What is the optimal volume for a speaker box for two Pioneer TS-W26C sub woofers? I know that enclosure speakers have an optimal volume for the boxes, however, I can not find out what the optimal volume would be for this box. I am trying to construct a speaker box for two ten inch Pioneer enclosure sub-woofers, but I can not find Pioneer's reccommended volume for such a box. Any help would be greatly appreciated.
    Scholar:
  • 136 Answers
Try this site very hepfull if you can find all the speakers spec's.http://www.ajdesigner.com/speaker/ajvented.php . if you have the latest pioneer speakers they were designed for small enclosures if you imput speaker code in to google search you should find all the details you need .
Posted on Sep 05, 2009
What size box should i build fro two pioneer 12inch speakers 1200watts each
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches.
Mar 17, 2011 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Jul 27, 2008 | Audio Players & Recorders
If i put the TS-swx310 sub in a bigger box would it get help the sound.......i have a 12'' regular sized box and the speaker is going in a car now???
It is amazing the difference box construction can have on the overall sound of a system. Size is only one factor. Using a larger sealed box may make the sub hit lower, but not necessarily louder. Because the TS-swx310 is a shallow mount woofer, it is designed to run in small enclosure. Putting it in a much larger box could potentially cause damage to the woofer over time. If you want more bass my advice is to use a normal woofer in a box built to spec for it. Generally a ported box will provide more output, and sealed hits tighter. It all depends on the type of music you listen to.
Hope this helps
Please Vote & Rate
Mar 08, 2010 | Pioneer TS-SWX310 Car Subwoofer
I need bow specifications for a pioneer ts-w308f
Hello, The problem with the enclosure is that you purchased a "free-air" sub, which is designed to NOT use an enclosure. You need to simply mount the sub on a baffle (board) that covers the whole entire rear deck of your vehicle, and seperates the inside of the trunk from the cabin of the vehicle. Use sealant to keep the two compartments sealed air-tight and mount the sub on the baffle-board. The other option, is to build a very large box (larger than 3 cubic feet) that would be incredibly huge for the subwoofer, as a free-air, it has a VERY high QTS, and relies on a massive amount of air behind the woofer to allow it to reach low frequencies. The best bet would be to get rid of the free-air sub and purchased a sealed enclosure subwoofer for use in a small (.6-1 cubic foot) sealed box.
Feb 16, 2010 | Car Audio & Video
Where to find the enclosures for PIONEER TS-A6872R
get some MDF board and make them.or buy the 6x9 box cover front with a peice of mdf screwed down good where the speaker will go and cut out a 6x8 hole.
Oct 07, 2009 | Pioneer TS-A6872R Car Tweeter
Replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
May 18, 2009 | Sony SA-WM500 Subwoofer
Building a box, need to know best dimensions for box and port
Hello dirt_digger6,
The specific sub you are asking about would seem to be the TS-302F which is the only 12" 800W Pioneer I have located.
Directly from Pioneer's support knowledgebase:
TS-W302F = Ported: 2.5 Cu.Ft. F3 = 39HzPort: 4  x 6.5 tuned @ 37 Hz with 12 % port noise.
An enclosure 16X18X21, constructed from 3/4" MDF will yield 2.69 Cu.Ft., allowing .19 Cu.Ft. displacement for the sub and port.
There's an excellent "box calculator" located here on the12v.com web site. You can measure the space you have to put the box and fiddle with the dimensions to get close to your ideal volume. There are also calculators on the12v.com which will allow you to calculate a port length based on port diameter (or width/height), enclosure volume, and desired tuning frequency.
Hope this helps.
May 07, 2009 | Car Audio & Video
Recommended vented box volume for tx-w307d4
pioneers are subs u have to be careful with, some subs are made for ported boxes and some arent, check if it is, tham if it is it should b tuned to about 35hz-45hz.
Nov 28, 2008 | Pioneer TS-W307D4 Car Subwoofer
Auto Sub woofer
There are several causes of distortion in an audio setup.
1) Speaker is unable to handle the frequency that it's being fed
2) The volume is too high for the speaker to handle
3) The amp can't provide enough power to drive the speaker adequately.
Either way distortion is BAD & best to be avoided unless you want an excuse to buy a new set of speakers :P
Nov 08, 2007 | MA Audio EHO152 15" 5000 Watts Subwoofer...
Pioneer ts w33c
Recommended volume for these speakers is 1-2 cu ft each speaker. Best materials are marine grade plywood and epoxy resin/matting. decide what space you think you can spare and see if you can make a box that will be about the right size in the space. always try and leave as much space behind the speaker as the speaker takes up from the front. look at the link below for some ideas of the ready made boxes you can buy. http://www.pioneerelectronics.com/pna/v3/pg/album/compare/0,,2076_310069931,00.html the speakers you have will need at least 2 one inch ports each in the back of the box, or equivalent. completely sealed can have bad effects on these speakers at high volume. I personally recommend keeping both subs in a seperate box completely, but a good solid box with a divider will probably work - make sure that no holes of any size exist between the two as this will cause distortion with certain channel set ups and is best avoided although some good results have been achieved with back flow between sub sets - it is a bit too hit and miss to be worth trying. If you need ideas how to fit these into your car so they look good - check out http://www.mtv.com/ontv/dyn/pimp_my_ride if you haven't seen it, check out a few episodes and you will get some great ideas and construction tips. Hope this helps :)
Mar 08, 2007 | Pioneer TS-W33C Car Subwoofer
67 people viewed this question
 Grubhead
Grubhead
