Question about Dual Electronics CECT P168 Cellular Phone
I am unable to change connection Network Setup > SIM1 network setup > Preferred mode I am stuck in "WLAN only". When I select "GSM" or "GSM preferred". The phone states "mode switching" and then "unfinished". I also have the "Not allowed to dial".
  • 4 Answers
Guys I had the same problem with the k599 Sciphone and none of the solutions found on the internet helped me. New chinese models tend to restart after testing is over and this results in turning the wifi application on. So I spent many hours on thinking how to bypass this function and this morning I woke up with an idea that really worked!! The steps are quite similar with the ones followed to debug older models:
put 2 chips on cell
Disable WLAN.
1-enter in factory mode *#3646633#
2-go to RF Test Tool
3-choose GSM, confirm OK!
4-go to Power scan
5-Select Band DCS1800 click OK
6-the cell frozen
7-wait for 3 minutes testing
8-while testing connect to a pc using the USB cable (do NOT select ANY of the options appearing on the cell screen)
9-Click the CENTER button of the cell until you go back to principal menu
10-go to settings/network settings and choose GSM Preferred or any other option (except WLAN only!!)
In this way the cell does not reboot, and the wifi application stays off, so the option can now be changed...
Hope this helps!
Greetings from Greece!
Posted on Sep 11, 2009
  • imothep Jan 22, 2011
    It worked with my airphone no.4, except the code to enter engineer mode was
    *#33*#
    thank you
HI....I had this problem too, and i was so mad, but i went to my computer and google all kinds of answers and i finally found it....just go to this page and is gonna tell and show you pictures of how to put your mode back to GSM preferred.
I hope it works out for you....thanks
Posted on Dec 19, 2009
  • arthur kam Jun 15, 2013
    it helped me to retaure my phone settings, THANKS A LOT !!!!!!!! guy you're the best. the WLAN mode is now off i can now make calls.like we say in french : MERCI BEAUCOUP !!!!!
  • 520 Answers
I have the solution/fix for not allowed to dial
the method has already been posted if you havent seen it
email at tat24me@yahoo.co.uk 100 % tested
some phones need slight variation to posted method just email me
Posted on Sep 06, 2009
  •  Adi Crisan
    Adi Crisan Nov 18, 2012
    I have the same problem on Riviera R21 Dual sim phone, but when I try to enter the engenier code, not allowed me to tap more than five caracters. So I can introduce the code. Please help!
    Problem Solver:
  • 4 Answers
I think you have only web setting not gprs setting.please tell ur service providers name too
Posted on Sep 05, 2009
3 Suggested Answers
  • 4 Answers
SOURCE: "Not allowed to dial" new c5000 wi-fi phone
put 2 chips on cell
Disable WLAN.
4-go to Power scan
6-the cell frozen
Hope this helps!
e-mail me to akiss_bd@hotmail.com if any questions..
Solution #1 work on the Voyager T737B phone as well. I had the same issue and now I can make calls. Thanks.
Posted on Sep 14, 2009
I cannot dial out I Problem with the Cellular Phones I cannot dial out I get a message Not allowed to dial. Also in the upper left I see wlan on I go to network setup then Preferred mode select GSM...
Please try this and let me know if it works.
  1. Change to flightmode.
  2. Then power off the device.
  3. Restart it and change to normal mode.
Also do a factory reset. The default passcode is 1122.
Apr 14, 2011 | Cell Phones
Blackberry w9700 dual sim. it says "not allowed to dial." how fix this? :(
You should be able to reset your phone by taking the following steps:
Turn on your phone, and go to the dial screen by pressing the GREEN phone icon.
In the dialing screen type the figures *#3646633#
The phone should go into engineer mode. Scroll to RF (radio frequency) test tool, this is the 10th option and will be in the second screen.
Select the RF(radio frequency) test tool option and then select the GSM option.
When a message appears hit ok to verify.
Go to the power scan option then select the band option. Click on the right arrow till you see DCS 1800 . Press OK.
The phone should enter into scan mode, wait a few minutes until it appears to have stopped, if it hasn't stopped within a 10 minute time frame proceed to the next step.
Plug the phone into a computer via a USB connection.
You will see the following options.
  • Mass storage
  • Webcam
  • COM port
  • PictBridge
Ignore all choices (!) and press on the RED (cancel call) phone key.
The phone should power OFF at this point.
Switch the phone back on and go into the settings menu
Select network setup
Select prefered mode, select GSM preferred and press OK
This step is crucial. If the change does go through you'll see mode switching to GSM, then to OK.
If it goes through smoothly go to Settings again, and click on 'Restore Factory settings...
If it the phone doesn't accept the setting you'll see mode switching then it will display UNFINISHED.
If you see that message, please go back to the first step and do everything over again. The definition of madness is doing the same thing again and again and expecting different results. But it's worth a try.
You'll be asked for a password. The password is 1122. If that doesn't work try 1212, 0000, 8888, or 1234.
A message will appear. Click Yes.
When the phone starts up again, you'll see a Chinese message. It's asking you to click on the screen for screen calibration. Click on the touchscreen.
Once that's done you'll be shown to the main menu.
Oh No! It's In Chinese!
Fear not...
To change the language back to English, just go to SETTINGS (the gears/cogs icon).
Then choose menu item 4, then 3 and you'll be able to choose English.
Still more steps...
Go back to SETTINGS, then NETWORK SETTINGS, then click on SIM1 network setup (or SIM2 network setup depending on which slot you previously put into WLAN Only).
There you'll be shown two choices: Network Selection and Preferred mode.
Make sure that Network Selection is set to AUTOMATIC and not MANUAL. If it says MANUAL, go in and change it to AUTOMATIC.
