Question about Western Digital Caviar 500GB Internal SATA Hard Drive
My win2k adv server with sp4 finds 137gb space on a 250gb sata int hdd. how can i utilize full space where i m using 945 m/b
    Problem Solver:
  • 15 Answers
It's complicated to explain, but basically, you never get the full amount of space on your hard drive. For instance, a 320gb drive will always provide you with aprox. 298gb of space. However, your 137 vs 250 is a bit extreme. Is this a new hard drive? Have you made sure you have properly formatted and partitioned the drive? If this is a used drive, the previous owner may have it partitioned to use only part if the drive, so in this case I would try and format it.
Posted on Sep 05, 2009
I have 250GB segate internal hard disk but framework is corrupt how i upgrade or recover my date (Disk not detected)
if its not detected this solution maybe crazy but sometimes it will work.. cover the hdd with polythene (air tight) and keep the hdd inside the refrigerator - freezer for 4 - 6 hours and try to connect as secondary hdd (not master) in linux os installed computer and try to recover the files.
Aug 16, 2013 | Seagate Barracuda 7200.12 250GB Hard Drive...
Formatting WD SATA 500GB AAKS in larger than 137GB
The best software that can fix this problem is "Power Quest Partition Magic".It works like a dream for drives of any capacity!
Oct 11, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
Hard disc test failed, boot device not found, couldn'f find 2 HDD'S on system. These are my error codes
Most definitely. If the drive failed a S.M.A.R.T. test or DFT (drive fitness test) then replace the drive and re-install your OS, drivers etc.
Jan 26, 2013 | Toshiba HDD2J95 250GB 5400 rpm 8MB Buffer...
Hdd detecetion proublem on 845 motherboard
845 chipset dont support sata devices and this is common problem that if unsupported device is forcefully bieng tried to work its goona happen sata support started from865 chipset u are lucky that ur hdd is getting detecting
Jun 11, 2010 | Computers & Internet
My Hard Drive is 250 GB but I only see 137GB
Windows xp has a max Hard drive limit of 137GB, so what you see is totally right.
Windows XP did not support 48-bit LBA for ATAPI disk drives, which is what larger drives needs.
The service packs do address the problem but you need to have a copy of windows xp which includes at least service pack 1 on the installation.
The problem is when you install from your original disk, it doesn't include the service packs, so by the time you have got the system up and running the hard disk space has already been allocated.
Bios update wont help
controller card won't help either
Possible solutions:
If you can get hold of a new version of XP which includes at least service pack 1, you can re-install with this disk and it should find all your hard disk space
or
You can do what is called 'slipstreaming', this is when you burn the original XP disk and the service packs together on one disk, but it does take a bit of working out.
here are a few links which may help you more:
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
http://support.microsoft.com/kb/303013
hope this al least sheds a little light on the problem
Bri
Feb 02, 2009 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Adding additional drives to an MSA20 unit,
1- Turn Off MSA and server
2- Insert new disks
3- Turn On MSA first then server
4- Access ACU and new HDD will be listed
Nov 21, 2008 | HP StorageWorks MSA20 (0808736947138) Hard...
Add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
Aug 30, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
Trying to format a 500GB HDD at full capacity
check your bios if the disk is recognized as 500gb first. if it is not recognized, update your motherboard bios. most updates are available in their manufacturers site.
Western Digital Caviar 500GB Internal SATA Hard Drive Logo
224 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
