Question about JBL Encounter 2.1 Computer Speakers
Jarring speakers Hi helping hand! kindly throw light on my JBL Encounter 2.1 table top speakers (the woofer is fine) as to why they are jarring wen i just raise the volume just a bit! it was fine all these months and just before the end of the warranty ( luckily) my alien faced speakers are giving me trouble! I just cant raise the levels anymore....I know u might tell me I 've been raising it too much beyond what my speakers could take and Ive blown it... but honestly i use less volume to mix my stuff... kindly let me know at the earliest what I can do to sort this issue! Thanx a million for ur time and patience GP
4 Suggested Answers
SOURCE: Sound problem with JBL Creature II
I had a problem with the speakers not working properly. The green lights lit, but the amount of sound coming from the speakers compared to that of the sub was much lower.
I decided to take it the speakers apart.
I found that the magnets on the speakers had moved forward slightly in the plastic cage they sat in. I pushed them back as far as they would go, and Hey Presto! working again!
I hope this helps someone!
Posted on Jul 06, 2008
SOURCE: JBL Creature Speakers have very low volume
I had the same problem. Then I read about the volume controls on the right speaker. They are silver buttons for me on the front bottom left and right of the speaker. Now they play really loud!
Posted on Jun 12, 2009
SOURCE: buzzing sound coming from my jbl creature speakers no music
Hi I have had my JBL speakers for 2 years now. Recently the sub woofer has been making a buzzing sound but it continued to work ok. Now the speakers have also stopped working! Is there a solution to this problem? Would be grateful if someone got back to me.
Posted on Mar 10, 2011
How to open the subwoofer unit? There is something lose inside and I don't know how to open it. And I can't find the service manual on internet.
particular model may please be mentioned.
In general, there is two types of packaging
1. The bottom or the back or the front will have screws, you can unscrew and that's it.
2. Some sub-woofers are factory sealed, that means all their panels are glued shut. Now here's the problematic part. Usually you can't open a glued shut sub-woofer without inflicting some cosmetic damage. You may put scratches on it or vice versa.
Still if it is very essential, you may have to use some thin and flat object like a praying knife or a flat head screwdriver. Use them with caution as applying too much pressure at wrong angels may result into ricocheting into your hand / fingers.
May 14, 2014 | JBL Encounter 2.1 Computer Speakers
Remote reset
Yes the woofer and tweeter can be replaced but the woofer needs a recone kit to repair as the whole speaker cannot be replaced without replacing half of the speaker enclosure.... call JBL pro or a service center for help.
Oct 08, 2013 | JBL EON15 G2 Main / Stereo Speaker
My son threw some coins into the subwoofer and i can't get them out.. any suggestions? How do i take it apart??
Subwoofers are accesible only requirng the tools and knowhow processes to dismantle. Observe the bolt straps on the woofer device from which to determine what type of tools are required. Gathering the entire components of tools that would beome useful is required, or attaining a tool box is prior preparation. Woofer s depeding on the location with a vehicle makes accessible. For example, woofers that are within an interior of vehicles require ascertaining the methods of gaining accessibility to perform modifations. Woofers placed in vehicles usualy are emebeded within box containers as sound replication requirement or as means to place within the vehicle without disintegrity.
Feb 20, 2011 | JBL Encounter 2.1 Computer Speakers
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
This thing isn't build with jbl speakers! cuz i repire this sub 2 weeks a ago this sub was build by some kind of unbrand chines speakers..so any one know about that..otherwise i heard jbl use onl JBL brand...
JBL is obviously just putting their name on your product. Just the way it is. They put their name on it, but use inferior parts. It is cheaper for JBL to have other folks make the stuff.
Oct 07, 2009 | JBL Encounter 2.1 Computer Speakers
Jbl encounter - loss of one channel ?
goto your control panel and set which type of speaker you r using
and get proper cable for connectivity to your cpu to speaker
and install matchable audio driver which suited to your hardware
one think you also check for your cpu is that
there are there pin in bihind your cpu one for dedicated to microphone
and other are used to get connected to speakers so let me know what socket pin and color r u using
ok and check correctly for your own knowledge
Nov 04, 2008 | JBL Encounter 2.1 Computer Speakers
Jbl eon
the eon woofer is designed to fit the small frame of the inside cabinet. The EV woofers look too deep to fit but you can try. I do think that the built in amps were set to work with only the JBL woofers so there might be a signal problem using the built in amp. The eon face seems to have their own screws to hold the grill so if they aren't holding you can drop some cement to help hold the srews in place. The front does not allow removal of the woofer so it seems whatever you do should not effect anything.
Nov 02, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Jbl sub woofer
Has nothing to do with the signal or source - it is a failure of the turn on circuit - I repair this amp - can help if you find my add here or I am located on ebay as well. Juust do a search for We Repair JBL and find the model :)
Sep 03, 2008 | JBL Northridge E 250P Subwoofer
Working on tv/playstation 2
You can easily buy RCA conectors and splice them. Remove the 1/8 plug from the speakers and strip the ends and add the RCA connector. I am not so sure of what it would sound like but the ohms may be different.
Nov 06, 2007 | JBL CREATURE II Computer Speakers
JBL Encounter 2.1 Computer Speakers Logo
91 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
