My CPU's star button does not work on single pushing...i have to keep it pushing for a second or 2 for my computer to start. what is the problem...how can i repair it..?
  • 3 Answers
Bro it is beacause inner spring of swithches becomes loose aftera certian time.jst buy a new switch from any computer shop.jst replace it with new one.it will work properly
Posted on Sep 06, 2009
Power button lock icon keeps popping up on screen. tried to push reuird buttons to fix. buttons on monitor are not working properly.
Push and hold your monitor's POWER button until the monitor shuts off completely.
After it is shut off, press the POWER button again to turn it back on and the lock should be disabled.
Sep 04, 2011 | ViewSonic Va2431wm LCD Monitor
Computer code A047 how fix the probleme
To clear the A047 code:
1. Re-enter diagnostics until you see PCM?
2. Keep pushing and releasing the LO button until you see ACP?
3. Push and release the HI button and you will see ACP DATA?
4. Keep pushing and releasing the LO button until you see ACP CLEAR CODES?
5. Push and release the HI button and you will see ACP CODES CLEAR.
6. Wait 3 seconds and turn the ignition OFF.
May 08, 2011 | Cadillac STS Cars & Trucks
How do I adjust the time on a 2005 yamaha roadstar digital clock?
With the key on.......
1) Push the select button and reset button together for at least two seconds.
2) When the hour digits start flashing push the reset button to set the hours.
3) Push the select button and the minute digits will start flashing.
4) Push the reset button to set the minutes
5) Push the select button and release it to start the clock.
Dec 14, 2010 | 2005 Yamaha Road Star Midnight Silverado
Push Button and Computer fan starts then immediately shuts off (1 Second) .Yellow light on front does the same comes on 1 second then off .Nothing else happens . It is a Dell Dual Core 2 fans.
chek your power unit or the cpu fan working or not if the cpu fan is not working computer will turnoff immediate to save it you better show you computer for technician soon
please rate this solution.....
Apr 11, 2010 | Dell Inspiron 531s Desktop Computer
How do you set the clock on a 2006 royal star tour deluxe?
Select the clock (push the "select" button for at least 2 seconds).
Push both the "select" and "reset" buttons for at least two seconds.
When the "hours" digits begin flashing, push the "reset" button to set hours.
Push the "select" button, and the "minutes" digits will begin flashing; push the "reset" button to set minutes.
Push the "select" button to start the clock.
Mar 03, 2010 | 2006 Yamaha Royal Star Tour Deluxe
The computer shutdown and I tried to turn on and
If you are getting through the bios before it shuts down, you may want to make sure that the CPU cooling fan is working and that there is plenty of airflow around the CPU heat sink. Make sure the reset and power buttons are working properly as well. Check that all of your RAM modules and any add on cards are seated properly as well.
Jan 03, 2010 | HP Compaq Presario F500 F700 and G6000...
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
BenQ computer start button doesn't work sometimes
Recommend replacing the switch with a new one. Usually the button is just a cover and mounted on the Chassis face. The real switch is behind the plastic button. You'd probably have to remove the front panel or go inside the Chassis to get at the switch. The switch will have a couple of wires that connect to the mother board "Start" pins. The wires can be unplugged from there.
Jun 10, 2009 | Computers & Internet
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
Reset button to push after changing oil
turn key on in the run position press gas peddle to the floor 3 times with in 5 seconds the wait ten 10 seconds i do these all the time
Feb 13, 2009 | 2005 Chevrolet Trailblazer Ext
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
