Question about Kyocera Strobe K612B Cellular Phone
Kyocera phone flashes on the camera and display when plugged in but doesn't charge
Why won't my Hydro by Kyocera turn on?
Make sure your phone is fully charged: plug it in and wait until the charge light (bottom right just below the screen) goes from red to white/green. Then turn the phone on using the power button (top edge of the phone just above the "a" in "Kyocera") by pressing and holding it for 5 seconds.
If the charge light doesn't come on when you plug it in, your battery may not be correctly installed, or you may need a new battery. Hope that helps!
Jul 17, 2014 | Kyocera Cell Phones
Although this camera will work when plugged into the mains and functions normally, it will not work off its battery - I have bought a new batttery and the camera does not seem to be able to charge it -...
The problem is clearly in the charging circuits of the adapter, the only other thing is check the connecting pins on the adapter, "by cleaning the points" if this fails, the unit will need to be dis-assembled for repair or replaced.
Mar 22, 2011 | Kyocera Finecam S3 Digital Camera
My kyocera wont turn on. when i plug it in to
i have had several of these handsets and i have noticed that there are several batteries that will fit into the battery compartment of the phone, however just because the batteries fit, that doezn't mean that it is the correct one. i went online and ordered the battery for this phone model on ebay several times and everytime, i got the same result: the battery fit in the phone, i plug it in to the charger and the phone would light up and say: PHONE IS OFF **** it did not say phone is charging**** when i turned the phone on (with it plugged in) it turned on and everything seemed normal except the battery icon was missing from the right hand top corner of the display. i looked up the kyocera website and looked up the compatibility matrix and it was absolutely 0 help. finally i figured it out because i buy and sell phones on ebay and i received a used phone with the battery in it and it worked, the # printed under the barcode on the front of the battery is 020609606036. i also purchased a brand new handset that was still in factory packaging and i took note of the # on this battery also and it was the same as above but the last two digits are 35. i have not researched any other batteries for functionality on this handset, however, there may be more that do. these 2 OEM batteries i listed above do indeed work in the handset for sure
Sep 15, 2009 | Kyocera Switchback KX21 Cellular Phone
Kyocera wildcard dropped into water and flashes white screen
im unsure if theres a problem with the scree or you mightve gotten a shortage in the phone
May 29, 2009 | Kyocera wild card Cellular Phone
My phone just flashes when I plug it in to charge
take it back to the place u got it most likely it has a warenty lords knows i have traded my in many times
Oct 24, 2008 | Kyocera Strobe K612B Cellular Phone
My camera won't charge
I've got same problem - cant charge the battery. Plug into charger, kyocera red light comes on momentarily, then goes out.
Jan 06, 2008 | Kyocera Finecam SL400R Digital Camera
Kyocera Finecam S5R digital "flash close"
You forgot to open the shooting flash on the top of camera
Nov 24, 2007 | Kyocera Finecam S5R Digital Camera
Won't begin to charge up
I talked to a rep for cricket that deals with Kyocera and he says its fried, and you cant even get the software, no less want to get it to fix it. I will never get a kyocera again as my cell provider nor kyocera gave me a reply to the issue! Anyone with a cricket, get a verizon and have it flashed over, i did that and loving it, everything worked.
Nov 03, 2007 | Kyocera SoHo KX1 Cellular Phone
Kyocera Strobe K612B Cellular Phone Logo
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
