Question about Canon PIXMA MP160 All-In-One InkJet Printer
My printing result slants to the left. how can i resolve this? did maintenance on control panel but does not work.
  • 4 Answers
Its very simple dude...!!!!
if your paper feed tray is at the back...
just put your hand into the paper feed tray and you can feel a small roller which rotates very easily.....
just turn it anti-clockwise(it is unidirectional-turns only one way) adjust it a little and print something white and notice if the paper is drawn in slant...!!!
Posted on Feb 29, 2012
Lexmark printer not dispensing ink
First, make sure you are using genuine Lexmark cartridges.
Second, try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
If the firmware update doesn't help, please perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If it still doesn't help, please contact our technical support team.
Jan 08, 2013 | Lexmark Impact S305 - multifunction ...
I put in new ink cartridges and the cyan pink won't work.i have a lexmark prevail pro705.
Hello Rina! Welcome to FixYa!
If you have changed Ink Cartridge and after changing Cyan Pink is not printing then you may resolve this issue by Cleaning Print Head, Sometimes due to clogged print head nozzles this problem may happens. By cleaning the Print head Nozzles, This problem may resolve.
From the Printer Control Panel, Navigate to Maintenance, Press Up and Down arrow button to scroll Clean Print head or deep Clean Print Head and then Press OK.
Now try to print again. I hope this issue will be resolved
I hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Feb 14, 2012 | Lexmark Office Equipment & Supplies
Haven't used printer for several weeks, although ink in cartridges print barely visible, tried new cartridges with same result
Dear plloyd, You had left the printer many times, which indicates that the printer heads are jammed due to non use. So go to the printer property in control panel - printer and faxes - your printer. In printer property go to maintenance. There is the option of head cleaning. Run the head cleaning programme twice or thrice. You will see, your old cartridges also can work. Thanks.
Sep 05, 2011 | Kodak ESP 5 Printer
When it prints there are many lines missing and unprinted can you advice please how to resolve this issue?
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Dec 29, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Ricoh Aficio MP 161 is printing slanted duplex copies
Hello sir; There have two way to resolve this problem, 1st, loose the cover hinge push cover all the way to front then tighten it. then go to 2nd step open the top cover, at the left side of the white padding there have to lockes (up & down) open it out look inside there have a reverse roller, clean it with alcohal, hat should take care the problem.
Jan 27, 2010 | Ricoh Office Equipment & Supplies
My computer isn't printing the way it should. It is a CANNON 1800
Hello michelle9mit,
First of all you will need to clean the surfaces of the DRUM, and paper feed path and assembly. This might be the cause of most of your problems. I would suggest also making sure the paper feed sensors are cleaned and tested for the proper voltage levels. As far as the slanting paper the paper feed mechanism may have to be cleaned and aligned. I would also make the suggestion that if you do not have a mechanical background you should get a professional service center to do the work for you, but first get an estimate on the cost and if it is too much, you may want to consider getting a new printer and getting a maintenance plan for it.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 14, 2009 | Dell 3100cn Laser Printer
My printing q shows an item which it says it has been deleting for 5 days nothing can get through...how do i rid it from my q
what you need to do is go to "start", "control panel", "performance and maintenance", "administrative tools", then double click on "services".
(if you are using the classic view, then simply "start", "control panel", "administrative tools")
scroll down the list to " print spooler. single click on it to highlight, then on the left click "stop"
once it is stopped, again on the left, click start.
This should clear out any print documents that became "stuck" in the print queue.
Oct 11, 2008 | Office Equipment & Supplies
Printer prints crooked (8.5 x 11 from paper tray)
check that the paper guides on paper cassette are hard up against paper edges
Oct 27, 2007 | Brother HL-2070N Laser Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
156 people viewed this question
old marine
old marine
