Question about Broan-NuTone Intermediate Whispaire WA6542SS Stainless Steel Kitchen Hood
Motor is noisy and very hot. How can I get a replacement motor for WA6500-c ?
  • 2 more comments
  • Badmotor Dec 11, 2007
    Thank you for your helpful information, but I am considering a different manufacture because the cost of the motor is almost the same price as a new one. Considering we bought the unit one year and one month ago, we were surprised since the original one lasted thirty years.
  • pggal May 03, 2008
    We are having the same issue with the same product exactly. I shall phone them . The fan cost about $150. A new motor costs $120. Whats wrong with this picture.
    thanks mb
  • lar656 Jul 11, 2008
    I had the same problem only it was the replacement motor ($34) that was noisy and hot. The problem was not with the motor but the switch assembly. Broan sells it for $30 because it's a variable speed assembly - I think I'll change mine to on/off and save $28.00.
  • carlosdyer Feb 01, 2009
    I chose this model as it was at a good price and i wanted a unit with a large fan that would run as quiet as possible.
    Large fan, lower speed, less noise.
  • 833 Answers
These guys have it! http://parts.broan-nutone.com/broan/Shop
Posted on Dec 09, 2007
  • Robert Hirst Dec 11, 2007
    Before you buy another...give them a call. They may 'help you out' because you are so recent a purchaser. Good luck.
My 2002 Mazda tribute ran hot. I found out my heater connection was broke. But when I replaced it. It still ran hot and now it taps real loud when the motor gets hot.
Need to discover why it is running hot to start with but not drive if it is causing the motor to get noisy. Overheating can be due to a thermostat stuck closed, cooling fan not turning on, low coolant level etc. Need to get to the bottom of the overheating before engine is damage badly.
Sep 13, 2015 | Mazda Cars & Trucks
Noisy blower motor
if its squalling..the bearings are bad.. motor needs replaced..if not it will blow fuses due to lockup..
Dec 22, 2013 | 2003 Chevrolet Tracker
Flotec pump 1hp motor has become too noisy when running
Is it the pump or motor. Pumps do wear out and need rebuilding or replacement.
Dec 17, 2013 | Plumbing
Help! Just opened my pool and the pump/motor (which is only 2 years old) is very noisy. Sounds like it could be the bearings. Do call someone to the house, disconnect and take to a repair shop, ord
Disassemble the pump to the point where you can see the whole impeller. Then turn the power back on to verify that it is the bearings, and not trapped debris causing the noise. If it is the bearings the short answer is to replace the motor.
Bearing failure is usually related to a leak at the pump seal. This results from either a faulty seal installation, or the pump running excessively hot (from running w/o water).
When replacing the motor carefully examine the seal plate (where the seal is set) front and back for any cracks or deformity. If the new seal doesn't set exactly, it will leak.
Apr 03, 2013 | Smith AO Pool Pump Motor
Treadmill motor sparking
Any electrical motor has the same principle and the same maintenance(lube the bearings+replacing brusch, cleaning+replacing some old winding hot,etc)
Now you have two option a)go to some repair shop for repair electrical motor or 2) by a new ones .
See my personal TIPS for motor help
God bless yoy
Jan 22, 2013 | Horizon CT5.0 2.0 HP Digital Drive Motor...
Motor is making a loud noise
if you can get to the sticky paper that hides the bairings, drop some oil in the hole and seal it back up, problem fixed for another year.
teflon oil is better.
Aug 09, 2009 | Samsung RS2630WW Side by Side Refrigerator
She was a little noisy with the fan sounding like it was rubbing, today i found no working at all but it was real hot. I opened the back and the fan spins freely and there is a canister that looks like a...
The capacitor should not be hot, so the motor could be drawing high amps do to a worn bearing which could cause the rubbing sound.
With the power off try to move the motor shaft from side to side, it shouldn't move any that way, if it does the bearings are worn and you need to replace the motor and the capacitor. The other cause for the hot capacitor would be a bad capacitor.
If the motor is bad you should also replace the capacitor at the same time.
Aug 05, 2009 | LG LD40E Dehumidifier
Motor shuts off, and resets after a few minutes dryer wont run
May be the tub support rollers, If this is problem you will have to remove the tub. Then check rollers to see if they turn free. If not replace the faulty ones. This drag on the motor will cause it to get hot.
Mar 29, 2009 | GE DBXR463EDWW Electric Dryer
Nutone WA6500 range hood fan motor noisy
We have the same product, 18 months in use and the very noisy motor has finally seized up. I contacted the manufacturer and was advised that I need a new motor, motor mounting bracket and fan rotor. The agent was not able to quote me a price for the parts but stated that even though my 1-year warranty had expired, if I faxed them a copy of the original sales reciept they could possibly send me the parts for free under the original warranty agreement. I've done as they asked but haven't received a reply as yet. After reading about all the problems with this product I'm tempted to dump the whole unit and try to find another manufacturer that has a reliable and QUIET range hood.
Dec 16, 2007 | Broan-NuTone Intermediate Whispaire ...
Broan-NuTone Intermediate Whispaire  WA6542SS Stainless Steel Kitchen Hood Logo
488 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Marvin
Marvin
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
