Question about Fuji FinePix S3000 Digital Camera
Fujifilm Finepixs S9000
I recently got a Fujifilm Finepix S9000 and it takes pretty sharp pictures but I am having a few problems with it. I know how to set Super Macro mode, but unlike my old point and shoot camera it isnt blurry till you get to the focus.. it's the opposite. Also I've never learned much about 1/1000 or whatever and I'm just looking for the mode that makes the subject sharp and the background blurry.. maybe it's the shutter speed? I read the manual and I followed the directions... turn to "M" move some lil thing that is blurry when I turn it and it didn't do anything or change the numbers like I read. My email is powershot-grl89@hotmail.com
I'm sorry go the Letter S for SHUTTER SPEED, M is for Manual Operation, set to lower then to the Highest, and you will see the differnce.
Happy Holidays
Bobby
Posted on Dec 10, 2007
Yes set your Dail for M for Motion, and if that doesn't work try and set your ISO to 1600, that should eliminate the PROBLEM..
Happy Holidays
Bobby
Fujifilm Finepix AX Flash Is Not Working/Turning On
If your camera is in "silent mode" the flash will not work. Press and hold the Disp/back button for a few seconds and the camera will toggle between "silent mode" and "normal mode"
Oct 09, 2014 | FUJIFILM Cameras
What settings should i use for my fujifilm FinePix S4250 camera
That depends on what you want the picture to say to the viewer. If there was one best setting for everything then there would be no need for any other setting.
If you're taking a picture of a countryside scene, you might consider the Landscape" mode. If you're taking a picture of a person, you might consider the "Portrait" mode. And so on.
However, those are only suggestions to the camera. They set things up to give generally good results for those types of scenes. There may be times when you want to override the camera, to make the picture come out the way YOU want it to, not the way the camera (or the camera designer) thinks it should be.
May 10, 2014 | Fujifilm FinePix S4250 Black 14MP Digital...
I am using a Fujifilm FinePix JX250 digital camera. Not the best I know to photograph jewelry but cannot afford a different camera now. After I've taken the picture I open it in IPhoto. I make...
The following will help to get the best possible pictures from your Fujifilm FinePix JX250:
TO CHANGE FILE SIZE:
  1. Press MENU/OK to display the shooting menu.
  2. Press the Selector UP or DOWN to highlight the option IMAGE SIZE and press the selector RIGHT to change IMAGE SIZE to 14M. This setting has a image resolution of 4,288x3,216.
  3. Press MENU/OK to select the highlighted option.
  4. Press DISP/BACK to exit from the menu.
TO CHANGE QUALITY:
  2. Press the Selector UP or DOWN to highlight the option IMAGE QUALITY and press the selector RIGHT to change IMAGE QUALITY to FINE (Less compression than NORMAL, meaning better picture quality).
NOTE: The focus range of the JX250 goes from 1.5 ft. - Infinity (Wide Angle), 2.6 ft. - Infinity (Telephoto), also make sure to clean the lens and adjust the focus before taking the photos. If the subject is close to the camera, select Macro mode. If the subject is far away from the camera, cancel Macro mode.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
May 28, 2011 | Cameras
Taking a photo of another photo with the finepix z70
Place your camera in MACRO mode to shorten the focal length. Make sure your flash is off. You can zoom in a little bit, but the trick to using MACRO mode is finding how close you can get to the photo without blurring- it takes some practice. You want enough light coming over your shoulder so the picture is not dim, but no glare either. If you can prop your photo up at an angle so that you cand find the "sweet spot" that gives you good lighting and minimal glare, you are home free!
Mar 08, 2011 | FUJIFILM FinePix Z70 Z71 Digital Camera
Im trying to take closeup pics of jewelry, which is the reason I purchased this 12x zoom. I am using the super macro feature but my pics are blurry. Can you give me any tips? Deb
In super macro mode, there is a minimum focussing distance. Any closer, and you have no hope of locking in a focus. So, be sure you don't go past this point.Close up pics have a very shallow "depth of focus" meaning that very little in front or behind what you focussed on will be in focus. Is anything in focus in your pics? If you can exert some manual control over lens openings, you could try using a smaller opening to get more of your subject in focus. When taking close-ups, always use a tripod.
Dec 01, 2010 | FUJIFILM Finepix S1500fd Digital Camera
Hi I bought this camera Fujifilm finepix s10000 fd in order to photograph sharp and clear close up pictures the best way I can. When I press the Menu/ok button = nothing happens. It simply does not...
if your wanting to do macro photography (close up) on the dial on the back, click the left button on the circle and a little flower should pop up on the screen saying "Macro, close up shots" this is for pictures that are closer up then regular and U want them in focus. it takes a few times to get it focused a few times but when it is focused properly, the square in the middle of the screen should be red. if you want really close up, click the button another time and the flower should come up again and it should say "macro close up shots up to 2cm (0.8in). once again once its focused properly the square will be red. you will have to practice because it takes time to learn where its proper focusing points are but i'm sure you will get the hang of it.
Aug 04, 2009 | Fuji FinePix S1000FD Digital Camera
Will not focus on any setting except macro and super macro.
Definitely sounds like it's defective, I'm sorry to inform. I've had my S2000HD for a few months, taken thousands of shots, and never encountered such a problem.
First, you need to check the return policy with the vendor whom you purchased from. If you are beyond their return/refund date, you'll need to then contact FujiFilm USA as they are the warranty holder. You will need your original receipt/invoice, and possibly a UPC from the box.
FujiFilm USA - 800-800-3854
Things worth mention:
1. If having replaced by an online/shipping vendor, make sure they pay ALL shipping costs, as this was a defective product. You will need to speak to their tech support and obtain an RMA.
2. Avoid the manufacturer if you can, b/c more than likely you will need to pay to ship the item to them. They will pay to ship a replacement back, but it is likely you will receive a refurbished item.
Apr 23, 2009 | Fuji FinePix S2000hd Digital Camera
I have a brand new Finepix S8100fd camera and the majority of the photos are speckled no matter what setting I use. However the super macro setting rocks and pictures are super clear! My Fuji 7.1 mega
Common issue with the A8100fd. The most likely problem you are having is not enough light. Try shooting in bright sunlight to test the "graininess". Make sure you use the flash anytime the light is not bright. Even though the camera will shoot in low light (without flash), because it defaults to a high ISO setting, which (just like film) accentuates the "grain", or more properly termed in digital photography, "noise". Set the camera for a low ISO setting and use the flash whenever you see the "red hand" symbol on the screen.
Apr 22, 2009 | Fuji FinePix S1000FD Digital Camera
Fuji FinePix S3000 Digital Camera Logo
95 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
