Need manual for kenmore 80 series washing machine
  • 15,935 Answers
Head over to SearPartsDirect.com and enter your exact model number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 series lid switch
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosned, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Posted on Nov 02, 2007
  • 1028 Answers
SOURCE: Kenmore 80 Series Top Load Washer not agitating
if it will pump out ckd motor to gearcase coupling probably broke
Posted on Sep 03, 2008
SOURCE: kenmore 80 series washing machine
I have Kenwore Series 80 Clothes Washer, Model # 110.26842694,Serial # CJ 3231197 and a couple of problems exist; as the timer reaches the rinse cyle the timer stops and needs to be set to the spin setting, during this period the water does not drain. Is there any suggestions for repair that can be advised. Thanks, Darius Caswell
Posted on Nov 21, 2008
SolutionGuy
  • 331 Answers
SOURCE: Need to remove the back panel off of the Kenmore series 80
Don't do that, Mike! Access is from the front...
SG
Posted on Apr 07, 2009
jsrock516
  • 5911 Answers
The following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch DOES require replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 11, 2009
Kenmore 80 series washing machine manual
how do I replace the speeds switch on my series 80 washer??
Sep 24, 2010 | Washing Machines
Need to know procedure to clean Kenmore Series 80 filter
unbolt the agitator filters should be underneath let me know how you went
Nov 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore Series 80 washing machine won't drain after wash cycle. The machine just stops.
Check the lid switch under the edge of the top where the lid closes. When you are about 1 inch from closing the lid you should here a little click sound. That is the switch closing. I fyou do not here the click then the switch is bad.
Sep 01, 2009 | Kenmore Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Washing Machines Logo
178 people viewed this question
Top Washing Machines Experts
