Motherboard issue how to conclude that my motherboard is free of errors. when i switch on my system it gets started and a display comes something like "press any key to boot from cd" if i does the same, system hangs and nothing happens. please help me out with the problem and try to figure out whether the problem is with hard disk, ram or motherboard. thanks prabha
  • 790 Answers
Just goto BIOS and change the boot priority to hard disk ... it has changed to cd-rom ... everything is fine not to worry ...
Posted on Dec 08, 2007
I cant use my camera it appers system error how can i fix this?
Please check if the lens can move free. If there is any obstruction, it will stop and the camera will give an error. Also never try to stop the lens from moving.
Start over again. Remove the battery, charge it. Place the battery and the memory card when you are sure the memory card is not in the locked position. Then close the battery door carefully, so the door is locked correct. Then switch on again.
If the error comes back, perhaps the lens is blocked inside (broken gear or something like that) you have to contact the service centre.
Jan 10, 2014 | Sanyo Xacti VPC-S770 Digital Camera
My pc is booting but no display
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
best of luck!
Mar 13, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
My samsung automatic washing machine wa7584c1 is giving me a 1E error why ?
Hello, the error code is due to a water pressure switch error the service manual says
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
p.s also before replaceing the pressure switch assure that the tube that comes off the switch that connects to the tub on the tub end has no debris or soap build up inside the hose this could also make the switch show as an error if the hose had something in the end of it. Thanks again
Aug 23, 2011 | Washing Machines
I have a MS-7101 motherboard with a Pentium 4 Dual Core CPU based system . RAM is 512 MB (DDR) . However , sometime after I have switched on the P.C. , the screen (display) suddenly starts going bad ....
Most of the distorted display related to video memory. MS-7101 Motherboard coming with embedded video controller so your system memory is sharing space for the video memory. Replace and check your system RAM or check RAM module with Memtest , if it is showing error u should replace memory module.
May 10, 2011 | Intel Motherboard
How to troubleshoot a atom motherboard display problem?
Dear sbhrth
Are you sure its motherboard display issue?
Any way please follow these steps,
1)Remove the RAM and clean the leads and again insert it. and start your system.
2)If there is a beep sound then it will be due to the problem of RAM. Then you have to change the RAM.
3)If you are sure that your RAM is perfect, and the display is not coming, Then get a pci display card and insert it into PCI slot and connect the monitor to this output. and Start your system. If the display is correct then the problem is with your motherboard display. Better to use the display card itself.
Mar 05, 2011 | Computers & Internet
Restarting always
Yhe main reason why a system will restart:
1. The system halted due to overheat
2. There was a serious system error cpu/memory
3. Power faliure
4. defective motherboard.
Things to try, Take the fan off the cpu put some thermal paste on it, if there was thermal paste before make sure you wipe that off before reapplying new.
allot of times due to heat and thermal paste seal failure these issues happend and there very damaging to a cpu.
Please try the above steps any questions please retun and ask we have wonderful expert here to help you. Please do conclude by rating all the epxerts that are involved with your issue, Thanks
Jun 30, 2010 | EliteGroup ECS Socket AM2+/ GeForce 8200/...
My cpu green led is glowing but monitor screen is black and keyboard led is continue glowing
There are No display in your system .Pls remove Power cable from CPU and again plug it and start your system.If display still not comes then pls remove RAM chip from slot in the Motherboard and re-install goods one and check it.if still display not come then issue with Motherboard .Its detter call vendor for repair the Motherboard.
Nov 19, 2009 | Intel Motherboard
Dimension 2400 can not power on
If you have no power by pressing the front power button and you have verified that the black connector coming from the power switch on the front is connected properly to the motherboard, then make sure that both connectors from the power supply are connected properly, the main connector and the p4 connector. Reseat both of the connectors to be sure.
If you still have no power and still have the light coming up on the motherboard then I think the motherboard may be bad cause that means something is shorting out the motherboard and not allowing power to go thru it properly.
Mar 08, 2009 | Dell Dimension 2400 Power Supply ** FREE...
Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya:
You can also find helpful exploded view diagrams and order parts by entering your full model number here:
Nov 10, 2007 | GE JVM1350BW/WW/AW/SY Microwave Oven
No beep,No Display on my monitor,only CPU heatsink fan is moving
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
Computers & Internet Logo
259 people viewed this question
David Payne
David Payne
