Question about Olympus Camedia C-60 Zoom Digital Camera
Pasotti sergio my camera Olympus Canmedia C-60 doesn't retract lens and comes up code D 1E 1A and doesn't make photo. Thank You
  • Anonymous Mar 20, 2008
    Same problem, camera won't turn on error message, motor sounds weak.
    Genius:
  • 2,985 Answers
The notor system has broken.
Contact Olympus support re repair.
Be warned of the camera is out of warranty the repair will cost nearly as much as buying another more upto date camera
Posted on Dec 09, 2007
Lens will not retract. orange and green lights come on, but preview screen remains dark and lens will not retract when I trun it off.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 02, 2009 | Cameras
Error code D: 5f08 8234
Check the power source, make sure the battery is fully charged.
If you have another battery you can try that other battery and see if the lens is able to extend and retract properly.
Try to reset the camera through the menu. If that does not solve the issue then the camera would need to be sent into Olympus for repair service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Mar 28, 2009 | Olympus Stylus 760 Digital Camera
The lens won't retract
If the lens is stuck out extended you may want to call Olympus Customer Service to discuss repair process and pricing. If the battery is fully charged and the lens still stays extended then this is a clear repair issue as something in the lens assembly has failed. Their telephone number is 800-622-6372 option 2 and then option 3
Dec 30, 2008 | Olympus Stylus 710 Digital Camera
Olympus FE-170 6.0 will not take pictures.
I had the same exact problem.The lens is not extending out fully or correctly, probably has broken or damaged gear or gears and needs to be replaced. Expensive repair done by Olympus. It is a very tricky and fragile repair on your own, requiring micro screwdrivers and soldering tool. I replaced my own lens but it was hard to find one.
Apr 28, 2008 | Olympus FE-170 Digital Camera
Yep. another lens stuck.
i had this problem after putting it in a jug of bear (i know, i know...not so smart)...i washed the camera with a small amount of dishwashing detergent and a good rinse and it seemed to solve the problem for me....not sure if this is the recommended way of dealing with it though.
Oct 22, 2007 | Olympus Stylus 770 SW Digital Camera
Lens won't come out
It sounds like the sensor that tells the camera weather the cover is open or closed has failed or come loose. This is a fairly common issue on cameras with the sliding lens covers. Our shop would charge around $50 in labor to fix this issue if it is that sensor. If a part was required it would be somewhere between $20 and $50 depending on what Olympus charges for the part. Cannot speak to what other shops may charge. David Millier Advance Camera Repair
Feb 22, 2007 | Olympus Stylus 410 / ? 410 Digital Camera
Olympus Mju 400 error code d: 1E12
the lens is with problems and needs to be changed. doesn´t happen when u connect to computer, because when is connected the lens doesn´t move.
Jan 21, 2007 | Olympus MJU 400 Digital Camera
Lens wont retract, makes noises, error code on blue screen D:1E 1A
I posted the same problem on the 15th June and in the meantime I have been playing around with the camera. After holding the camera upside down and gently tapping the back of it, the lens decided to work and retract back into the camera. Not the most technical advice I know but it seemed to work.
Nov 18, 2006 | Olympus Camedia C-60 Zoom Digital Camera
Code on display screen D:
same here, with my Camedia C-60 Zoom Apparently the motor has some problems. Did you take the camera to the beach? It must have caught sand or other kind of dirt in the lens mechanism. These digital cameras all have a fixed solution if they fail to work: they are meant to be thrown away. The people at Olympus also have mortgages going, don't they? Half a year ago it was already impossible to get parts for this camera, also, the memory sticks are not around any more, M-XD cards won't work with it, so, yeah, let's come to the Conclusion: this is intelligent (it can write out parts of machine code) landfill. Cheers, Reinhard
Oct 09, 2006 | Olympus Camedia C-60 Zoom Digital Camera
Olympus Camedia C-60 Zoom Digital Camera Logo
53 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
