Question about IBM ThinkPad T43 Notebook
A USB device has malfunctioned and exceeded the power limits of its hub port. You should disconnect the device.
  • oloo May 11, 2010
    You have not asked a question?
  • IBM Master
  • 1,165 Answers
Usb requires more usb out put then pc has.
Posted on Sep 05, 2009
Apple mobile device usb drivers has malfunctioned and exceed the power limits of its hub port.
ok this is common with usb and high output devices try time machine or using two different ports
Feb 28, 2013 | Computers & Internet
Ewwwwwww... no fun.
You should try a "POWERED"
4 Port USB 3.0 Hub It's important that it's a "POWERED HUB" because you need the HUB to supply it's OWN power and not depend on your Apple E to provide power to your connected USB devices!
The good news is they don't cost much: $8 on eBay
Auction: 202096902632
Note that they include the power supply! Many other HUBS don't.
Your HUB is even LESS if you pick on the USB 2.0. Version, AND YES, each HUB MUST have it's own power supply and that's just what YOU need.
The ONE thing I didn't like about this HUB is the LED lights that are provided for each port! They are TOO bright so I opened it up and plucked all but one LED out. I also bought the 8 and 10 Port HUB versions and 'fixed' them too.
I also didn't need the switches to confuse things (accidentally turn one or more ports OFF)... so my trusty hot glue gun fixed that! All are constant ON now.
Anthony
Black 4 Port USB 3 0 Hub On Off Switches AC Power Adapter Cable For PC...
Oct 27, 2017 | Sony VAIO Computers & Internet
A usb has exceeded the power limits of its hub port
Simply put its what it says.
you have too many devices drawing power from the USB ports of your laptop.
A fix for this is to use a USB hub but it MUST be one with its own power supply.
Sep 07, 2009 | Microsoft Windows XP Home Edition
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
Error power surge on hub port
Some USB devices draw too much current from the computer's USB port and you get an exceed power error message.
To get around this problem, get a powered USB hub and connect it to the Computer's USB port and then connect the troublesome USB device into the powered USB hub.
Apr 09, 2009 | Lenovo 3000 N500 Notebook
Usb power surge
The Safely Remove Hardware icon list all removeable devices regardless whether it is a USB or PCMCIA or a removeable CD/DVD drive etc.
To get around the problem with your USB device that exceeds the power limit of the computer's USB port. Get a powered USB hub and connect it to the computer's USB port and plug the USB device into the powered USB hub.
Apr 06, 2009 | IBM ThinkPad T30 2366 Notebook
Power surge on hub port
Try this to find out which one of your components has an issue. Turn off your machine then unplug all of your USB cables. Turn your machine back on and plug in one of your USB cables. Verify the component you just plugged in works correctly and if it does plug in another cable and verify that component is working. Continue these steps until you have the one component that displays the error you have seen. That component is most likely the cause of your issue and should be replaced.
Good luck, Greased.
Jan 28, 2009 | Dell Dimension 4700C PC Desktop
Maxtor OneTouch lll Mini 120 GB
If your using a USB hub, unplug another device (i.e printer or scanner, fax, etc.). Plug in your One Touch. Then turn off your pc and turn it back on. This should work.
If you use a alot of USB devices, you may need to get a USB Power Hub.
You can try an plug in the One Touch straight to the pc and unpluging all other usb device except the keyboard and mouse.
Let me know if this helps. You also may need to move the ac power to another outlet.
Sep 01, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Helpp! exceeded the power limits on its hub port?
try to change a new USB cord, and if it does not work the problem is a device then
Jun 21, 2008 | Vivitar MAGNACAM Binocular
Power Surge error message
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at thumuvikram@rediffmail.com for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
238 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
