Question about Samsung SGH-D900 Cellular Phone
Samsung SGH-D900 will not turn on. Buttons and backlight light up when on charger, charging tone sounds when I plug it in. It used to display the charging screen but doesn't now. Nothing happens when I press and hold the green key. Dies when unplugged. Tried full reset code *2767*3855# but nothing. Any ideas. Thanks.
How to turn off the keypad tone for my samsung d900i
On the phones sides there are two buttons. Press the lower button severally and the tone reduction will be displayed on the screen. Alternatively, go to settings, then select sound profiles then select normal then option, edit then scroll to keypad tone then mute.
Oct 04, 2011 | Samsung SGH-D900 Cellular Phone
Samsung sgh-d900 won't power on. If I plug in the charger it lights up and shows the battery charging animation. When it goes deem, it will respond to every button by going back to the charge meter EXCEPT...
the power buttons are very very small and are prone to break ther solder point take it into a mobile service agent and have them resolder/investigate the problem at this point its all you can do
Nov 28, 2010 | Samsung SGH-D900 Cellular Phone
Samsung SGH D900I- cannot turnoff keypad sound
The steps are outlined in the article below:
D900 FAQ – How do I disable or mute the keypad tone on my SGH-D900? admin March 6, 2009 --> Note: In order to disable the keypad tone, the Dialing Display Font Type must first be set to “Normal”
To change the dialing display font type follow the steps below:
  1. From the standby screen, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Display Settings (3)
  4. Select Dialing Display (6)
  5. Select Font Type (1)
  6. Highlight either Normal or Theme, using the navigation keys
  7. Press the left soft key to Save the Dialing Display Font Type setting
To turn off the keypad tone follow the steps below:
  3. Select Sound Settings (4)
  4. Select Keypad Tone (2)
  5. Highlight Off, using the up navigation key
  6. Press the left soft key to Save the Keypad Tone setting
Aug 29, 2009 | Samsung SGH-D900 Cellular Phone
Can't turn on my d900 with cable plugged in...
It is probably is the charging port. Have you tried a different charger?
If it is the charger port on you SGH-D900, You have 3 options.
1. get it repaired, under warranty if possible.
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay.
For more information and links to the parts check the following link below.
Samsung SGH-D900 will not charge
Jul 11, 2009 | Samsung SGH-D900 Cellular Phone
My phone samsung d900 is charging up witout charger installed
The charging port on your D900 may be broken. Have you tried a different charger first?
You have 3 options when the charge port breaks.
2. Get a new D900
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on Ebay.
Fix for Broken Charge port on Samsung SGH-D900
Jun 03, 2009 | Samsung SGH-D900 Cellular Phone
Samsung charging problem
If very well could be the charging port. Have you tried a different charger?
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
Samsung SGH-D900 charging problem repair
May 13, 2009 | Samsung SGH-D900 Cellular Phone
D900 won't turn on , But battery is ok
Your charging port may have broken. I am seeing more and more of this type of problem. Did you try a different charger? If it is the charge port, You have 3 options when the charge port breaks.
1. Get it repaired, under Warranty if possible. About 60 dollars
2. Get a new one, runs sbout 75 dollars
Samsung SGH-D900 not charging problem repairs
Apr 20, 2009 | Samsung SGH-D900 Cellular Phone
Charger port seems faulty and wont take a charge SGH a 437
Umm, that means it was exposed to moisture or is water damaged.
The water dmage may have caused the charg port on you D900 to short out.
2. Get a new one
Dec 04, 2008 | Samsung SGH-D900 Cellular Phone
Sansung d900 wont work
Take The Battery Out,Give It A Wipe Inside,Take The SIM Out And The Put It All In A Again And See If It Works.
Otherwise See If It Can Be Repaired By Warrenty?
Good Luck :)
Regards,
Sophiee.
Mar 02, 2008 | Samsung SGH-D900 Cellular Phone
Keypad tone
You need to change the display, change the display so that handwriting is NOT selected and then you can change the keypad tone.
Sep 12, 2007 | Samsung SGH-D900 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
284 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
