Videoseven LTV30C 29.6 in. LCD Television
Problem for Videoseven LTV30C 29.6 in. LCD Television
Videoseven LTV30C 29.6 in. LCD... momentarily turns on..
By mansikka on Dec 08, 2007
hello there,
Video LTV30C tv momentarily turns on with the blue screen and goes blank, there is sound. sometimes after so many trials of swicthing it off (e.g 20-30 times ) and on the picture can stay normally for some hours before again going off.
Same Problem
Apr 05, 2009
-   i have the same problem. But if you look very carefuly, there is image (as if brightness was desactivated). It seems the back lamp is not getting enough power, because it works for a second and then goes black.
I have no idea how to fix it.-   Guest
Mar 02, 2009
-   I have the exact same problem wit my LTV30C. Turn on the tv but after a while, like 30 secs, the screen goes black. Thers is sound but no picture.   Sometimes it just work good, but if I turn off and on it goes back to black.
-   clinne
Feb 16, 2009
-   Hi all, I have exactly the same problem. When I turn on my TV, blue screen flash for a sec and stay black. Sound is coming out, but nothing else. I tried to conect vga but nothing change. Could you please help. I saw that T1,2,3....could be defected. Could you please be more specific. I very appreciate any help. Thank you very much
-   skleno23
Oct 06, 2008
-   how did you know which was the faulty part?
how could you tell where to solder..?
-   Gynandtonix
Feb 26, 2008
-   I've got the exact same problem, started 2 days ago. I've not been able to get it to keep the picture though. Turn it on, blue screen for a split second, then black. Again, I have sound, just no picture.
To the guy that managed to fix his, was it exactly the same fault as described? If so, whereabouts did you find the dry joint?-   subtopia
Best Solution
posted on Jun 16, 2008
Helpful)
ursem
Rank: Apprentice
Rating: 87%, 4 votes
Hallo,I have 4 x LTV30c with te exact same problem
look to HiGH voltage PCB T1 ,T2,T3 --T8
one of the Transformers is defect
must be 480 Kohm if is more than 100 Kohm
he is defect number of the T is 400SA502055
al 4 LTV30c are now working again
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jan 23, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
One mine, the power supply went faulty, traced problem to a dry joint, soldered it up, perfect!
Solution #3
posted on Jul 25, 2008
Not Rated)
toasterpilot
Rank: Apprentice
Rating: 0%, 0 votes
Thanks to ursem.
In my case the trouble was an break on an solderjoint at one of the 8 transformers.
Was this helpful?
Yes
No
Popular Solutions for Videoseven LTV30C 29.6 in. LCD
Questions and Unsolved Problems for Videoseven LTV30C 29.6 in. LCD
Do you recommend Videoseven LTV30C 29.6 in. LCD Television?
Answer
Answer
The Samsung TV power on relay intermittently clicks on/off, sometimes the TV nearly comes on, and... (More)
Answer
Samsung plasma tv, model PS42S5S. The relay clicks and blue stand by led flickers in sympathy with... (More)
Answer
i have ltv30 c no power i took out power supply there is no light at all does it need replaceing?
Answer
i have video seven lcd tv 20 inch and want to buy more
Answer
alhlfkhlakhflakhflkhalfkhalkfhlkcnl\xnhn'h'oprfnhwdknslk?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Videoseven LTV30C 29.6 in. LCD...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
