Question about HP Pavilion dv1000 Notebook
Laptop stopped working and now not starting up. I think the battrey is dead and charger not working. it is HP laptop
  • 733 Answers
If the charger has a light on it when it's plugged in and it's not on when you plug it in, then yes your charger is bad. if the light is green then you have issues with the laptop. If no light, check the voltage with a volt meter to see if the charger has power. good luck.
Posted on Sep 05, 2009
Persario/HP charger scam
Remove the battery before you plug in the charger/adapter and see what it will do. It can't recognize a battery mode if there is no battery. Maybe the charger you are using is not appropriate: different voltage, wrong polarity, the tip is not in contact with the plug terminals, or the circuit is not closed to allow the passage of current.
Rocketfish, Targus , and a few others, manufacture universal chargers that work with may laptop makes and models.
Mar 30, 2014 | HP Compaq Presario CQ60-249US Notebook
Battrey charger not working
change you battery charger
Jan 18, 2012 | Drills
Not Turn on
you should have changed the processor before only when the sound started.i think you will have to change your motherboard now as your laptop is not responding at all
so do not worry much,all you have to do is change the motherboard and it will be perfectly fine and do not worry much.Thanks
Jul 26, 2010 | HP Compaq Presario V6000T PC Notebook
Laptop does not start
The loud buzzing was most likely your CPU (processor) fan dying of bust bearings. The CPU is supposed to shut down your pc before it burns out but some intel processors no longer have this feature.
The first step is to find your laptop on the HP support website, and then look for the service manual. You'll need a small philips (crosshead) or posidrive screwdriver and a guitar pick (or similar)
You need to take out the fan, order a new one from ebay and replace. If that doesn't fix it, you need to do the same with the CPU.
Jul 25, 2010 | HP Compaq Presario V6000T PC Notebook
My pc has just stopped running the charger light is on but wont charge help
battrey his already damaged, try replacing them with new battrey ....
Jun 02, 2010 | ASUS Eee PC 1005HAPU17BU Netbook
My HP laptop will not turn on.One day I was using it and everything was normal, after a while I turned it off and the next day when I went to turn it on again it did not turn on. No lights, no screen, no...
Remove the battery and the ac adapter the memory as well.Press and hold the power button down for twenty seconds.Once done put the battery in and the power in,no memory.If it beeps with the memory out the memory might be bad what the beeping signifies is the motherbord is good.Unfortunatly if you have no power lights the motherboard is bad.
good luck
Sep 14, 2009 | Computers & Internet
Help!
key off and out,diconnect negitive side of battrey then postive.clean terimals,charge battrey,connect postive cable (with key off)connect negitive.and start.
your dead battrey is taking up a big load on system,so when you boost it the dead battrey is taking it all the starter is geeting vey little.thats the clicking.
if you dont have a charger dicconect both terminals the same way again,put the jumper cables on the dead battrey.let it charge battrey for 10 15 mins .the longer the better.remover jumpers.
with key off and out conected battrey terminals.connect jumper cables and start.
let me know if it start or not hopefully the key hasnt lost its coding.
Dec 04, 2008 | 2003 Volkswagen Golf
Computer black out
WAT I UNDERSTAND THAT UR WINDOWS HAVE BEEN CORRUPTED AND NEED TO RE-INSTALL USING RECOVERY CD, OFCOUSE WITH AN UPDATED VIRUS CLEANER (AVG IS BETTER).
Nov 22, 2008 | HP Pavilion dv6000z Notebook
Hp dv 6000 I cant turn on my laptop !????
you can turn on your laptop if you dant have an removal battrey n then plug the charge back in and it will work fine however not only that check if the battrey shows any sign of leakeage also once your computer is back on then turn it off again and put the battrey back in if u do not have a removal battrey then keep the laptop unpluged for 5 minutes and try to turn it back on at least 2 times if u have done it then u could try tihis plug the charge wait for ten minutes see if it give u any sign of charging then turn the laptop on .
please try this out and see if it works as im not an it guy but justed wanted to help u
thanks
this is my e mail id
alson_1925@hotmail.com
can u please let me know if that worked for u or not thanks .
Jun 23, 2008 | HP Pavilion dv6000z Notebook
Can't access internet
if ur computer is old may be the battrey on mother board is dead thats why this is giving you this problem
Apr 29, 2008 | Computers & Internet
HP Pavilion dv1000 Notebook Logo
93 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
