Question about Olympia Lands Phones
4310-WONT MEMORISE LONG DISTANCE ACCESS CODES ALSO CAN MORE THAN 16 DIGITS BE ENTERED
  • 19,396 Answers
Unfortunately the manual for your product is not available in English, so I can only give you general instructions.
The 16 digits limit is normal and depends on phone specifications. 16 is the maximum size for stored number.
If the number is not being stored , that may happen because you are using a number that the phone does not recognise as valid. Probably this phone does not allow call transfer to this kind of number.
Ensure that you are following thoroughly the instructions, if the phone is not storing settings , then the number entered is not valid.
Test distance access code with a different number.
Also ensure that you are using the phone in the country where the phone was originally purchased, or the phone may not work as it should.
Posted on Sep 05, 2009
Where can i find the 16 digit code to unlock a modem? i already have the unlocking code and flash code but it keeps saying enter 16 digit code. pls help
Check on the bottom or back of the modem. You can access your modem via it's IP address which is also on the back or bottom of your modem. Type that IP address into the address bar of your browser. You may need to reset it which will restore the default setting.
Dec 22, 2016 | Cell Phones
How to Change COS (Class of Service) Password
If you set the all line and set restrictions to no restrictions, you are not restricted from making any calls. I don't think it's the phone system requiring this 4 digit code. Are you sure all your lines are set with the same long distance provider. Did the lines in the dial 8 group require a code. (ie some users had the long distance provider set up their lines to need a code entered to charge calls off to different job codes, so they can distribute the charges correctly).
You should now be able to call 9+1+area code+number, with no restrictions.
Mar 25, 2014 | Nortel Norstar M7310 Display Phone
4310 john Deere e hydro
Check to make sure the brake is completely return to the off position, all the way back, it cancels the cruize when depressed
Mar 12, 2014 | John Deere Garden
I want to unlock my LG GR500, can you help?
Welcome to Fixya
Try this torubleshooting procedure
1. After turning on your mobile phone, press: *#865625#
2. Press Yes to continue.
3. Enter the 16 digit Subsidy Unlock Code
4. Enter the 16 digit Subsidy Unlock Code, again. Device should say: "Network Lock Deactivated" Phone may automatically reboot
*The 16 digit code can be obtained by calling the Mobile Operator Customer Care Department and given the representative the IMEI number. In exchange they will give you the Subsidy Unlock Code. Alternatively, you can go online and seek out a Subsidy Unlock site.
To obtain the IMEI number press *#06# on your mobile device.
Thank you for using Fixya! Enter the 16 digit Subsidy Unlock Code, again. Device should say: "Network Lock Deactivated"
Dec 18, 2010 | LG Xenon GR500 Cell Phone
Very often the photos are not showing on LCD screen and not memorised on CF
hi,
i suggest you upgrade your firmware for your camera. this usually resolves some issues regarding some firmware bugs.
this is the site. its a whole lot more because you can even find downloads ad stuff here.
http://www.nikonusa.com/template.php?goingto=dtc_options&cat=1&grp=2&productNr=25211
hope this helps
Jan 22, 2008 | Nikon D1X Digital Camera
Kyocera mita long distance faxing
Kelly,
I hate to point out the obvious, but make sure your phone line has long distance service, then make sure you are dialing 1 before the long distance number. You didn't mention if you had to dial 9 to get out. If you do, you may have to enter a pause between the 9 and the 1. What model Kyocera Mita do you have? The fax kits vary by model, and I can look up any issues with your particular fax kit given the extra info. Thanks.
Bryan
Don't forget to rate your answers please.
Nov 27, 2007 | Office Equipment & Supplies
Fax
An access code is normally set up by a person or company to prevent long distance faxes or phone calls by unauthorized users. The access code is a series of numbers to access long distance service. Check with your employer for the long distance code or check with you carrier to make sure that this service has not been put on your line by mistake.
Oct 08, 2007 | Brother IntelliFax-2820 Laser Fax
Only lets me enter 7 digit number
Use the chain dialling feature. Program the 1-800 into a quick dial key and chain dial using it.
Sep 05, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
What are the flash metering modes?
The DiMAGE A1 employs three metering modes; ADI (Advanced Distance Integration) flash metering, Preflash-TTL metering and Manual. The ADI flash metering mode combines distance information from the autofocusing system with information from a pre-flash exposure. On the other hand, in Preflash -TTL metering mode, the exposure is calculated with a pre-flash only. Flash emission control is manually selectable in three levels from 1/1, 1/4, 1/8, 1/16. Pre-flash TTL metering must be used when a diffuser is attached to an external flash or a filter to the lens. Attachment of those accessories may cause error in distance information necessary for ADI (Advanced Distance Integration) metering due to reduced entering light. While manual output control is active, pre-flash will not burst.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
The ADI flash metering mode combines distance information from the auto focusing system with information from a pre-flash exposure. On the other hand, in Preflash -TTL metering mode, the exposure is calculated with a pre-flash only. Flash emission control is manually selectable in three levels from 1/1, 1/4, and 1/16. Pre-flash TTL metering must be used when a diffuser is attached to an external flash or a filter to the lens. Attachment of those accessories may cause error in distance information necessary for ADI (Advanced Distance Integration) metering due to reduced entering light. While manual output control is active, pre-flash
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Lands Phones Logo
Top Olympia Lands Phones Experts
Computer Repairing
Computer Repairing
ray gallant
Jose Ma DM.
Jose Ma DM.
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
