Question about Dell Latitude D600 Notebook
Hi I have a 1883 lt 28 there is a problem with electrics?
Hi I have a 1883 lt 28 there is a problem with electrics, the back lights, indicators and the fuel pump are not working Ihave checked all the fuses?
fuse box rusty in parts has been changed but still the same. does the van need re-wiring?
    Scholar:
  • 61 Answers
Are you sure this is in reference to a D600 laptop? You've filed your question under laptops and it sounds like a car issue. Please check your question and re-ask it in the appropriate section to get a better chance of a correct response :)
Posted on Sep 05, 2009
The latest figures on Tsunami about when and where and the ***** toll
Tsunamis generally aren't the enormous towering unbroken waves seen in the movies, rather, a wide mass of water and foam resembling a huge broken surge wave with great power behind it.
Historical very destructive tsunamis
  • Sumatra, Indonesia - 26 December 2004. ...
  • North Pacific Coast, Japan - 11 March 2011. ...
  • Lisbon, Portugal - 1 November 1755. ...
  • Krakatau, Indonesia - 27 August 1883. ...
  • Enshunada Sea, Japan - 20 September 1498. ...
  • Nankaido, Japan - 28 October 1707. ...
  • Sanriku, Japan - 15 June 1896. ...
  • Northern Chile - 13 August 1868.
Aug 18, 2017 | Miscellaneous
The rear door on my 2010 highlander says it's open and getting nuisance alarms. I know the sensor is in the locking mechanism, however that part is $400. Where is the door ajar chime so I can remove it?
Here is what another Highlander owner said: "2010 Highlander 4WD: System check panel I indicating the rear door is open, when it's not. Been to dealer 3 times. Car has 6000 miles on it. The rear door open indicator effects door locking ability with key fob as well as continual chime indicating rear door is open in conjunction with turning dome light off and on. Dealer thought it was rear door strike plate. Adjusted accordingly. This was not the problem. 3rd visit to dealer still trying to pinpoint why this is happening so far no luck. Electrical bad door sensor faulty electrical door switch this problem is very annoying and now times consuming 3 visits to the dealer and still no solution. Rear door open indicator initially made to stop by rolling down driver side window at highway speed. Indicator also made to go off when road turns to the left only. <- " moisture causing short in rear door electrical switch" maybe.
something like this. You can remove it.
Mar 29, 2015 | 2010 Toyota Highlander
My archos 28 internet tablet wont turn on... the light comes on and then it goes off after like 7 seconds
LOL, you're up the creek. Never buy a computer that does not have a CD Drive on it because that is what you need now.
May the AC Adapter Power Cord is bad. Some of them have a indicator light on them when you plug them in the wall. Does yours have a light on it and does it light up?
When you plug the power cord in the tablet do you see any lights?
Apr 24, 2012 | Archos 28 Internet Tablet
Basically i plugged in the ac adapter to it, pressed the power button and the power light comes on for 2-3 seconds then the power light shuts off. lcd screen never turned on or show anything, fan never...
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
Feb 19, 2011 | HP Pavilion DV9429US Notebook
Which colour wire to use to hook up a trailer for a Kia Carnival 2000,trailer leads are yellow, green,black,brown,red,white and blue(no connection). just want to know which lead goes to which in the Kia?...
Here is a cheat sheet I compiled that you will find very helpful:
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are Color, Function, Mark on the plug.
Seven wire Trailer plugs
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
Oct 28, 2009 | 2000 Kia Amanti
Dont have a owners manuel so i dont know what the fuse numbers are 93 ford taurus
1996 is all I have. Look on back of cover for fuse chart.
Location
The fuse junction panel is located to the left of the steering column. To expose the fuse junction panel, remove the fuse panel cover (14A003) as outlined.
