Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Formation of ice in freezer compartment
I have a 4-year old Bosch bottom freezer fridge, model KGU44123. Ice forms in the bottom freezer compartment so that the freezer drawer gets stuck. The Bosch agents have replaced the door rubber and two sensors in the freezer compartment. It hasn't solved the problem. The fridge is properly tilted slightly backwards. Any suggestions?
  • Bosch Master
  • 43,501 Answers
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 20, 2010
Turned the fridge temperature up (ie. from 3 to 6) but fridge warmer than ever. Gauge on side ambiguous. Now wondering whether 1 is actually the coldest and 6 the warmest. Help! Fridge old so can't trace...
Keeping 3 to 5 degree is good. But check freezer is frosting good. If ice formation around the freezer is over, it will abstract the fan by functioning. If so, check defrost timer, thermostat and heater for not malfunctioning.If defrost cycle is good, there would be constant cool in fridge compartment.
Thanks.
Feb 03, 2011 | Fisher and Paykel Active Smart E522B...
Ice forming on the back of side by side 17 yr old fridge
You have a bad defrost heater . To access , you will have to remove the inside rear freezer panel . The heater is located at the bottom of the coils . Take your model number when ordering the part so you get the correct part .
May 02, 2010 | GE Refrigerators
Bosch Frost Free Frdge Freezer Icing Up
Switch off fridge. Put a pedistal fan in front blowing into the cabinet and leave until all ice has defrosted. Locate the drain hole in the back of the freezer compartment, try to defrost ice which blockes up about the first inch or two of this pipe. If water does not run through you need to force it through with a turkey baster. This should sort your problem. ratemeplease
Mar 12, 2009 | Freezers
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Bosch KGU31124 Freezer Not Working
I have the same freezer and get the same problems. Ice forms on the refrigeration fins beind the plastic shroud at the rear and completely blocks the airflow. The fan that moves cool air around does not work then and freezer temp goes up. Ice will often push the shroud forwards so that the door does not close properly. Warm moist air get in and just increases the ice problem.
I take the shroud and fan housing off the rear (4 screws and a wire to the fan) and defrost thoroughly using a hair dryer. You can then see when all the ice has gone..
Sep 18, 2008 | Bosch KGU31124 Bottom Freezer Refrigerator
Bosch KGU44120 frost free fridge freezer (6 years old) generates ice on floor of freezer compartment within a couple of hours. Maintains -20C temperature no problem.
drain is blocked in freezer. take back panel off inside the freezer and you will probably find that the bottom is covered with ice. melt off with a hairdryer and hot water till water flows freely down the drain. needs a bit of patience
Jul 04, 2008 | Bosch Refrigerators
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
557 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
