Question about Datamax DMX E4203 Printer
Printer fault light lights up each time a label is printed and the alignment is totally out. It prints between two labels and then following after that 6-7 blank labels is generated. HELP!
  • Anonymous Mar 29, 2014
    Can't print but 50 labels at a time i need to print 240. What to do?
Zebra LP2844 pulls labels in before printing
Yes, first of all, it is necessary that the labels are pulled backward (other wise you could not print on the upper part of the label). It appears from time to time that it is a problem - generated by the label itself. Try to use a different label (of size and material) to see if the behavior changes ...
Good luck.
Apr 16, 2013 | Zebra LP 2844 Thermal Label Printer
Using MS Access, I am printing labels to a Zebra 110XiIII printer. The output truncates the label to 2" instead of the 3.5" I have the report page settings saved as. I have been through the setup...
First check printer. Change setting "Print Width" to maximum width, save. Switch off. Hold down pause key while switching on (untill all but power light turns off). the subsequent prints should print across the full width. If this is OK fault is with label format.
If you are using windows printer driver check settings there this can over ride printer settings. If using ZPL the problem is most likely in the label format.
Jul 05, 2011 | Zebra 110XIIII Thermal Label Printer
We are using the Zebra 170XilllPlus printer for printing rolls of labels which they have some preprinted portions on them. However, after we printed the first label of a roll successfully the next and all...
Make sure the pause light is on and press calibrate. See if this calibration solves the problem. If not align the media sensors (top and bottom) to a position that is aligned with the least amount of preprinted data and calibrate again. Print configuration Power on while holding cancel key for 10 seconds. Use the config to help troubleshoot. Make sure the sensor type matches the media. Download user manual at zebra.com.
Nov 04, 2010 | Zebra 170XiIIIPlus Thermal Label Printer
Losing half of top line when printing
Label definition in printer driver may need adjustment. Try calibrating printer, printer on solid green light, hold down feed key & release after light blinks 4 times, (blinks once, twice, three times then 4 times) Download the Zebra setup utility and use it to configure printer.
Sep 29, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Printing a 2.25 in label on Zebra LP2824. Prints
Recalibrate the printer and you should be good to go. Do this by turning the printer off, press and hold the button and turn on the power. When the light flases red let go and it will calibrate, at the end it will do a printout. Reboot the printer and your fixed.
Jul 28, 2009 | Zebra Eltron LP 2824 Thermal Printer
Labelmaker program will not print image in right place
This can drive you nuts! :)
It sounds like you need to adjust the label orientation with the label maker software first. THEN, use regular paper to test your adjustments. Take the print out from a regular piece of paper and overlay it on the label paper. Hold it up to a light and see how the labels align. Re-adjust if you need to. You won't waste your label paper that way.
Also check the settings on the printer as well, making sure you have selected the correct paper or tray (if equipped).
Apr 07, 2009 | HP Deskjet F340 All-In-One Printer
Printer working fine - when it stopped printing in mid of alabel♠
If reinstalling the drivers doesn't work... sadly I think it's time for a new one..!
Mar 30, 2017 | Seiko Instruments Smart Label Printer 430...
Problem with printing labels - not aligned, some missing
This is due to print server problem, you should change the options on the driver.
Nov 04, 2008 | Datamax M-Class M-4206 Thermal Label...
Alignment of print with Labels
Sid
Perform a media calibration as follows: -
Turn the printer off
Press and hold the green button and turn on the printer.
When the red flashes 3-4 times release the button and the printer shoould perform a calibration, then try printing again. Any futher problem with this contact Lancer labels
Apr 15, 2008 | Zebra LP 2844-Z Thermal Label Printer
Datamax DMX E4203 Printer Logo
244 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
pkwc
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
