Question about De Dietrich Ovens
I have an old de dietrich double oven model no FB2727u1. I ran a pyroclean cycle on the main oven and the clock stopped working before the cycle had finished. The main oven will not open, will not heat up and the circofan will not work, and the clock has stopped. But the small bottom oven is working. Can you please advise me what to do. The oven is 14 years old but I am reluctant to replace it. thank you, Angela Gates
SOURCE: De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
Posted on Sep 26, 2008
barkencoa
  • 3463 Answers
SOURCE: SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Posted on Dec 15, 2008
SOURCE: tricity bendix double oven
My oven's fan is working but no heat what so ever what shall i do
Posted on Jul 24, 2009
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
barkencoa
  • 3463 Answers
SOURCE: Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Posted on Nov 06, 2009
De Dietrich DOD788B is not switching on. None of the digital buttons work except for the timer, but the clock is on.
ovens can sometimes need a time set on the clock, it dose not need to be the right time but it must be at a time ie not flashing
Dec 11, 2016 | De Dietrich Ovens
Tip
Help! my Pyroclean De Dietrich oven is about 8 years old and the fan option has...
Before you choose to run you oven in the “Self Clean” mode be sure to read this.
After viewing many hundreds of range and oven problems there is one constant theme that comes through. “After running the self clean feature” on my oven I have this problem or that problem. Whether the oven is gas or electric does not seem to matter. The common thing is that the self cleaning feature was just used on the oven, and now it is not working, the glass broke, or you now, cannot even get the door open.
The basic idea of a self cleaning oven is to get the oven so hot that you incinerate everything that is in the oven. The heat from this process will burn up everything in the oven and sometimes things outside also. Even though the wiring and controls are built to withstand high heat, taking the oven to such high temperatures pushes everything to the limit. If something is not insulated perfectly or has shifted a bit then the heat causes it to fail. Repeated heating also wears the insulation out and causes it to break down. For this reason the self cleaning features should be used sparingly.
Manufacturers want to please the customer so even though they know that this can create problems they also know that this feature sells more products. It is in your best interest to not even use this feature if possible.
If you have a oven that will not unlock after the cycle you have a few things you can try.
First make sure that you wait long enough before you try to open the oven. If it has not cooled completely it will not open. Do not run a clean cycle when you do not have the time to let it cool completely before you need it. Sometimes if you cycle the power to your oven off and then on again you can reset the oven and it will open. Turn off the breaker to your oven for a good minute or two before reapplying the power again.
If this fails to work then check your manual for instructions or to get a factory service number. They should be able to give you the information you need to open your oven.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Oct 02, 2010 | Ovens
I have a de Dietrich double electric oven with pyrolysis. I did a clean and now the bottom oven won't heat and fan not working. Top oven is fine, thank goodness
Many times when the self clean function is used they seem to melt connections internally . call your local repair company and have it checked out
Sep 24, 2016 | De Dietrich Ovens
De dietrich oven clock tripping out
I already explained, you need to replace the big 1.5uF Capacitor that
is reponsible for the voltage drop from 220V to about 10V. You need to
remove the timer controler module from the oven, in the meanwhile you
can shunt the 2 wires that usually are shunt by the relay, and then
buy a new capacitor and replace it with a soldering iron.
Good luck.
Apr 11, 2013 | De Dietrich DOC310 Electric Single Oven
How to I clean the inner glass on a die dietrich pyroclean oven
If you are in the U/K, then go too the following site for a detailed explanation.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR GLASS
You should find a video showing you how to do it
Nov 30, 2010 | Ovens
good luck Andy B
May 13, 2008 | De Dietrich DOC310 Electric Single Oven
De Dietrich oven not working!
I suspect that it is the oven lock that needs replacing. I bought a De Deitrich oven (pyroclean) in Sept 2007. The oven failed to heat in Aug 2009. The oven lock needed replacing which meant the unit had to be removed from the wall. It was replaced under guarantee but failed again in June 2010 and was replaced at a cost of €140 by enginneer. I am very dissappoined in the oven and expected to have no problems with it considering the DeDeitrich name. I would not recommend it to a friend. By the way the clock is easy to use if you follow the instructions exactly. Oven used by two careful owners only.
Mar 31, 2008 | Ovens
Ovens Logo
49 people viewed this question
Top De Dietrich Ovens Experts
ashburton
Shehu Pro
Shehu Pro
Electro Med Services...
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