Fuse Loc. Number Fuse Amp Rating Fuse Color Circuit Protected 1 — — Not Used 2 5A Tan Instrument Illumination 3 10A Red Left Low Beam Headlamp 4 10A Red Right Low Beam Headlamp 5 5A Tan Brake/Shift Interlock Rear Window Defrost 6 15A Lt Blue Back-Up Lamps/Air Conditioning, Speed Control, TR Sensor 7 10A Red Starter Relay Power, TR Sensor 8 5A Tan Radio Mute, Power Antenna, GEM Module 9 10A Red Anti-Lock Brake System, Central Temperature Monitor 10 20A Yellow Electronic Engine Control (EEC) Relay, Ignition Coil, PATS, Radio 11 5A Tan Air Bags, Alternator Indicator Lamp 12 5A Tan Gauges, Warning Lamps, Transmission Control Switch, GEM Module, Integrated Control Panel Autolamps 13 5A Tan Air Bags, Blower Motor, Electronic Automatic Temperature Control 14 5A Tan Light-Out Module 15 10A Red Multi-Function Switch (Turn Signals) 16 — — Not Used 17 30A Lt Green Front Windshield Wipers/Washers 18 5A Tan Headlamp Switch Illumination 19 15A Lt Blue Rear Window Wiper/Washer 20 5A Tan Radio Memory, Phone, Remote Anti-Theft Personality (RAP) Module, Integrated Control Panel (ICP) 21 20A Yellow Cigar Lighter 22 5A Tan Power Rearview Mirrors, Antenna, Decklid Lamps, Autolamp 23 5A Tan Generic Electronic Module (GEM) Power, Remote Anti-Theft Personality (RAP) Module, Passive Anti-Theft System (PATS) Module 24 5A Tan Integrated Control Panel, Radio, Speedometer 25 10A Red Diagnostics (Data Link Connector) (DLC) 26 15A Lt Blue Decklid Release 27 10A Red Battery Saver System 28 15A Lt Blue Stoplamps, Speed Control 29 15A Lt Blue Multi-Function Switch (Hazard Lamps) 30 15A Lt Blue Highbeam Headlamps, Daytime Running Lamps (DRL), Instrument Cluster 31 5A Tan Tail Lamps 32 5A Tan Heated O/S Rear View Mirrors, Integrated Control Panel (ICP) 33 5A Tan Power Window and Lock Switch Illumination 34 — — Battery Saver Relay 35 — — Driver Unlock Relay 36 — — Rear Defrost Relay 37 — — Interior Lamp Relay 38 — — Driver Power Window Relay (One Touch Down) 39 — — Accessory Delay Relay
Apr 09, 2009 | 1993 Ford Taurus
1995 chrysler lebaron
Here's what mine says- for a 95 Chysler LeBaron GTC Convertible. I didn't see anything about a fuel pump, but maybe it's connected to something else? I dunno. Good luck. Here's the info at least.
1 HTR-AC 30A, 2 POWER WINDOWS 30A C/B, 3 PWR SEAT, LKS, TOP 30 A C/B, 4-BLANK, 5 BACK-UP LAMPS 20A, 6 TURN SIGNAL 20A, 7 REAR WIPER 20A, 8 ILLUM LAMPS 5A, 9 INTERIOR LAMPS 10A, 11 CIGAR LIGHTER 20A, 12 RS AMO 20A, 13 INTERIOR LAMPS 10A. 14 BOD COMP MESS CTR 5A, 15 SPEED CONTROL 2A, 16 GAUGES AIRBAGS 5A, 17 STOP LAMPS 18 HEAD LAMP RT-LOW 10A, 19 HEATED MIRRORS 5A, 20 AIRBAGS 5A, 21 STOP LAMOS 20A, 22 HORN 20A, 23 RT-TAIL LAMP-EUR 5A, 24 LT-TAIL LAMP EUR 5A, 25 HEAD LAMP LT-HI 10A, 26 HEAD LAMP RT-HI 10A, 27 RADIO 104, 28 FRONT WIPER 20A
Mar 29, 2009 | 1995 Chrysler LeBaron
I need to wire a towbar to my lt 28 but have no wiring info
Trailer socket pin1 (yellow) to left hand indicator (Black/White) at L/H Lamp, Pin2 (blue) to fog (Grey/White) at R/H Lamp, Pin3 (white) to Chassis Earth, Pin4 (green) to right hand indicator (Black/Green) at R/H Lamp, Pin5 (brown) to right hand side light (Grey/Red) at R/H Lamp, Pin6 (red) to brake (Black/Red) at either Rear Lamp, and finally Pin7 (black) to left hand side light (Grey/Black) at L/H Lamp.
Mar 25, 2009 | 2004 Volkswagen Eurovan
Dell Latitude D600 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
