Ususally its micro switches on the latch assy. Then again, could be a bad relay on the control board. I would dis connect the switch first and see what happens. The way I would do that is disconnect power at your circuit box and dis connect the switch, tape off the wire, latch the door and return power. Bet it doesn't run. Most likely the switch assy. Would help to know the right brand name tho...
Oct 16, 2013 | Smeg Dishwashers
Smeg df612sdx wont drain
its clog up take a clothes hanger an clean the drainage
Mar 12, 2012 | Smeg Dishwashers
Error 4 on my smeg washer, not doing any programmes only rinse
Smeg Error 4 states 'NTC- water in, short circuit or interrupted'.???
'NTC' stands for 'Negative Temperature Co-efficient' or water temperature thermostat to you and me!
Might be worth trying the following in case the thermostat is just stuck.
One way of hopefully getting around the problem is first to ensure the washer is empty then pour the contents of a boiling kettle into it. That can sometimes kick the device into correct action. It's worth a try anyway before having to call in the repair man ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 08, 2011 | Smeg WM16AAA Front Load Washer
Smeg Dishwasher ST 663 sometimes won't work
My dish washer stops after i5 minutes, don't know what the problem is, water is going in but just suddenly stops, i changed the hose but still the same. Any help welcome
Feb 22, 2009 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
MANUAL FOR A SMEG DISH WASHER ?
dunno, your question dont make sense
Jul 08, 2008 | Smeg Dishwashers
Smeg dishwasher
my hotpoint dish washer aquarius is 4 years old leaves a sandy grit all over dishes water not spraying the top,done all the usual stuff run out of ideas
Mar 09, 2008 | Dishwashers
My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
155 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
