Intermitant loss of power, spinning problem
Hi, First the machine lost power, all lights went out - during spin cycle. I tested power point - o.k. - took agitator out, put it back and it worked, for a while. When it's on the spin cycle now, keeps power but just sits there. I turn it off, leave for a bit, try to spin and it does? It's like it's overheating and cutting out but I can't feel any heat. Can you help please?
  • 76 Answers
Hi Diane, Sounds like the brushes in the motor have gone, is it a hotpoint?
Posted on Dec 09, 2007
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
I have an Amana washer model NAV3330EWW purchased in November 2004. The washer will not drain during any of the cycles, It apparently went through the entire wash without draining after the wash or...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Aug 28, 2011 | Amana Washing Machines
Water collects in the tub after the spin cycle is complete
This could be
  • failure to spin out properly....check that water flows out of the hose properly during drain and spin
  • machine not gaining spin it a top or front load? you haven't said.
  • bowl unbalanced preventing spin speed.
  • inlet valve leaking into machine....try turning off the taps during the spin cycle and see wghat happens
  • Good luck
Mar 13, 2011 | Washing Machines
I have had a new consumer unit fitted and the washing machine tripps the RCD during operation, not sure when because there is no indication where the machine is within its cycle.
Hi again,
You are more up-to-date with 17th and 2 RCD's than we are here in France- also knowledgeable!
It does appear to be a machine problem. What I would do is, going backwards from the final spin, try each cycle to give some indication where the problem lies. For instance there would be no water heating on spin of course BUT both of the motors, main and drain, would be working - the former at its hardest/fastest. If OK through spin, step back to rinse- again no water heating (normally). If that is OK then its pointing more towards the heater element than anything else as both of the motors would have been isolated by the earlier tests. I would not suspect the control board at this point. Obviously if the spin trips it could be either of the motors OR some dodgy wiring showing itself during lots of movement.
I would have the back off WITHOUT POWER(!) and check as much visually as possible.
Here's hoping!
John C
Feb 02, 2011 | Bosch Washing Machines
Maytag Neptune TL clothes still dripping wet after full cycle
Pump out time of 40 seconds sounds good.
No ND error code and you spin up to 850RPM which is max for the machine.
You have no standing water in the wash basket.... I'm scratching my head.
Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached.
""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code.
The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle
I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min. I toggled into Service Mode to watch wash basket RPM. At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle. You don’t have a water valve stuck open or you would flood/over flow of the machine. Did you here the drain pump turn on several times during the Spin Only cycle?
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Ge # wbb4500e1ww stops during fill, wash,spin and rinse cycle intermitenly there is no regular pattern we can follow. We are lost as to what to do
Check your hose end. On your hoses there are screens at the end that goes on the washer, and that screen could be plug enough to intermitent.
Dec 07, 2009 | GE WBB4500EWW Top Load Washer
Washing machine is on spin cycle, and spinning yet
There is a relay switch that is hooked to the timer and to valve that controls the water draining, this relay is worn out or just no getting the signal for the timer. Its a (timer) (relayswitch) or ( valve) Finding which one is easy, a cheap test light well do the trick. Start at the source of power and work your way to the valve when you stop getting power you are at the problem.
Aug 09, 2009 | Texas Instruments TI-83 Plus Calculator
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
Indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Oct 09, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
