Question about ASUS X Series A7V600-X Socket A KT600 Motherboard (MOTAS09)
SATA diver Hi, The motherboard driver disk doesn't install my SATA driver. Where can i go to get the driver the SATA controller.
  • JustAndy Dec 08, 2007
    Thanks for the advice.
    How do I find out the exact model of my motherboard?
    Genius:
  • 1,601 Answers
Here is the website download section to get your driver. Let me know how you make out.
http://support.asus.com/download/download.aspx?SLanguage=en-us
use the -4-in one
Posted on Dec 08, 2007
  • Thomas Christopher
    Thomas Christopher Dec 08, 2007
    isnt it the one that this post is listed??
    Thomas Christopher Dec 09, 2007
    go and put in your model number on the top left and hit search. Let me know how you make out.
Whenever i connect a SATA hard disk on my ATI Radeon Xpress 200 chipset motherboard and try to install an operatin system it says no hard disk found please solve my problem
The chipset in your motherboard doesn't have in it a controller for the SATA, it uses an external one - ULI M1573. For it to be activated and the disk detected its driver must be already in the install disk. Unfortunately the XP install disk doesn't have any SATA drivers and the ULI driver isn't included in the original Vista disk . So you must add it on a floppy during install Here it is http://download.cnet.com/ULi-SATA-Controller-M1573/3000-18492_4-159398.html
Aug 23, 2011 | Intel ASUS P5RD1-VM ATI Radeon Xpress 200...
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
Hello ! I have motherboard MS6378 (Microstar) and SATA disk 500 GB. I want to install win xp on it. But I can not. It seems that I need some SATA drivers but can not find it. Do anybody has any...
Ludvik,
The motherboard model that you listed doesn't have support for SATA drives. Are you sure that's the correct model? If so, that's your problem, unless you are using a third-party SATA PCI controller. Then I would need to know the model of that to find the driver you are requesting.
I know this doesn't answer your question, but if it helps please rate positively.
Jul 01, 2011 | MSI MS-6378 Motherboard
Sir, i have an msi n1996 (vt8237r & km400 8237) mother board. My sata 160 gb hdd is not getting recognized in bios. Pl. help. (it is reported somewhare on the net that i have to enter into the...
I enabled SATA support on my BioStar M7VIZ-SATA MOBO (it is km400 and 8237r, like yours) by first installing the VIA SATA RAID drivers. At this point, Windows recognized the device controller but not the 120GB drive. The problem was that the system doesn't support "newer" SATA drives, so I installed a jumper on the disk drive to set it to "150" mode... SATA version 1 compatibility. After that, Windows immediately recognized the drive and mounted the filesystem.
I think it was a Western Digital drive. Other manufacturers have a different name for the same jumper. Also, I read that one type (Samsung?) can only be set to the old SATA standard by getting the drive running in a SATA 2 environment, then using a utility program to adjust the drive's microcode setting.
Good Luck to you.
May 28, 2011 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
Run a sata drive as main boot up drive. Xp on ide cant see new sata drive to format or install Windows 7?
XP installation does not have SATA drivers.
You need to have the SATA driver on a floppy disk and during the XP installation press F6 to install the SATA driver.
The other alternative is to change the BIOS configuration and set the disk controller to IDE or SATA native driver, then install XP.
After Windows installation then install the SATA driver.
Download the driver from the motherboard WEB site.
Oct 10, 2009 | ASUS K8S-MX Motherboard
My PC don't recognize HD Samsung Sata II 250gb
If you mean the drivers for your SATA harddisk, you should have gotten a CD with your motherboard that contains drivers they might be labeled as RAID, sata, or EIDE controller. when you click that it should prompt you for a floppy disk to put the drivers on, you need to put a floppy disk in drive A and then extract the RAID drivers to your floppy, when installing windows press F6 at the begining of the installation and it will act like it didn't work for a minute and then it will pop up asking you something, you press S and then you will be asked to insert your floppy disk. It might ask you if you want to install the x86 or x64 drivers, x86 is 32bit and x64 is 64 bit, if you don't know which you are using it should tell you somewhere on your windows disk. another option is to get a sata controller that isn't part of your motherboard, it would be a pci-e card and it would come with drivers. I don't know where you could download your drivers from because I think the driver you need is specific to the type of SATA controller your motherboard has in it, but I do know that seagate and western digital have sata drivers available as well for their harddrives so I don't know what to tell you. best shot is your motherboard driver CD.
Dec 18, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Dell Dimension 8400 cannot see SATA drive when trying to do clean install on new drive or on old drive. Thought the old drive went belly up but new drive does same results. Setup of drive using western...
It is not a controller problem. When you install XP with a SATA drive, You get to a point on the install where you are asked if you have 3rd party divers to install. You have to hit F6 and point it to where the SATA drivers are. You need the SATA divers for you unit. Dell may have them on their website.
Without the SATA drivers, Xp will not see the serial drive.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 23, 2008 | Computers & Internet
Installing windows on SATA HDD
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Sep 08, 2008 | Soltek SL-75FRN2-RL Motherboard
Samsung sata hard disk detection problem while windows setup
Hi, Typically, Windows XP installer does not provide full support for SATA HDs (drives) nor for all kinds of SATA Controllers (on the motherboard or add-on card). However, Windows XP installer provided a way out by prompting the user to press F6 and load the necessary drivers in the FDD. The diskette containing the drivers may either come from: manufacturer of motherboard; manufacturer of controller; or manufacturer of HD. If none was provided nor available, then perhaps you can DIY (do-it-yourself). More often than not, it is inside the MB installer/driver CD in D:\Drivers\SATA or something like that and copy to a floppy diskette. Alternately, you can download from the manufacturer's website, decompress and copy to FD. When the Windows XP installation CD puts out the message "Press F6 if you need to install a third party SCSI or RAID driver", press "F6" as instructed. Thereafter, press "S" to specify additional device on the next pop up screen. Insert the driver floppy disk in and press enter to continue. If the floppy disk is made successfully, the installation program will ask for selecting driver. Please then select "Motherboard chipset (VIA, Intel etc Serial ATA RAID Controller(Windows XP)".) After the SATA driver loaded, Windows XP will now recognize the SATA HDD, proceed and continue to install Windows XP. If you do not have a FDD, one of your option is to DIY a slipstream WinXP installer CD. This is better explained in this article . Hope this be of some idea/help. Pls post back how things turned up or should you need fur4ther information. Good luck and kind regards.
Sep 22, 2007 | Computers & Internet
ASUS X Series A7V600-X Socket A KT600 Motherboard (MOTAS09) Logo
540 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
