Question about Konica Minolta magicolor 2300DL Laser Printer
Sticky label stuck
A sticky label got stuck during printing. I can't get to the label and it prints out a black colume the size of the label in the middle of the page. Anyway I can remove the stuck label? Or is there any parts I can replace to make the printer functional again?
Print dosent stop
u have to create your label at printer properties.
if prints doesn't fix your label, this problem appears.
( for 80x40 cm barcode: open printer properties-printing defaults - label size - new custom size or new label - write your sizes at size fileds- and save)
open your app, and create new file, type your sizes for new file, and print it!
Jun 25, 2013 | Zebra Eltron TLP 2844 Thermal Label...
Zebra LP2844 pulls labels in before printing
Yes, first of all, it is necessary that the labels are pulled backward (other wise you could not print on the upper part of the label). It appears from time to time that it is a problem - generated by the label itself. Try to use a different label (of size and material) to see if the behavior changes ...
Good luck.
Apr 16, 2013 | Zebra LP 2844 Thermal Label Printer
Everytime i print something in a label sized setting it always cuts into short
Before printing try using print preview first and adjust yur settings from there. Or go into control panel select printers and reset to default settings, restart your computer and try again. Good luck.
Sep 09, 2012 | Canon IP2700 Inkjet Printer
When I try to print on a 6x6 envelope on my hp envy 110 printer it tells me it is the wrong size paper. No where is there a setting for a 6x6
Print labels and envelopes
With the HP ENVY 110 series, you can print on a single envelope, a group of envelopes, or label sheets
designed for inkjet printers.
To print a group of addresses on labels or envelopes
1. Print a test page on plain paper first.
2. Place the test page on top of the label sheet or envelope, and hold both up to the light. Check the spacing for
each block of text. Make adjustments as needed.
3. Load the labels or envelopes into the paper tray.
CAUTION: Do not use envelopes with clasps or windows. They can get stuck in the rollers and cause
paper jams.
4. Slide paper-width guides inward against the stack of labels or envelopes until the guides stop.
5. Select the appropriate options.
• On -Paper/Quality- tab select a Plain paper type.
• Click the [Advanced] button, and select the appropriate envelope size from the Paper Size drop down
menu.
6. Click [OK], and then click [Print] or [OK] in the Print dialog box.
If you print from within a program that DOES have that listed (like M$ Word,) then you don't need the limited printer driver to specify the paper size.
Tallon41
Sep 08, 2012 | HP ENVY 110 Wireless e-All-in-One Inkjet...
HP LaserJet Pro 300 M375nw keeps saying paper jam in drawer 2 but there is no paper anywhere.
My problem was the rollers at the top of the printer where the paper feeds out of the unit. I had printed some labels and some sticky material from the labels stuck to the rollers and metal fuser unit. I cleaned off the sticky strips from the rollers and fuser roller and the unit works fine now. You may have to let the printer cycle several times so it turns the rollers so you are sure to remove all the sticky stuff or paper. I also used a can of the compressed gas to spray out all the dust, paper and sticky stuff after I scrapped off with envelope opener.
Jul 24, 2012 | HP LaserJet Pro 300 M375nw All-in-One...
Zebra TLP 2844 stuck intermittently. After pressing green button instead of one labels 2 or 3 labels came out. 2 blank and one printed. Please reply soon.
The feed button is probably just a bit sticky or registering multiple presses...it's likely not a major issue, and it likely has already gone back to normal operation.
Mar 09, 2011 | Zebra TLP 2844 Label Printer
During manual calibration of the Z4Mplus the
Let the printer calibrates itself or have a manual calibration in the printer setup. You can also press the keys FEED, PAUSE and CANCEL, turn on the printer and release the keys when feeding the labels.
Roberto Martinez
Jul 07, 2009 | Zebra Z4Mplus Label Printer
Labels unexpectedly stop printing half way through a job
Located winder further away from printer. Set winder to lowest possible speed setting. Thoroughly cleaned printer to remove any trace of label residue near print head and label cutter (sticky labels with pre-cut patterns are being used). No more problems reported. Will continue to monitor.
Jun 02, 2009 | IBM Infoprint 6700 R40 Printer
I've got a sheet of sticky labels stuck in the printer
Yuck! You will have to remove the pritner cartridge and carefully remove each one. Sounds like your print settings was not set to print labels.
Jan 29, 2009 | Brother HL 1250 Laser Printer
I have an HP 5550 Series Deskjet printer. Only recently, I have encountered difficulty printing labels. I have double-checked the Printing Properties, including label size, label paper size, Avery paper #,...
This printer have the capabilites of sense the size of label, each colomn width.
So, you must set the right size of colomn width, in your application (ms. word) to match label width.
May this help.
Oct 10, 2008 | Office Equipment & Supplies
Konica Minolta magicolor 2300DL Laser Printer Logo
81 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
