Question about Refrigerators
Our Freezone fridge keeps getting very wet inside. The temperature seems to be getting low enough and I have turned it up but I am still getting lots of water. Any ideas
This happened to me two just before i moved from alicesprings to wagga wagga its jut the sel in the upper dooor u cant see it but my dad works with people who fix these types of things hope i can help allyson
Posted on Sep 05, 2009
Hi ive hoover hrfa54w fridge freezer just over a year old. Ive noticed freezer is starting to defrost sometimes the freeze again....its in a holiday cottage so often in a very cold ambient temperatur
Ambient temp will cause the thermostat some confusion. There's probably nothing wrong with the fridge, my freezer doesn't like being in the outhouse. Only alternative is only switch on when you are there or move it to a cupboard where you could put a low output source of heat just enough to keep it happy. Then get it out when you are there?
Jan 25, 2015 | Hoover Refrigerators
Why doesnt the refrigerator and freezer not get cold enough?
You need to check a few things -
1. settings for the temperature are not set too low. Not cold enough.
2 there is no leakage through the door seals.
3. there is not too much ice formed inside the freezer walls. Needs defrost.
4. the fridge is not overloaded with stuff - not enough capacity to cool things.
5. Not enough free space behind the fridge to allow air movement for coils to cool
Please provide more details of the problem if above not helping. For example model number, is the problem happening both in freezer and refrigerator settings. Get a fridge thermometer and monitor temperature in both sections. should be 4 deg C in fridge and -18 deg C in freezer after stable operation.
Apr 23, 2014 | GE Refrigerators
Zanussi freezone fridge freezer
Try adding freeon made for refrigerator. Can get at any hardware store. Hope this help.
Sep 09, 2013 | Microwave Ovens
Refrigerator not cooling
the damper vent door fan that blows the cold air from the freezer into the refrige compartment is bad,these are known to go bad a lot of the time,you need to buy the whole damper vent door/motor together
May 02, 2012 | GE Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Frigidaire gallery refrigerator ice maker doesn't turn off...no plastic signal bale arm?
Good day!!!!
When working properly, the thermostat turns the compressor on and off. Once the thermostat turns the compressor on, it will run until the temperature inside the refrigerator is lower than the setting of the thermostat. Make sure that the refrigerator has enough air clearance on all sides. Refrigerators with a condenser coil grid on the back of them need room to radiate the heat away from the coils.
Verify that the door light switch is working properly. Push the switch with your finger to verify the light is turning off. If the light stays on, it will actually warn the interior of the refrigerator. Fix or replace the switch if it is faulty.
Modern refrigerators that have a lot of storage and large freezer compartments run for longer periods of time. They also start and stop very frequently to maintain an even temperature. This is especially true if you have just put a lot of warm food in the refrigerator, or if it is very hot and humid. It can take several hours to get back to the cool temperature you have it set for after putting a large amount of food in it.
If the compressor is not shutting off when the temperature inside the refrigerator is cold enough, you may have a bad thermostat. You may also have the temperature set too high in the refrigerator. Try adjusting the thermostat to a lower temperature. If this turns the compressor off, you had it set too high. With the help of a refrigerator thermometer, you can find a more ideal setting that will keep your food cold, but not so cold that the compressor is always running. If raising the temperature setting doesn't help, it may be a problem with the thermostat and you will need to replace it.
If your thermostat is working properly, there's a chance that you have low levels of refrigerant in the sealed system. If this is where the symptoms lead you, you need to contact a professional appliance repair person. Only an EPA certified technician can legally work on a sealed system. If you attempt to do work on this system, you will void the warranty.
If this is a new refrigerator, it will run for a long time, almost constantly, before it gets cooled enough to stabilize the interior temperature. Allow up to 24 hours for it to stabilize. The refrigerator should be at least one half to two thirds full. This will help to maintain a stable temperature inside the unit. The cold items inside will help to keep an even temperature inside after the door has been opened and closed. Some people prefer to keep a lot of stuff in the refrigerator as ballast, even jugs of water. This helps to maintain temperatures inside so that when the door gets opened and closed often, it doesn't need to run as much to maintain the temperature inside.
I hope this information will be helpful...Thanks for using fixya...
Aug 31, 2011 | Refrigerators
Why does the fridge part of my zanussi freezone fridge/freezer, keep freezing the food?
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
Jun 24, 2010 | Hoover HCA390FFK Bottom Freezer...
A funny smell and i think it might be the temperature
Adjust the knob to 3 or 4 which would be the midway temperature.
0 would probably be off or close to it. The 7 would be coldest and freeze water.
If this is manual defrost you need to turn it off and defrost it. The frost will keep it from getting cold enough. The buildup is normal from humid warm air when opening the door. You might get a standalone fridge / freezer thermometer (about $5) to tell you what temperature is. The smell may be food spoiling from warm temperature.
Mar 20, 2009 | Danby DDW1805W Designer Series...
My fridge freezer made by samsung is on the blink
These fridges have an evaporator fan motor on both sides - the freezer and fridge side. The freezer can maintain it's temperature because that fan is working fine. I had the same problem, and replaced the evaporator fan motor on fridge side, and it solved the problem. Also, if your fan motor is not working well, or stops working, the evaporator is prone to ice build up, and will prevent proper cooling. You may want to open up panel on fridge side and see if that's the case. Taking a blow dryer to the evaporator and surrounding area (while fridge is off), or letting it sit for a few hours might solve the problem. Ultimately though, it appears as if these fan motors are prone to failure, and need to be replaced.
Dec 19, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
