Question about Canon PIXMA iP90 InkJet Printer
My ink cartridge is full. The page is still
My ink cartridge is full. The page is still printing with lines.
  • 13 Answers
SOURCE: won't print in black
open your list of printers. r/click on the 780 and open properties. fo to the last tab "maintenance" and run cleaning 2 or 3 times then run deep cleaning 2 or 3 times. and see how this helps. If you've never done it before you might want to take out the print head and clean it with alcohol. Take out all the ink like you were changing them then reach in and gently pull out the container that holds the ink. This is the print head. Clean it and replace it, then run clean and deep clean again. run Nozzle check to see how clean it's become and you'll definetly see a difference in your printing. good luck
Posted on Oct 02, 2007
IB4G2008
  • 3587 Answers
SOURCE: Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Posted on Mar 24, 2008
  • 31 Answers
SOURCE: black ink cartridge is leaking and black line is running down back of page
if you do your own refill the ink u are using is of the wrong density, get the right ink
Posted on May 22, 2009
daryn720
  • 113 Answers
YOU CAN TRY PULLING THE CARTRIDGE OUT AND WITH A CLEAN , VERY SOFT CLOTH , CLEAN THE HEAD GENTLY ....SOME CARTRIDGES ARE JUST FAULTY ....HAVE YOU TRIED RETURNING IT OR GOING TO CANON SITE AND TROUBLESHOOTING ?
Posted on Jun 02, 2009
komguy
  • 2306 Answers
SOURCE: Ink leak?
It's not the cartridges, the waste ink is coming up thru the bottom to the exit rollers. The only fix is to have a shop open it up, clean up the ink mess and install a shield that stops the ink from coming back up when it should go to the absorbers. The new machines all have this shield and the ink tube cut back to make the ink go where it should.
Posted on Feb 21, 2010
HP all-in-one F380 only prints top half of the page, and sometimes that is pretty faded. What to do?
Replace the ink-cartridges, because they are just about empty.
When ink is pulled from the cartridge, there is just enough ink to print a "low-density" page,
or a few lines of text, but there's not enough ink to "freely" flow, on demand, to ink a full page.
Jul 30, 2011 | HP DeskJet F380 All-In-One Printer
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
Colored photos have a parallel red green line running the full width of the picture. Can this be eliminated?
Streaks or Lines in the Printed Image
An ink cartridge could be running out of ink or your ink cartridges require cleaning. Need to check ink levels, run the clean print cartridges utility and then print a diagnostic page.
Working through the steps outlined at the link below will help you to diagnose your specific problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00219790&cc=us&lc=en&dlc=en&product=421139&tmp_track_link=ot_search
Trust this is helpful.
Dec 28, 2010 | HP Photosmart 2610 All-In-One InkJet...
Copier appears to be functioning well, but page comes out blank
You actually answered your own question, you said it started fading and came out with lines missing. Looks like and could possibly be that the ink cartridge you are using wasn't as full as you thought it was, and the computer really has no idea, it's just software and i do not recall seeing sensors on the inside of the ink tank to tell the computer how much ink is in the cartridge. Try refilling the ink again or maybe a better idea is to buy a new cartridge since over time the cartridges can get contaminants in them which will block the ink from the inside of the cartridge.
Hope this helps
May 31, 2010 | Canon PIXMA MX310 All-In-One Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
MP830 prints a black stripe down the back of the paper
the waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Prints only the top half of some lines.
Take the offending cartridge out and get a piece of tissue paper on your finger. Gently run the print head of the cartridge over the tissue paper. You shold see full lines of ink coming out. If not, the cartridge is out. If you see a full line of ink, reinsert the cartridge and do a clean cartridge from the tools menu
This should work
May 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
Printing blank pages
Blank Pages Printed
Remove the protective tape from the cartridges:
With the printer power on, open the front cover of the printer. The cartridge carrier should move to the middle.
Remove the cartridge(s) from the printer.
Look on the underside of the cartridge(s). If there is yellow tape and/or transparent blue tape there, remove it.
Clean the cartridge nozzles:
Go to the Lexmark Control Program or Solution Center and run the Clean print nozzle test.
If a black cartridge is installed, you should see black lines only.
If the color cartridge is installed, you should see yellow, magenta (a reddish purple), and cyan (a dark sky blue) lines.
If a photo cartridge is installed, you may see different colors.
Examine the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.
If there are gaps in the lines, you could run the Clean Print Nozzle page a few more times to try and clear it up or try the "wicking" procedure below to conserve ink.
If the page is faded from left to right and the wicking procedure doesn't clear it up, your cartridge is probably out of ink.
Clean ("wick") the cartridges:
Remove your cartridges following the instructions in your User's Guide.
Take a warm, damp paper towel and fold it so that it has about 4- to 6-ply thickness.
Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge.
Now drag the cartridge lightly across the paper towel in one direction only (left to right) until the bottom of the cartridge looks clean.
Turn the cartridge over so that you can see the bar code sticker on the back. Note: Only perform steps 6 and 7 if the contacts look dirty or corroded.
Using a clean pencil eraser, clean the contact points on the copper strip (only the little squares just below the bar code). Caution! Do not use the eraser on the nozzles that were cleaned, as this will damage the cartridge.
Using a clean part of your dry paper towel, wipe the eraser dust off the contacts; ensure that they are dry, and snap the cartridge back into the printer.
Make sure to install the cartridges following the instructions in your User's Guide, selecting Old Cartridge. Failure to do so could reset your ink levels as explained above.
Repeat the nozzle cleaning procedure one more time. At this point the diagonal lines should be solid.
If they are not and you think the cartridges should have ink in them, contact our technicians by e-mail and let them know the results of this test.
Reset the ink levels:
Lexmark printer cartridges do not have ink sensors. The levels of ink are produced by a mathematical calculation of ink drops and page counts. The printer stores this information and then writes it to the win.ini file on your computer.
Ink levels can be reset by telling the printer you have installed a new ink cartridge or by reinstalling the printer drivers and selecting Cartridges Installed. Once ink levels have been reset, there is no way to change them except by printing.
Accordingly, even if your computer says that your ink is full for a particular cartridge, it may be incorrect and the cartridge may need to be replaced. You may want to try a new cartridge to see if that clears up any print quality problems.
Mar 13, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Printer Pixma IP 1600
Verify your ink cartridges have the 'Tape: removed from the top of the cartridge.
IF the tape has not been removed a vacuum is present in the cartridge and it will not allow the ink to flow smoothly.
Also try a few cleaning cycles.
Feb 09, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA iP90 InkJet Printer Logo
old marine
old marine
