Question about Motorola Radio Communications
I have XTR 446 PMR, 1 unit has become receive only showing handset icon on display.
I apear to have the same thing. The radio that can send a signal has the radio icon on the screen at all times. the one that cannot apear to transmit (or at least not received has not got the radion icon) from the user manual it would appear that the icon should not be on all the time.
They weer working fine haowever they were going off in our pokets and now we have this problem I would imagine it is something that was pressed in our pockets rather than a fault with the radio may be.
Any help would be grately appreciated.
James
Posted on Feb 22, 2010
  • Motorola Master
  • 1,654 Answers
1) Check your radio to be certain it is programmed the same as the other unit. It is possible the interference eliminator code or the frequency has been changed. 2) Also, it is possible the radio is picking up RF (radio frequency wave) from another radio or device in the area. 3) Or your radio is defective.
Check your programming, reprogram if necessary. Change the radios to another frequency and code to see if you can move away from the issue.
Here is a link to the user manual, which may assist you: http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=252
Posted on Sep 06, 2009
I'm searching for a owners manual for Cobra Micro Talk H302015077
it;s a pmr nothing only
its send and transmit on pmr 446 mhz
left volume up down
right 8 channels
call is beep
there could be a subtone on a channel, selective call to reach users with same channel and subtone.
if subtone is off you can hear everyone on the channel.
May 01, 2015 | Cobra Radio Communications
How do I Sync PMR and GMRS/FRS Two Way Radios?
Sorry, these two types of radios are not compatible. PMR operates in the 446 MHz range, and GMRS/FRS are in the 462-468 MHz range.
Best regards.
Mar 03, 2013 | Radio Communications
Motorola XTR 446 talkie walkie is not receiving
Try programming the radios without an eliminator code and see if they work together then. If so, there is something wrong with the eliminator code portion of the radio. Also, check your batteries, switch batteries between the units and see if the problem moves to the other unit. It takes more energy to transmit than receive, so a bad or very weak battery could exhibit a similar problem. The radio icon will illuminate whenever a radio is transmitting or receiving. When the radio is in standby mode, the icon should not be shown. Your radio with the icon on all the time may be stuck in transmit. Check your PTT button to see if it is slightly stuck or depressed. Here's a link to the user guide http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103
Best regards.
Jun 24, 2012 | Radio Communications
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
How do i copy a phone book for the Uniden DECT1560 cordless phone
Kathy,
This should do the trick!
Copying Phonebook Entries to Another Handset:
You can transfer one phonebook entry at a time or all phonebook entries at once.
1) With the phone in standby, press the address book icon.
2) To copy one entry, find the phonebook entry you want to copy, press Menu /Select , and then select Copy.
To copy all entries, press Menu /Select and then select Copy All.
3) Move the cursor to select the handset which you want to transfer the entries to and then press Menu /Select .
If you select Copy All, Are you sure? appears on the display screen. Move the cursor to select Yes, and then
4) The phonebook entries will be transferred to the designated handset. During the copy process, the receiving handset shows Receiving and the ID of the sending handset.
5) When the transfer is completed, Done! appears on the handset.
Notes: • The handsets must be currently connected to the same base.
• If the handset you want to transfer to already has seventy entries in its phonebook, you will hear a beep and Not enough memory in receiving unit appears on the display.
• If the selected handset is out of range or data transfer is cancelled, Unavailable appears in the display, Phonebook listings will not be transferred.
Have Fun!!
Jul 07, 2010 | Uniden DECT15602 Cordless Phone
How do i get rid of the walkie talkie icon on the screen of one phone that is now not receiving. motorola xtr 446 walkie talkie
how do i get rid of the walkie talkie icon on one of the handsets that is now not recieving ?
May 31, 2010 | Motorola Lands Phones
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Understanding and changing the display
it could be missed call just see ur missed calls
May 17, 2008 | Cell Phones
Radio Communications Logo
1,189 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
