Question about Philips 20DV6942 20 in. TV/DVD Combo
TV WORKED FINE AND AFTER A THUNDER STORM, WONT POWER ON
THE TV IS IN OUR ROOM AND HAS SURVIVED A BILLION STORMS BUT FOR SOME REASON, EVEN THOUGH IT WAS OFF, I CANT GET IT TO POWER ON NOW...I HAVE A FEELING IT MAY HAVE BLEW AN INTERNAL DEVICE BUT NOT SURE... ANY SUGGESTIONS???
    Problem Solver:
  • 11 Answers
Sets such as this still have power applied to stand-by circuits whenever it is plugged in. Try unplugging it for 5 min or so and then if normal operation does not return, ask around for a competent repair shop. With lightning or surges it can be either something "simple" to someone experienced (about $50 maybe) or well exceeding replacement cost. A power strip with surge protection is a good idea in the future, unplugging everything is better but not always practical.
Posted on Sep 05, 2009
I Have a COBY 50i inch, We had a thunder storm wiped out my cable boxes & I think it wipe out my TV. It wont even turn on. Do you think its fried
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 11, 2016 | Coby Televison & Video
Tv does not turn on, after a thunder storm.. tv was off during storm.. but heard a click as if I was turning off tv.. Blueray player , ok Direct tv box ok , all come on that was connected to tv... whi
during thunder storm, is your TV connected to wall outlet, if it so your set have a problem on power supply, you are lucky if is only a blown fuse.
Aug 06, 2014 | Televison & Video
I have vizio sv470m and all of the 4 hdmi plugs stopped working one at a time.
Power doesn't have to be knocked out for a cable box to destroy the HDMI ports on a TV. Thunder miles away will put voltage spikes on the cable system which in turn trashes the main board in the TV. You can get parts for your TV here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 30, 2018 | Vizio VO47L 47 in. LCD TV
Kdl40ex401
Hi there!
One of reasons your tv not working, the thunder storm /lighting possibility has burnt your Tv micro processor. get a technician to check the power supply section too because during the thunder storm your TV circuitry received excessive voltage .
If is the main processor is burnt you have to change it for the TV to work .
Jan 10, 2018 | Sony KDL-40EX401 42" HDTV-Ready LCD TV
Not getting power to tv.Socket and plugs are getting power ,there was a thunder storm,but every thing else fine.
The problem of your tv is the power supply the thunder storm cause that. You should unplug your tv when not in use, try to check the fuse if busted, their are two classification of a busted fuse, if the fuse is only open try to replace it but if the fuse is all burned out dont just replace it, it has a shorted parts like the regulator and the bridge type rectifier
Jun 24, 2011 | Televison & Video
My wd-60c9 60 in. dlp hdtv quit working after a thunder storm it was plugged into a powerstrip . The only this that wont work are the tv and direct tv receiver.
fried it, unfixable, get a new one. and start unplugging everything during storms. if you still want to watch tv while there is storm get a old crappy small tv to watch while you high priced one is in safe position(unplugged)
May 23, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
42" westinghouse flat screen wont turn on
Some surge protectors fail just when most needed.
Jun 19, 2017 | Westinghouse TX-52F480S 52 in. LCD TV
Problem with tv
look for reset sw. under unit.
Aug 02, 2008 | Insignia Televison & Video
JVC 48" HDTV Ready Widescreen Projection TV
Terrible thunder storm can create electrict shock to our appliances thats why we recomended that if you donot use your tv pls unplug it, and it mostly if you use outdoor antena when the thunder hit the tv will damage.
Jan 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Philips 20DV6942 20 in. TV/DVD Combo Logo
271 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
