Question about Kocom KDC-330 Digital Camera
Wiring the kocom dp-203hd installation manual (what color wires go where I have a green, yellow, black, red, white and blue wires. I need to know what colors goes into scoket SW+, SW -, 1B, and 2Y at the back of the Kocom dp-203hd I'm in South Africa
    Top Expert:
  • Kocom Master
  • 79,186 Answers
We do not have this information, it is not published.
Posted on Aug 12, 2016
I am installing a CD player in a 2004 Nissan Sentra and I need to find the wiring diagram to show me how. Can you help?
see connection colors below and let me know if you have questions.
2004 Nissan Sentra wire colors aftermarket radio wire colors
Car Radio Constant 12v+ Wire: Pink, yellow
Car Radio Switched 12v+ Wire: Blue, red
Car Radio Ground Wire: Gray, black
Car Radio Illumination Wire: Red/Green, N/A (tape off factory wire)
Car Stereo Dimmer Wire: Red/Yellow, N/A (tape off factory wire)
there is no factory amplifier wire, blue (tape off radio wire)
Left Front Speaker Positive Wire (+): Pink, white
Left Front Speaker Negative Wire (-): Blue, white/black
Right Front Speaker Positive Wire (+): White, gray
Right Front Speaker Negative Wire (-): Black, gray/black
Left Rear Speaker Positive Wire (+): Light Green, green
Left Rear Speaker Negative Wire (-): Violet, green/black
Right Rear Speaker Positive Wire (+): Blue, violet
Right Rear Speaker Negative Wire (-): Pink, violet/black
Aug 21, 2011 | Car Audio & Video
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1995 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1995
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Distributor
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector)
Parking Lights: Red/Black - (+) Above Fuse Panel
Head Lamp: Red/White - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Blue/Yellow
Windows DOWM: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
VSS Wire : Yellow/Blue - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 03, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1994 Honda Civic This...
1994
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Hood Pin: n/a
NOTES: - none -
CRUISE CONTROL:
NOTES: 4000PPM
on Apr 01, 2010 | Honda Civic Cars & Trucks
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
Just need a diagram showing how to install the
If you need step by step instructions to wire something, you shouldn't really attempt to install a security system, as it will tie into almost every important electrical system in the car i.e. starter, door locks, lights, etc.
However, if you know how to get the lower portion of the drivers side dashboard off, and how to cut/splice a wire correctly and aren't color blind, you should be able to follow the installation instructions that came with the system. The wiring diagram for your car is:
What/ Color/ Where:
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Brake Switch Green/White Brake Switch
Trunk Pin Green/Black (-) Above Fuse Panel
Parking Lights Red/Black Above Fuse Panel
Head Lamp Red/White Steering Column
Door Trigger Green/Red (-) Driver's Running Board (One of Two Wires)
Door Lock Green/White (-) In Driver's Door at Door Lock Module or at Anti-Theft Module under Driver's Seat
Door Unlock Green/Red (-) Driver's Running Board
Horn Wire Blue/Red (-) Steering Column, use Relay
Windows Up LF=Red/Blue, RF=Blue/Yellow
Windows Down LF=Red/Yellow, RF=Blue/Green
Jan 13, 2010 | XX-67A II LED/Valet Switch Pod
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1993 Honda Civic This...
1993
Constant 12V+: White/Blue
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Parking Lights: Red/Black - (+) Above Fus Panel (White Connector)
Hood Pin: n/a
Factory Disarm: Disarms with Unlock
Door Trigger: Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) Driver's Door at Door Lock Module
Horn: Blue/Red - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Orange/White
NOTES: - none -
CRUISE CONTROL:
NOTES: 4000PPM
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1992 Honda Civic This...
1992
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Hood Pin: n/a
Windows DOWN: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
WIRING COLOR CODE
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Apr 07, 2007 | Clarion DRX5575
Kocom KDC-330 Digital Camera Logo
1,829 people viewed this question
Top Kocom Cameras Experts
Are you a Kocom Camera Expert? Answer questions, earn points and help others