As for Preferred mode it should say GSM Preferred. If not please start the beginning again.
Dec 03, 2010 | Dual Electronics CECT P168 Cellular Phone
I have a chinese iphone clone, I68 3g. It has a problem i'veseen mentioned alot on this site, where it reads "not allowed to dial" when i try to make a call. The setting is stuck in wlan only....
Hello. you can try *#337# and then the phone wll reboot. If not fixed then try:
01. Make sure two SIMs are online with good coverage, WLAN switched off.
02. Press the "call"-button and type in *#3646633#
03. The phone shows "Engineer mode" with a menu of 10 different items.
04. Go to No. 10 "RF test tool", using the up/down button at the left side of the mobile.
05. Choose "GSM"
06. A message shows up "Wifi....blabla", just confirm with OK
07. Choose "Power Scan"
08. Select your local GSM frequency (an eisai Cosmote bale GSM900) and press OK.
09. The mobile will freeze now, because its adjusting itself. Leave it like this for about 2-3 minutes and wait !!!
10. Connect your mobile via USB cable to a PC, DO NOT CONFIRM any connection mode at your mobile, just and ONLY connect the cable!!!
11. Press the Menu button (second from the left, the one with the seven small dots on it) until you you the main menu with the 12 icons on the display.
12. Go to "Settings" -> "Network Setup" -> "SIM1 network setup"
13. Go to "Preferred mode" and choose "GSM preferred"
14. The mobile will switch to your selection, but the message that it will stay on display. Do not press anything else, just wait for about 10 - 15 seconds.
15. Disconnect the USB cable from the phone, it will show you that it has switched to your selection.
16. Get back to main menu, switch off and restart the mobile
Nov 16, 2010 | Cell Phones
Have ablackberry 9630 dual sim china cannot
"not allowed to dial" problem
--> SOLVED :dance2:
Hello everybody, after playing arround for a while, collecting a lot of other information from the net, I got the problem solved with my phone:
02. Press the "call"-button and type in *#9646633#
05. Choose "GSM"
08. Select your local GSM frequency (in my case DSC 1800 for Germany) and press OK.
11. Press the Menu button (second from the left, the one with the seven small dots on it) until you are at the main menu with the 12 icons on the display.
12. Go to "Settings" --> "Network Setup" --> "SIM1 network setup"
13. Go to "Preferred mode" and choose "GSM preferred" or "GSM only"
14. The mobile will switch to your selection, but the message that it will stays on display. Do not press anything else, just wait for about 10 - 15 seconds.
16. Get back to main menu, switch off and restart the mobile --> DONE. :smoke:
I hope my "weekend job" is helping a lot of other people to get rid of this annoying problem. Please bomb your supplier with emails, so maybe we do get a general solution to this problem. Next I will check why I do not get the "Opera Mini 3" working, maybe an update is necessary first.
Nov 17, 2009 | Cell Phones
M001 Phone when trying to make a call it says : NOT ALLOWED DIAL"
This is for another similar clone marked with the "vaio" name but it might be useful to someone out there. I found that by following solution one above (thanks Mrfixit) to step 6 as below and then following the second part of what I found at http://chinamobiles.org/archive/index.php/t-16088.html worked for me. I reproduce the steps below:
1. make sure to have 2 sims in phone(do not use 3g sims) 2. make sure wlan is disabled 3. enter engineer mode (type in *#3646633# 4.scroll up not down to number 10 RF test tool 5.choose gsm touch ok verify ok touch power scan 6.select band dcs 1800 press ok phone will go to test looking for DES(frequencies) wait until phone crashes or seems inactive
BUT THEN
Sep 22, 2009 | Cell Phones
None of published solutions does help (mine = Cesim A9530)
"not allowed to dial" problem with Cesim A9530 --> SOLVED
Hello everybody,
switched off.
items.
side of the mobile.
05. Choose "GSM"
cable!!!
the display.
only"
10 - 15 seconds.
--> DONE.
Sep 13, 2009 | Dual Electronics CECT P168 Cellular Phone
put 2 chips on cell
Disable WLAN.
4-go to Power scan
6-the cell frozen
Hope this helps!
Sep 03, 2009 | Dual Electronics CECT P168 Cellular Phone
"not allowed to dial"on f003 phone
hi mate,just follow these instructions 1. make sure to have 2 sims in phone(do not use 3g sims) 2. make sure wlan is disabled 3. enter engineer mode (type in *#3646633# 4.scroll up not down to number 10 RF test tool 5.choose gsm touch ok verify ok touch power scan 6.select band dcs 1800 press ok phone will go to test looking for DES(frequencies) wait until phone crashes or seems inactive(can take 3 to 15 min) press the end button (red one) phones with one middle button use that one phone will go off turn on phone and it will be reset to flight mode....(you can try to make call to verify,phone wil say cannot make call,not, not allowed to dial like before) go to settings and network setup,sim1 network setup,prefered mode and select gsm prefered...(phone will now change mode unlike before saying unfinnished) try the phone to make a call (should be no prob now) not finnished though .... go into settings again select restore factory settings (password 1122) wait for phone to restart...now its all done .....now you can change your tones and turn wlan on etc do not for any reason select wlan only or gsm only again...
Jul 19, 2009 | Dual Electronics CECT P168 Cellular Phone
Mi F003 show the error NOT ALLOWED TO DIAL tis is a video of the error: http://www.youtube.com/watch?v=bhJj21J6z_M Thank´s
put 2 chips on cell
Disable WLAN.
4-go to Power scan
6-the cell frozen
Hope this helps!
email me to akiss_bd@hotmail.com if any questions
Jun 30, 2009 | Dual Electronics CECT P168 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
996 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
