Air conditioner blower flapper stuck on defrost and not blowing out vents
  • 11,896 Answers
This flap is controlled by a vacuum operated actuator. Either the actuator is bad, or there is a leaky or missing vacuum hose for it. Or flap is just stuck
Posted on Sep 05, 2009
99 air conditioner switch
im not sure what fails here.
no air, from all vents. no cold air , no hot air.
tell me what you want.? hot or cold air. (or defrost)
does the blower blow on high?
did you check all fuses. 1st.
if real serious. on DIY repairs, try the FSM.
or a great subs. alldata.com
Jan 01, 2014 | 1999 Toyota Camry
Defrost blower motor runs on all contol settings
Before replacing anything, look for a vacuum leak. Check under the hood for a broken or dislodged vacuum hose.
Aug 22, 2009 | 1997 Chevrolet Monte Carlo
2000 pontiac montana air conditioner driver side vent blow warm air yet passenger side and rear vents blow cold air. sometimes the driver side vent blow cold air. is flapper valve stuck sometimes?
That is correct, the air blend door actuator. "flapper valve" may need to be replaced or cleaned and free from binding up. Good luck and hope this helps. If there is an Auto Zone in your area, they can order the part you need and give you the step by step instructions to removing the old actuator and replacing it if it's damaged. Good luck and keep me posted, be glad to help.
Aug 22, 2009 | 2000 Pontiac Montana
2006 Ford Expedition Limited - A/C blower does not blow in front
check connectors on control head,if look good,replace control head
Jul 05, 2009 | Heating & Cooling
Air conditioner not blowing out of panel vents on 2000 Lincoln Navigator. It's blowing cold but when you cut on panel vents it only blows out on the floor and out of the defrost vents.
sounds like the leakages that operate the flapper are misaligned or bent. if its electrically operated then actuator could be going bad
Jun 12, 2009 | 2000 Lincoln Navigator
1986 Buick Skylark heater blows out cold air
In many cars there is a flapper valve in the ductwork which is sometimes vacuum actuated.If this flapper is stuck or the vacuum line is unhooked or deteriorated,you will not feel any warm air at the vents.Look under the dash for rubber vacuum lines or try moving the selector knob for HOT/COLD or FEET/VENT/DEFROST while revving engine alittle to increase vacuum.
Jan 17, 2009 | 1986 Buick Skylark
Heat wont blow through heater or defroster vents
Had the same problem. believe it or not i changed the gas cap and got heat all around. something about pressure.
Dec 05, 2008 | 1993 Chevrolet Corsica
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
