Question about Zonet ZSR0104CP (zsr0104cp) Router
I have to repair my connection to get internet
I have a zonet ZSR0104cp router, i use all the time. i have two computers hooked up to it. i just reinstalled xp on both. since i reinstalled i have to repair my connection every time i go any where on the internet and some pages will not display unless i disable and reconnect to the router. when it does go to a web page it takes a long time and some times can not load the whole page. i have a cable internet connection and use firefox. i also can not access the router(192.168.1.1). is there any thing i can do??
  • 556 Answers
Are you running a virus scanner or internet security software?
Is it active and has it been updated recently?
Do you perform periodic full scan of your systems and are they clean?
Do you run any apyware packages?
Are they active and have they been updated lately?
Do you perform periodic scans with them and is your system clean?
Not all virus scanners, etc catch all problems. Some catch different items.
Consider using free online services from some of the security vendors to double check your product. Several to consider
Trend Micro
Fsecure (www.fsecure.com and search for online scanner)
Symantec
Consider free spyware software for additional checks if you have not choosen to purchase a product to do this.
Lavasoft
Spybot
Clean up the issues found and see if the problems are eliminated.
Using the following instructions from the zonet website to get your IP address will also reveal your router's address in the default gateway entry (assuming your computer receives it's IP information via DHCP from the router or has been staticslly configured correctly). This will be the value you utilize instead of 192.168.1.1 to access the router's configuration.
i have to repair my connection to get internet - spacer.gif Q: How can I find the IP address of my computer? spacer.gif A: Windows 95, 98, and ME:
Click on Start.
Then click on Run.
The Run Dialogue Box will appear. Type "winipcfg" in the window as shown then click OK.
The IP Configuration window will appear, displaying your Ethernet Adapter Information.
Select your adapter from the drop down menu.
If you do not see your adapter in the drop down menu, your adapter is not properly installed.
After selecting your adapter, it will display your IP address, subnet mask, and default gateway.
Click OK to close the IP Configuration window.
Windows 2000 and XP:
Click on Start and select Run.
Type cmd then click OK.
From the Command Prompt, enter ipconfig. It will return your IP address, subnet mask, and default gateway.
Type exit to close the command prompt.
Macintosh 8.x and 9.x:
Click on the Apple Menu>Control Panels>TCP/IP.
Select your Ethernet adapter from the Connect Via drop-down menu.
Under Setup, select Using DHCP Server from the Configure drop-down menu, if connecting to a router DHCP server. This is the most common setting when using a router. In this configuration, your computer will be automatically assigned an IP address by the router.
You must reboot your computer to "renew" your IP address.
Macintosh OS X:
Click on Apple Menu>System Preferences>Network>TCP/IP.
Linux:
At the command line type /sbin/ifconfig and you will get a listing of information. Your IP is shown after inet addr.
Posted on Dec 08, 2007
  • david Dec 08, 2007
    Sir, there are several items here and you have provided no feedback as to the results of these specific suggested actions to perform. Am I to assume that none of these items worked including using ipconfig to find the router's address assuming it is not 192.168.1.1 since you indicated you could not access the configuration at that address?
I cant setup my zonet router because i lost the installation cd
Type 192.168.0.0.1 into your web browser to configure your router. Or check devices and right-click your router and click view device webpage
Jan 15, 2011 | Zonet ZSR0104CP (zsr0104cp) Router
Router says limited connectivity
Not a lot of info to go on, but I'll give you my thoughts on it. In my experience, limited connectivity indicates the modem isn't connecting up to the internet. You can reset the modem by unpowering it for a few seconds, then seeing if it will connect, but I'm sure you've already tried that. Could be a faulty modem, but I doubt it. Chances are there's a software incompatibility issue between the modem and the wireless card. Was the zonet working with the card before? If it was, you might have to go into Network in control panel and delete the linksys connection, and have windows redetect the Zonet. Sorry, all I can think of, not a whole lot of experience in this arena, and my routers always worked. Maybe someone will have had the same problem and know the solution, that would be the easiest way to go, of course.
Mar 25, 2010 | Zonet ZSR0104CP (zsr0104cp) Router
How di i log into this router?
point your browser to -> 192.168.10.1
default user and pass is:
user: guest
pass: guest
Feb 02, 2010 | Zonet ZSR0104CP (zsr0104cp) Router
I have comcast and as soon as i hookup the Zonet router zsr0104cp i dont have the internet on either of my computers
If you connect the computer to the modem, it works. but it does not work with the router. You will need to check the settings of the router. For this you will need to access the router set up. Your ISP is comcast. The computer which is online when connected to the router is your main computer. you will need to use that computer to set up the router. Click Here for step by step solutions
Nov 17, 2009 | Zonet (ZSR0104UP) Router
With Zonet ZSR0104CP can't see internet
If the router is connected to the internet then you just have to setup a new internet connection from Network Connections. Select the option for new internet connection. From there read carefully all the options before selecting. And even if you go wrong anywhere, you can come BACK and correct yourself. Select the Router and then give the ID and Password and you will be through.
Nov 02, 2009 | Zonet ZSR0104CP (zsr0104cp) Router
Need Clear instructions on Port Forwarding
This page will guide you. Just choose the appropriate program for which you want the port to be forwarded. The link is:
http://portforward.com/english/routers/port_forwarding/Zonet/ZSR0104CP/ZSR0104CPindex.htm
Sep 01, 2009 | Zonet ZSR0104CP (zsr0104cp) Router
Can not connect to network folders at work
This problem is common if your password has expired. If you suspect that this may be true you can contact your network administrator for help or you can simply change your password and restart and see if you've gained network connectivity.
Jul 19, 2009 | Zonet ZSR0104CP (zsr0104cp) Router
Can't see both computers in my network places with zonet router
U can give the sharing to one of the folders in the PC1 and search the file in the PC2 so that u can transfer the files with the help of network connections
or
The other method is the u can use the PC mover software and transfer the files from one system to other.You can download the s/w from the below link
http://www.freedownloadscenter.com/Utilities/Automation_Utilities/PCmover_Download.html
Regards,
Ayyasam
May 29, 2009 | Zonet ZSR0104CP (zsr0104cp) Router
Everytime i connect to the internet some1 else gets diconnected
It's possible that the router is limiting the number of DHCP connections to TWO.  Check under your router setup page and look for "Maximum DHCP Users" and see what it is set to.
Feb 16, 2009 | Zonet ZSR0104CP (zsr0104cp) Router
Zonet ZSR0104CP (zsr0104cp) Router Logo
356 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
